    MMM-Todoist only displays 'Loading...'
    26 Posts 3 Posters 13.0k Views 3 Watching
      robertybob @sdetweil
      This seems to have worked, but the issue of ‘loading…’ is still there. Ah well, thank you for your help :) If anyone here does manage to get the module working ok, please let me know how you did it!
        MadeInMaine
        Did anyone ever figure out how to get past the “loading”?
        I can’t seem to get it to work
        Thanks in advance
          sdetweil @MadeInMaine
          @MadeInMaine what do the messages say?
          2 places
          where you do npm start,
          or if you use pm2 to auto start mm,.then
          pm2 logs --lines=50
          and in the developers window, ctrl-shift-i on the keyboard and then select the console tab
          M 3 Replies Last reply Reply Quote 0
            MadeInMaine @sdetweil
            I don’t get an error, just says “loading” under the Todoist section on the MM
            I ‘npm start’ from the MagicMirror directory
            Sorry, I am not sure what the rest of the info is you requested
              I am not sure exactly what you mean.
              Could you explain/dumb it down for me….
              Thank you so much
                @MadeInMaine the instructions are there
                  I see the thé instructions to do thé git fetch in the ToDoist folder, then git checkout df2d4ff.
                  Is that all I need to do?
                    @MadeInMaine I am talking about logs of messages while mm is running
                      Where do I find the logs of messages while mm is running?
                        @MadeInMaine I gave you the instructions for where the logs are
