    MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast
    259 Posts 55 Posters 692.4k Views 57 Watching
      sdetweil @chris1971
      @chris1971 and u checked the pm2 status
      before doing npm start ?
      you don’t reboot after pm2 stop all, as t will restart MM on boot (its job)
        chris1971 @sdetweil
        @sdetweil this is the pm2 status
        pi@raspberrypi:~/MagicMirror $ pm2 status
        │ id │ name │ mode │ ↺ │ status │ cpu │ memory │
        │ 0 │ MagicMirror │ fork │ 0 │ online │ 0% │ 2.3mb │
        with npm start I only have a black screen in the terminal - I can see the conten in the browser with http://192.168.178.35:8080/
        S 3 Replies Last reply Reply Quote 0
          sdetweil @chris1971
          @chris1971 pm2 stop all
          then cd ~/MagicMirror
          npm start
          only can have ONE instance running at a time on the same config.js port: setting
            sdetweil @chris1971
            @chris1971 yes, you have another instance running , so this one will fail
              sdetweil @chris1971
              @chris1971 said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
              you are looking at the one running under pm2
                chris1971 @sdetweil
                sdetweil 5 minutes ago
                npm start
                ahhh… ok: with this I am able to see the scree in the terminal - but the weather module is still not loading in the terminal
                Errors like before:
                [31.03.2023 17:19.15.233] [LOG] Launching application.
                MESA-LOADER: failed to retrieve device information
                …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[2465:0331/171918.392802:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=6
                …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[2465:0331/171919.478457:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=6
                …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[2465:0331/171920.679631:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=6
                [2509:0331/171921.424506:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
                [31.03.2023 17:19.25.235] [LOG] Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/c.euro%40gmx.de/private-8dd63e4cddfec3349/basic.ics - Interval: 50000
                [31.03.2023 17:19.25.774] [LOG] Create new newsfetcher for url: http://www.radiomuelheim.de/lokalnachrichten.xml - Interval: 300000
                [31.03.2023 17:19.25.793] [LOG] Create new newsfetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
                [31.03.2023 17:19.25.813] [LOG] Working notification system. Notification: MMM-GOOGLE_MAPS_TRAFFIC-GET payload: { style: ‘standard’ }
                have to go out for a beer now…:dizzy_face:
                  sdetweil @chris1971
                  @chris1971 u have to enter the
                  export ELECTRON_DISABLE_GPU=1
                  EVERY time you open a new terminal window
                  so, then i’d look in the MM screen developers window as previously described
                    chris1971 @sdetweil
                    @sdetweil I placed the “export ELECTRON_DISABLE_GPU=1” in the install.
                    Where do I have to place the “export ELECTRON_DISABLE_GPU=1” in the terminal window?
                    Info from console (red):
                    >Uncaught TypeError: Cannot read properties of undefined (reading ‘length’)
                    at script.onload (MMM-GoogleMapsTraffic.js:77:52)
                    MMM-OpenWeatherForecast.js:685 Uncaught (in promise) TypeError: console.log is not a function
                    at Class.addIcon (MMM-OpenWeatherForecast.js:685:13)
                    at Class.processWeatherData (MMM-OpenWeatherForecast.js:370:61)
                    at Class.socketNotificationReceived (MMM-OpenWeatherForecast.js:282:40)
                    at module.js:245:9
                    at Socket. (socketclient.js:38:4)
                    at Emitter.emit (index.mjs:136:20)
                    at Socket.emitEvent (socket.js:498:20)
                    at Socket.onevent (socket.js:485:18)
                    at MMSocket.socket.onevent (socketclient.js:32:11)
                    at Socket.onpacket (socket.js:455:22)
                    js?key=cccc:221 You have included the Google Maps JavaScript API multiple times on this page. This may cause unexpected errors.
                    js?key=uuuuu:217 Google Maps JavaScript API has been loaded directly without a callback. This is not supported and can lead to race conditions and suboptimal performance. For supported loading patterns please see https://goo.gle/js-api-loading
                    MMM-GoogleMapsTraffic.js:77 Uncaught TypeError: Cannot read properties of undefined (reading ‘length’)
                      sdetweil @chris1971
                      you just enter that command string and hit enter
                        sdetweil @chris1971
                        I haven’t seen that one before
                        I xxx’ed out your api key in the debug info
                          chris1971 @sdetweil
                          @sdetweil thanks for xxx
                          What is your recommendation? Delete maps and new install?
                          Can you explain why I see the MM in the terminal correct, if I stop all and start npm? Is ist possible to delete PM2?
                            sdetweil @chris1971
                            @chris1971 delete pm2, sure, see the
                            pm2 --help
                            output
                            no idea why u are having trouble
                            try this
                            instead of npm start
                            do
                            npm run server
                            then access from the remote and see what happens
                              chris1971 @sdetweil
                              npm run server - no success
                              I deleted pm2 - then I was able to start MM from the console without black screen with npm start. But then MM didn’t start on the mirror.
                              Maybe I will setup a new system tomorrow … thanks for your input until now - cheers
                                sdetweil @chris1971
                                @chris1971 hm… are you trying to display mm on multiple monitors at once?
                                if so
                                this is built in function
                                edit the config.js to allow access from outside the mm machine
                                address:'0.0.0.0'
                                ipWhitelist:[],
                                then on the mm machine, in a terminal window, do
                                ip addr
                                and remember that value
                                then
                                npm start
                                then on your other machine, use a browser
                                (Chrome, Edge, Firefox, Midori, Safari)
                                and open http://ip_address_from_above:8080
                                  chris1971 @sdetweil
                                  Short summary: I installed MM new with your script - I agreed to the installation of pm2 and disable screensaver. To get a connection to my WIN 10 via remote desktop computer I need to install sudo apt-get install xrdp. Without this installation I’m not able to start the remote desktop connetcion - Only via putty.
