    MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast
    259 Posts 55 Posters 721.5k Views 57 Watching
      sdetweil @chris1971
      @chris1971 yes, when u make any change, you should stop MM and then then restart it…
      as I said before, some modules impact others…
      I fixed a similar problem in OpenWeatherMapForecast as the author was not updating it anymore
      this is my fork with the fix https://github.com/sdetweil/MMM-OpenWeatherMapForecast
      I would look at the messages
      pm2 stop all
      pm2 flush
      pm2 start all
      wait
      pm2 logs --lines=100
      or, not use pm2
      pm2 stop all
      npm start >somefile.txt 2>&1
      wait
      ctrl-c to stop MM (in the window where you did npm start )
      then examine the contents of somefile.txt to see if there was any error that might causing the problem
      you can also look in the MagicMirror developers window to see if there is a problem there
      ctrl-shift-i on the running MM screen
      select the console tab
      and put weath in the filter field
      this will reduce the output to modules with weath in their name
      looking for any content in red
      C 1 Reply Last reply
        chris1971 @sdetweil
        @sdetweil lot of stuff…
        pi@raspberrypi:~ $ pm2 logs --lines=100
        PM2 | 2023-03-31T16:08:12: PM2 log: App [MagicMirror:0] starting in -fork mode-
        PM2 | 2023-03-31T16:08:12: PM2 log: App [MagicMirror:0] online
        /home/pi/.pm2/logs/MagicMirror-error.log last 100 lines:
        0|MagicMir | [31.03.2023 16:08.20.333] [WARN] You’re using a full whitelist configuration to allow for all IPs
        0|MagicMir | MESA-LOADER: failed to retrieve device information
        0|MagicMir | …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[2472:0331/160823.980369:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=134
        0|MagicMir | …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[2472:0331/160825.475337:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=134
        0|MagicMir | …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[2472:0331/160827.345249:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=134
        0|MagicMir | [2512:0331/160829.375127:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
        /home/pi/.pm2/logs/MagicMirror-out.log last 100 lines:
        0|MagicMir |
        0|MagicMir | > magicmirror@2.22.0 start
        0|MagicMir | > DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
        0|MagicMir |
        0|MagicMir | [31.03.2023 16:08.18.855] [LOG] Starting MagicMirror: v2.22.0
        0|MagicMir | [31.03.2023 16:08.18.868] [LOG] Loading config …
        I read something about the GPU process in the forum - could this infuence the system?
          sdetweil @chris1971
          @chris1971 possibly
          for pm2 add the
          export ELECTRON_DISABLE_GPU=1
          to the ~/MagicMirror/installers/mm.sh
          before the line
          DISPLAY=:0 npm start
          for using npm start
          just do it once in the terminal window
            chris1971 @sdetweil
            @sdetweil still not loading…
            [31.03.2023 16:29.04.053] [LOG] Starting MagicMirror: v2.22.0
            [31.03.2023 16:29.04.077] [LOG] Loading config …
            [31.03.2023 16:29.04.113] [LOG] Loading module helpers …
            [31.03.2023 16:29.04.120] [LOG] No helper found for module: alert.
            [31.03.2023 16:29.04.191] [LOG] Initializing new module helper …
            [31.03.2023 16:29.04.194] [LOG] Module helper loaded: updatenotification
            [31.03.2023 16:29.04.196] [LOG] No helper found for module: clock.
            [31.03.2023 16:29.04.591] [LOG] Initializing new module helper …
            [31.03.2023 16:29.04.592] [LOG] Module helper loaded: MMM-OpenWeatherForecast
            [31.03.2023 16:29.05.736] [LOG] Initializing new module helper …
            [31.03.2023 16:29.05.740] [LOG] Module helper loaded: calendar
            [31.03.2023 16:29.05.754] [LOG] No helper found for module: MMM-TextClock.
            [31.03.2023 16:29.06.143] [LOG] Initializing new module helper …
            [31.03.2023 16:29.06.150] [LOG] Module helper loaded: newsfeed
            [31.03.2023 16:29.06.155] [LOG] No helper found for module: MMM-RAIN-MAP.
