    MMM-Todoist only displays 'Loading...'
    26 Posts 3 Posters 13.0k Views 3 Watching
      robertybob @sdetweil
      @sdetweil said in MMM-Todoist only displays 'Loading...':
      @robertybob that was in the module folder, right? the git checkout?
      did u do a git fetch first, to get the info to the pi
      @sdetweil Hi Sam. Yeah it was in the module folder, but I didn’t realise I had to do git fetch before git checkout (so I haven’t done git fetch at all). Can I simply try those commands, in the correct order, for it to work, or have I messed anything up (and therefore it best I delete and reinstall the module)?
        sdetweil @robertybob
        @robertybob u didn’t break anything. git is very robust
        when u did the git checkout it should have said unknown commit
        so git fetch to get the stuff from github to your machine. (git pull only updates the current branch)
        then git checkout as described
          This seems to have worked, but the issue of ‘loading…’ is still there. Ah well, thank you for your help :) If anyone here does manage to get the module working ok, please let me know how you did it!
            MadeInMaine
            Did anyone ever figure out how to get past the “loading”?
            I can’t seem to get it to work
            Thanks in advance
              sdetweil @MadeInMaine
              @MadeInMaine what do the messages say?
              2 places
              where you do npm start,
              or if you use pm2 to auto start mm,.then
              pm2 logs --lines=50
              and in the developers window, ctrl-shift-i on the keyboard and then select the console tab
              M 3 Replies Last reply Reply Quote 0
                MadeInMaine @sdetweil
                I don’t get an error, just says “loading” under the Todoist section on the MM
                I ‘npm start’ from the MagicMirror directory
                Sorry, I am not sure what the rest of the info is you requested
                  I am not sure exactly what you mean.
                  Could you explain/dumb it down for me….
                  Thank you so much
                    @MadeInMaine the instructions are there
                      I see the thé instructions to do thé git fetch in the ToDoist folder, then git checkout df2d4ff.
                      Is that all I need to do?
                        @MadeInMaine I am talking about logs of messages while mm is running
