    MMM-Todoist only displays 'Loading...'
    26 Posts 3 Posters 13.0k Views 3 Watching
      MadeInMaine
      Did anyone ever figure out how to get past the “loading”?
      I can’t seem to get it to work
      Thanks in advance
        sdetweil @MadeInMaine
        @MadeInMaine what do the messages say?
        2 places
        where you do npm start,
        or if you use pm2 to auto start mm,.then
        pm2 logs --lines=50
        and in the developers window, ctrl-shift-i on the keyboard and then select the console tab
        M 3 Replies Last reply Reply Quote 0
          MadeInMaine @sdetweil
          I don’t get an error, just says “loading” under the Todoist section on the MM
          I ‘npm start’ from the MagicMirror directory
          Sorry, I am not sure what the rest of the info is you requested
            I am not sure exactly what you mean.
            Could you explain/dumb it down for me….
            Thank you so much
              @MadeInMaine the instructions are there
                I see the thé instructions to do thé git fetch in the ToDoist folder, then git checkout df2d4ff.
                Is that all I need to do?
                  @MadeInMaine I am talking about logs of messages while mm is running
                    Where do I find the logs of messages while mm is running?
                      @MadeInMaine I gave you the instructions for where the logs are
                        Is the developer window (for curl-shift-i) the terminal window or folders/files?