            [31.03.2023 16:29.06.170] [LOG] Initializing new module helper …
            [31.03.2023 16:29.06.172] [LOG] Module helper loaded: MMM-GoogleMapsTraffic
            [31.03.2023 16:29.06.173] [LOG] All module helpers loaded.
            [31.03.2023 16:29.06.803] [LOG] Starting server on port 8080 …
            [31.03.2023 16:29.06.828] [WARN] You’re using a full whitelist configuration to allow for all IPs
            [31.03.2023 16:29.06.884] [ERROR] Whoops! There was an uncaught exception…
            [31.03.2023 16:29.06.900] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
            at Server.setupListenHandle [as _listen2] (node:net:1432:16)
            at listenInCluster (node:net:1480:12)
            at doListen (node:net:1629:7)
            at process.processTicksAndRejections (node:internal/process/task_queues:84:21) {
            code: ‘EADDRINUSE’,
            errno: -98,
            syscall: ‘listen’,
            address: ‘0.0.0.0’,
            port: 8080
            [31.03.2023 16:29.06.901] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            [31.03.2023 16:29.06.902] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
            [31.03.2023 16:29.08.680] [LOG] Launching application.
            …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[2071:0331/162912.978009:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=6
            …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[2071:0331/162914.498526:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=6
            …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[2071:0331/162915.779583:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=6
            [31.03.2023 16:29.37.588] [LOG] Shutting down server…
            [31.03.2023 16:29.37.595] [LOG] Stopping module helper: updatenotification
            [31.03.2023 16:29.37.596] [LOG] Stopping module helper: MMM-OpenWeatherForecast
            [31.03.2023 16:29.37.596] [LOG] Stopping module helper: calendar
            [31.03.2023 16:29.37.597] [LOG] Stopping module helper: newsfeed
            [31.03.2023 16:29.37.597] [LOG] Stopping module helper: MMM-GoogleMapsTraffic
              sdetweil @chris1971
              @chris1971 said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
              did u do the pm2 stop all?
              did you use any install instructions before my script? the manual install describes how to create a service to auto start MM
                chris1971 @sdetweil
                yes - ich changed the mm.sh after stop all
                my method for installation:
                • format SD card
                • install Bullseye
                • install sudo apt-get install xrdp (to get a remote connection via remote desktop)
                • install your scripts including screensaver/ pm2
                • install the modules
                  it worked once … I do not understand what changed after a restart…
                  sdetweil @chris1971
                  @chris1971 and u checked the pm2 status
                  before doing npm start ?
                  you don’t reboot after pm2 stop all, as t will restart MM on boot (its job)
                    chris1971 @sdetweil
                    @sdetweil this is the pm2 status
                    pi@raspberrypi:~/MagicMirror $ pm2 status
                    │ id │ name │ mode │ ↺ │ status │ cpu │ memory │
                    │ 0 │ MagicMirror │ fork │ 0 │ online │ 0% │ 2.3mb │
                    with npm start I only have a black screen in the terminal - I can see the conten in the browser with http://192.168.178.35:8080/
                    S 3 Replies Last reply
                      sdetweil @chris1971
                      @chris1971 pm2 stop all
                      then cd ~/MagicMirror
                      npm start
                      only can have ONE instance running at a time on the same config.js port: setting
                        sdetweil @chris1971
                        @chris1971 yes, you have another instance running , so this one will fail
                          sdetweil @chris1971
                          you are looking at the one running under pm2
                            chris1971 @sdetweil
                            sdetweil 5 minutes ago
                            npm start
                            ahhh… ok: with this I am able to see the scree in the terminal - but the weather module is still not loading in the terminal
                            Errors like before:
                            [31.03.2023 17:19.15.233] [LOG] Launching application.
