    MMM-MoonPhase
    7 Posts 4 Posters 2.0k Views 3 Watching
      Anthony Project Sponsor
      Hello to all forum. Recently my rasberry’s SD card crashed and I Installed everything from scratch. I have only one problem with MMM-MoonPhse which cannot be installed. I had this one in my previous MM and was working fine. Does anyone know if something happened? Below is the errors I am getting during installation. I am not a programmer so I would be grateful if somebody spot something wrong on my side.
      Cloning into 'MMM-MoonPhase'...
      remote: Enumerating objects: 214, done.
      remote: Counting objects: 100% (42/42), done.
      remote: Compressing objects: 100% (33/33), done.
      remote: Total 214 (delta 15), reused 18 (delta 9), pack-reused 172
      Receiving objects: 100% (214/214), 1.07 MiB | 2.76 MiB/s, done.
      Resolving deltas: 100% (85/85), done.
      npm ERR! code ERESOLVE
      npm ERR! ERESOLVE could not resolve
      npm ERR!
      npm ERR! While resolving: MMM-MoonPhase@1.0.1
      npm ERR! Found: stylelint@14.16.1
      npm ERR! node_modules/stylelint
      npm ERR!   peer stylelint@"14.x" from grunt-stylelint@0.18.0
      npm ERR!   node_modules/grunt-stylelint
      npm ERR!     dev grunt-stylelint@"latest" from the root project
      npm ERR!
      npm ERR! Could not resolve dependency:
      npm ERR! dev stylelint-config-standard@"latest" from the root project
      npm ERR!
      npm ERR! Conflicting peer dependency: stylelint@15.2.0
      npm ERR!   peer stylelint@"^15.0.0" from stylelint-config-standard@30.0.1
      npm ERR!   node_modules/stylelint-config-standard
      npm ERR!
      npm ERR! Fix the upstream dependency conflict, or retry
      npm ERR! this command with --force, or --legacy-peer-deps
      npm ERR! to accept an incorrect (and potentially broken) dependency resolution.
      npm ERR!
      npm ERR! See /home/anthony/.npm/eresolve-report.txt for a full report.
      npm ERR!     /home/anthony/.npm/_logs/2023-03-15T16_21_25_597Z-debug-0.log
      Thank you in advance.
      swvalentiS KristjanESPERANTOK 2 Replies Last reply Reply Quote 0
      • swvalentiS Offline
        swvalenti Project Sponsor @Anthony
        @Anthony not sure if this is related but I see you are cloning into moon phase. That folder shouldn’t exist yet and should be cloning into modules folder instead. I can’t see your commands before that to make sure that’s what you’ve done.
          sdetweil @swvalenti
          @swvalenti git tells u the new folder name where the files will be
          • KristjanESPERANTOK Offline
            KristjanESPERANTO Module Developer @Anthony
            @Anthony Contrary to the instructions, you do not need to run npm install for this module. This would only install packages for development, these are not necessary for you to use the module.
              Anthony Project Sponsor @KristjanESPERANTO
              @KristjanESPERANTO , @sdetweil , @swvalenti Thank you for your replies. As I remember I run npm install at the first time and I had no problems. I will try it without this command as well but I do not think this is the problem.
              swvalentiS 1 Reply Last reply Reply Quote 0
                Just tried it on mine no issues and no npm install
                A 1 Reply Last reply Reply Quote 1
                  Anthony Project Sponsor @swvalenti
                  @swvalenti you were right. it worked just fine without npm command. Thank you.
