    Internet connection problem related to updates
    14 Posts 3 Posters 3.6k Views 3 Watching
      RIKKO14
      ~ 1 month ago I redid my MM by installing the Bugsounet wiki (https://wiki.bugsounet.fr/en/MMInstaller) then I installed GoogleAssistant (https://wiki.bugsounet.fr/ en/MMM-GoogleAssistant)
      For several days I often have a connection problem with my MM.
      I often get this screen that pops up :
      Very often it is displayed an updated request like this :
      And I even had it on display :
      I have however installed the EXT-UpdateNotification module (I use the default configuration) but the updates are not done automatically
      I have the impression that it’s a pb of internet with wifi but yet I have no pb of internet with my computer in wifi so I don’t understand.
      what should I do ?
      Thank you for your help
        sdetweil @RIKKO14
        @RIKKO14 that update is a system update, not MagicMirror
        so you would use
        sudo apt get update
        sudo apt upgrade
        wifi
        some suggest making sure it’s idle wifi sleep is disable
          RIKKO14
          sudo apt get update does not work :
          It is not possible to configure the updates of the system in automatic ?
          How do I do “making sure it’s idle wifi sleep is disable” ?
            sdetweil @RIKKO14
            @RIKKO14 sorry, typo on commands
            sudo apt-get update
            sudo apt-get upgrade
            sleep , google is your friend…
            https://forums.raspberrypi.com/viewtopic.php?t=314387#p1881498
              RIKKO14
              thanks you.
              So, It is not possible to configure the updates of the system in automatic ?
              About “https://forums.raspberrypi.com/viewtopic.php?t=314387#p1881498” it’s for Pi Zero W Buster, I have Pi4
              so, according to you, the problem would be a problem of save mode wifi power, that’s right ?
              How can I disable Wi-Fi power save mode on my Pi4?
              if I have to write this command line: /sbin/iwconfig wlan0 power off, where and how?
                sdetweil @RIKKO14
                @RIKKO14 open a terminal window to type the command
                if at the pi desktop
                ctrl-alt-t
                or use ssh connection to pi
                  RIKKO14
                  it doen’t work…
                    sdetweil @RIKKO14
                    @RIKKO14 add sudo in front of that
                      RIKKO14
                      the same…
                        sdetweil @RIKKO14
                        @RIKKO14 with a space after sudo