                            …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[2465:0331/171918.392802:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=6
                            …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[2465:0331/171919.478457:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=6
                            …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[2465:0331/171920.679631:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=6
                            [2509:0331/171921.424506:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
                            [31.03.2023 17:19.25.235] [LOG] Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/c.euro%40gmx.de/private-8dd63e4cddfec3349/basic.ics - Interval: 50000
                            [31.03.2023 17:19.25.774] [LOG] Create new newsfetcher for url: http://www.radiomuelheim.de/lokalnachrichten.xml - Interval: 300000
                            [31.03.2023 17:19.25.793] [LOG] Create new newsfetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
                            [31.03.2023 17:19.25.813] [LOG] Working notification system. Notification: MMM-GOOGLE_MAPS_TRAFFIC-GET payload: { style: ‘standard’ }
                            have to go out for a beer now…:dizzy_face:
                              sdetweil @chris1971
                              @chris1971 u have to enter the
                              EVERY time you open a new terminal window
                              so, then i’d look in the MM screen developers window as previously described
                                chris1971 @sdetweil
                                @sdetweil I placed the “export ELECTRON_DISABLE_GPU=1” in the install.
                                Where do I have to place the “export ELECTRON_DISABLE_GPU=1” in the terminal window?
                                Info from console (red):
                                >Uncaught TypeError: Cannot read properties of undefined (reading ‘length’)
                                at script.onload (MMM-GoogleMapsTraffic.js:77:52)
                                MMM-OpenWeatherForecast.js:685 Uncaught (in promise) TypeError: console.log is not a function
                                at Class.addIcon (MMM-OpenWeatherForecast.js:685:13)
                                at Class.processWeatherData (MMM-OpenWeatherForecast.js:370:61)
                                at Class.socketNotificationReceived (MMM-OpenWeatherForecast.js:282:40)
                                at module.js:245:9
                                at Socket. (socketclient.js:38:4)
                                at Emitter.emit (index.mjs:136:20)
                                at Socket.emitEvent (socket.js:498:20)
                                at Socket.onevent (socket.js:485:18)
                                at MMSocket.socket.onevent (socketclient.js:32:11)
                                at Socket.onpacket (socket.js:455:22)
                                js?key=cccc:221 You have included the Google Maps JavaScript API multiple times on this page. This may cause unexpected errors.
                                js?key=uuuuu:217 Google Maps JavaScript API has been loaded directly without a callback. This is not supported and can lead to race conditions and suboptimal performance. For supported loading patterns please see https://goo.gle/js-api-loading
                                MMM-GoogleMapsTraffic.js:77 Uncaught TypeError: Cannot read properties of undefined (reading ‘length’)
                                S 2 Replies Last reply
                                  sdetweil @chris1971
                                  you just enter that command string and hit enter
                                    sdetweil @chris1971
                                    I haven’t seen that one before
                                    I xxx’ed out your api key in the debug info
                                      chris1971 @sdetweil
                                      @sdetweil thanks for xxx
                                      What is your recommendation? Delete maps and new install?
                                      Can you explain why I see the MM in the terminal correct, if I stop all and start npm? Is ist possible to delete PM2?
                                        sdetweil @chris1971
                                        @chris1971 delete pm2, sure, see the
                                        pm2 --help
                                        output
                                        no idea why u are having trouble
                                        try this
                                        instead of npm start
                                        do
                                        npm run server
                                        then access from the remote and see what happens
                                          chris1971 @sdetweil
                                          npm run server - no success
                                          I deleted pm2 - then I was able to start MM from the console without black screen with npm start. But then MM didn’t start on the mirror.
                                          Maybe I will setup a new system tomorrow … thanks for your input until now - cheers
                                            sdetweil @chris1971
                                            @chris1971 hm… are you trying to display mm on multiple monitors at once?
                                            if so
                                            this is built in function
                                            edit the config.js to allow access from outside the mm machine
                                            address:'0.0.0.0'
                                            ipWhitelist:[],
                                            then on the mm machine, in a terminal window, do
                                            ip addr
                                            and remember that value
                                            then
                                            npm start
                                            then on your other machine, use a browser
                                            (Chrome, Edge, Firefox, Midori, Safari)
                                            and open http://ip_address_from_above:8080
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 11 / 13
