    MMM-WunderGround-PWS-Observations
    20 Posts 5 Posters 10.5k Views 9 Watching
    • V
      Volkae @Saabman
      @Saabman
      No, the Wunderground module is above the weather module, so I think it cannot be the left padding.
      Both have position top_right in the config.js
        Saabman Project Sponsor @Volkae
        @Volkae can you post a screen shot even just a photo of your screen.?
        S V 2 Replies Last reply
          sdetweil @Saabman
          @Saabman by using the developers window you can examine the styles and results
          https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1679343561716
          • V
            Volkae @Saabman
            @Saabman said in MMM-WunderGround-PWS-Observations:
              sdetweil @Volkae
              @Volkae may need to override
              .module {
                margin-bottom: var(--gap-modules);
              defaults to 30px
              V 1 Reply Last reply
              • V
                Volkae @sdetweil
                sorry Sam, I don 't know where to put the lines.
                Absolut beginner…
                  sdetweil @Volkae
                  @Volkae all css goes in ~/MagicMirror/css/custom.css
                  if the file doesn’t exist, create it
                  • V
                    Volkae @sdetweil
                    I put it in my custom.css but it only changes the distance between the upper edge from my MM and the weather module. It does not change the distance between the weather module and the WunderGround-PWS-Observation module.
                      sdetweil @Volkae
                      @Volkae hm. makes no sense as it explicitly does the gap between modules
                      • V
                        Volkae @sdetweil
                        • Module styles.
                        .module {
                        margin-bottom: 30px;