                                  After the installation I am not able to run npm start without getting a black screen. I have to pm2 stop all - then npm start again and I see the MM screen on my computer to update the modules, config, etc.
                                  This is what we have seen before:
                                  [31.03.2023 14:13.31.869] [LOG] Starting server on port 8080 …
                                  [31.03.2023 14:13.31.892] [WARN] You’re using a full whitelist configuration to allow for all IPs
                                  [31.03.2023 14:13.31.940] [ERROR] Whoops! There was an uncaught exception…
                                  [31.03.2023 14:13.31.961] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                                  at Server.setupListenHandle [as _listen2] (node:net:1432:16)
                                  at listenInCluster (node:net:1480:12)
                                  at doListen (node:net:1629:7)
                                  at process.processTicksAndRejections (node:internal/process/task_queues:84:21) {
                                  code: ‘EADDRINUSE’,
                                  errno: -98,
                                  syscall: ‘listen’,
                                  address: ‘0.0.0.0’,
                                  port: 8080
                                  With this error MM is running on the Mirror screen without problems.
                                  When I install MMM-GoogleMapsTraffic I get following message:
                                  npm ERR! code ERESOLVE
                                  npm ERR! ERESOLVE could not resolve
                                  npm ERR!
                                  npm ERR! While resolving: MMM-GoogleMapsTraffic@1.0.0
                                  npm ERR! Found: stylelint@14.16.1
                                  npm ERR! node_modules/stylelint
                                  npm ERR! peer stylelint@“14.x” from grunt-stylelint@0.18.0
                                  npm ERR! node_modules/grunt-stylelint
                                  npm ERR! dev grunt-stylelint@“latest” from the root project
                                  npm ERR!
                                  npm ERR! Could not resolve dependency:
                                  npm ERR! dev stylelint-config-standard@“latest” from the root project
                                  npm ERR!
                                  npm ERR! Conflicting peer dependency: stylelint@15.4.0
                                  npm ERR! peer stylelint@“^15.4.0” from stylelint-config-standard@32.0.0
                                  npm ERR! node_modules/stylelint-config-standard
                                  npm ERR!
                                  npm ERR! Fix the upstream dependency conflict, or retry
                                  npm ERR! this command with --force, or --legacy-peer-deps
                                  npm ERR! to accept an incorrect (and potentially broken) dependency resolution.
                                  npm ERR!
                                  npm ERR! See /home/pi/.npm/eresolve-report.txt for a full report.
                                  npm ERR! /home/pi/.npm/_logs/2023-04-01T11_07_55_012Z-debug-0.log
                                  After installation of MMM-GoogleMapsTraffic the Openweather is not loading anymore.
                                    sdetweil @chris1971
                                    @chris1971 we have two different problems going on.
                                    1. when u start MagicMirror, it will display on the monitor attached to the system. NOT any remote console.
                                      it IS a mirror on the wall after all
                                    IF you want to show the mirror screen on a remote system, phone, laptop, tablet, desktop
                                    then you use a browser on that other device to show the mm screen from it’s server on the mirror system.
                                    you do not start another running copy of MagicMirror . you do not need rdp to do this.
                                    just a browser.
                                    IF you want to display MagicMirror over your rdp session, then you would open a browser thru the rdp session and use the url
                                    http://localhost:8080
                                    as rdp makes it like you are at the local desktop
                                    I’ll look at the Googlemapstraffic problem
                                      chris1971 @sdetweil
                                      @sdetweil many thanks - but I have to install/ modify the Mirror from my computer. That’s the reason why I would like to connect via WIFI and get easy access to the modules/ config, etc.
                                      With Putty I only have access to the terminal - not to the PI Explorer…
                                      Your recommendation is not to install sudo apt-get install xrdp - it seems that this install mekes the trouble with 2 systems…
                                        sdetweil @chris1971
                                        @chris1971 yes, rdp is fine to access the console.
                                        but from the remote system u just use a browser to see the mm contents
                                        same as if you used putty to edit the config.js
                                        try it. that is the whole point of pm2, start the mirror/web server without user intervention
                                        as u have removed pm2, use putty to logon and npm start. , then disconnect putty
                                        now use your browser on windows to access the mm web server BEFORE STARTING rdp, using the same IP address as you used for putty
                                        and port 8080 (the port number in mm config.js)
                                        if u make a change and restart mm. then hit refresh on the browser page
                                          chris1971 @sdetweil
                                          @sdetweil Thanks for your support - a solution for the maps issue would be really nice!!!
                                          The 1st topic with the remote desktop is my minor challenge
                                            sdetweil @chris1971
                                            @chris1971 so looking at MMM-GoogleMapsTraffic , it uses very old stuff (5 years) in its dev dependencies section of package.json
                                            sadly there is no way to get rid of the error messages without a tiny change
                                            when u install a module using npm you can ‘omit’ installing the development stuff… BUT, it STILL goes thru all the WORK to check them out (I don’t know why this is stupid)
                                            anyhow, the ONLY fix is to trick the installer to not FIND any dev dependencies…
                                            edit package.json
                                            and change this
                                            "devDependencies": {
                                            to this
                                            "devDependencies1": {
                                            notice I added the ‘1’ at the end… when npm install runs it will look for “devDependencies”
                                            and not find it… and skip all the junk (You are not going to be developing on the module anyhow…so no loss and the stuff eliminated is formatting tools anyhow)
                                            now, that said,
                                            I installed the module
                                            copied the default config entry from the readme
                                            fixed the text typo (missing trailing comma)
                                            added my apikey from google dev console and
                                            worked like a champ…
                                            i did this on two separate systems
                                            my linux desktop
                                            and a pi4 w 7in screen
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 11 / 13
