    Internet connection problem related to updates
    14 Posts 3 Posters 4.7k Views 3 Watching
      RIKKO14
      sudo apt get update does not work :
      It is not possible to configure the updates of the system in automatic ?
      How do I do “making sure it’s idle wifi sleep is disable” ?
        sdetweil @RIKKO14
        @RIKKO14 sorry, typo on commands
        sudo apt-get update
        sudo apt-get upgrade
        sleep , google is your friend…
        https://forums.raspberrypi.com/viewtopic.php?t=314387#p1881498
          RIKKO14
          thanks you.
          So, It is not possible to configure the updates of the system in automatic ?
          About “https://forums.raspberrypi.com/viewtopic.php?t=314387#p1881498” it’s for Pi Zero W Buster, I have Pi4
          so, according to you, the problem would be a problem of save mode wifi power, that’s right ?
          How can I disable Wi-Fi power save mode on my Pi4?
          if I have to write this command line: /sbin/iwconfig wlan0 power off, where and how?
            sdetweil @RIKKO14
            @RIKKO14 open a terminal window to type the command
            if at the pi desktop
            ctrl-alt-t
            or use ssh connection to pi
              RIKKO14
              it doen’t work…
                sdetweil @RIKKO14
                @RIKKO14 add sudo in front of that
                  RIKKO14
                  the same…
                    sdetweil @RIKKO14
                    @RIKKO14 with a space after sudo
                      RIKKO14
                      the same…
                        RIKKO14
                        what to do ?
                          sdetweil @RIKKO14
                          @RIKKO14 I do not know any more info
                          swvalentiS 1 Reply Last reply
                          • swvalentiS
                            swvalenti Project Sponsor @sdetweil
                            sounds like a fresh install is needed as something got corrupted and copy over your MM folder to new install.
