    MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast
    259 Posts 55 Posters 719.9k Views 57 Watching
      chris1971 @sdetweil
      @sdetweil still not loading…
      magicmirror@2.22.0 start
      [31.03.2023 16:29.04.053] [LOG] Starting MagicMirror: v2.22.0
      [31.03.2023 16:29.04.077] [LOG] Loading config …
      [31.03.2023 16:29.04.113] [LOG] Loading module helpers …
      [31.03.2023 16:29.04.120] [LOG] No helper found for module: alert.
      [31.03.2023 16:29.04.191] [LOG] Initializing new module helper …
      [31.03.2023 16:29.04.194] [LOG] Module helper loaded: updatenotification
      [31.03.2023 16:29.04.196] [LOG] No helper found for module: clock.
      [31.03.2023 16:29.04.591] [LOG] Initializing new module helper …
      [31.03.2023 16:29.04.592] [LOG] Module helper loaded: MMM-OpenWeatherForecast
      [31.03.2023 16:29.05.736] [LOG] Initializing new module helper …
      [31.03.2023 16:29.05.740] [LOG] Module helper loaded: calendar
      [31.03.2023 16:29.05.754] [LOG] No helper found for module: MMM-TextClock.
      [31.03.2023 16:29.06.143] [LOG] Initializing new module helper …
      [31.03.2023 16:29.06.150] [LOG] Module helper loaded: newsfeed
      [31.03.2023 16:29.06.155] [LOG] No helper found for module: MMM-RAIN-MAP.
      [31.03.2023 16:29.06.170] [LOG] Initializing new module helper …
      [31.03.2023 16:29.06.172] [LOG] Module helper loaded: MMM-GoogleMapsTraffic
      [31.03.2023 16:29.06.173] [LOG] All module helpers loaded.
      [31.03.2023 16:29.06.803] [LOG] Starting server on port 8080 …
      [31.03.2023 16:29.06.828] [WARN] You’re using a full whitelist configuration to allow for all IPs
      [31.03.2023 16:29.06.884] [ERROR] Whoops! There was an uncaught exception…
      [31.03.2023 16:29.06.900] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
      at Server.setupListenHandle [as _listen2] (node:net:1432:16)
      at listenInCluster (node:net:1480:12)
      at doListen (node:net:1629:7)
      at process.processTicksAndRejections (node:internal/process/task_queues:84:21) {
      code: ‘EADDRINUSE’,
      errno: -98,
      syscall: ‘listen’,
      address: ‘0.0.0.0’,
      port: 8080
      [31.03.2023 16:29.06.901] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [31.03.2023 16:29.06.902] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      [31.03.2023 16:29.08.680] [LOG] Launching application.
      MESA-LOADER: failed to retrieve device information
      …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[2071:0331/162912.978009:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=6
      …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[2071:0331/162914.498526:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=6
      …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[2071:0331/162915.779583:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=6
      [31.03.2023 16:29.37.588] [LOG] Shutting down server…
      [31.03.2023 16:29.37.595] [LOG] Stopping module helper: updatenotification
      [31.03.2023 16:29.37.596] [LOG] Stopping module helper: MMM-OpenWeatherForecast
      [31.03.2023 16:29.37.596] [LOG] Stopping module helper: calendar
      [31.03.2023 16:29.37.597] [LOG] Stopping module helper: newsfeed
      [31.03.2023 16:29.37.597] [LOG] Stopping module helper: MMM-GoogleMapsTraffic
        sdetweil @chris1971
        @chris1971 said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
        did u do the pm2 stop all?
        did you use any install instructions before my script? the manual install describes how to create a service to auto start MM
        C 1 Reply Last reply
          chris1971 @sdetweil
          yes - ich changed the mm.sh after stop all
          my method for installation:
          • format SD card
          • install Bullseye
          • install sudo apt-get install xrdp (to get a remote connection via remote desktop)
          • install your scripts including screensaver/ pm2
          • install the modules
            it worked once … I do not understand what changed after a restart…
            sdetweil @chris1971
            @chris1971 and u checked the pm2 status
            before doing npm start ?
            you don’t reboot after pm2 stop all, as t will restart MM on boot (its job)
              chris1971 @sdetweil
              @sdetweil this is the pm2 status
              pi@raspberrypi:~/MagicMirror $ pm2 status
              │ id │ name │ mode │ ↺ │ status │ cpu │ memory │
              │ 0 │ MagicMirror │ fork │ 0 │ online │ 0% │ 2.3mb │
              with npm start I only have a black screen in the terminal - I can see the conten in the browser with http://192.168.178.35:8080/
              S 3 Replies Last reply
                sdetweil @chris1971
                @chris1971 pm2 stop all
                then cd ~/MagicMirror
                npm start
                only can have ONE instance running at a time on the same config.js port: setting
                  sdetweil @chris1971
                  @chris1971 yes, you have another instance running , so this one will fail
                    sdetweil @chris1971
                    you are looking at the one running under pm2
                      chris1971 @sdetweil
                      sdetweil 5 minutes ago
                      npm start
                      ahhh… ok: with this I am able to see the scree in the terminal - but the weather module is still not loading in the terminal
                      Errors like before:
                      [31.03.2023 17:19.15.233] [LOG] Launching application.
                      …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[2465:0331/171918.392802:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=6
                      …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[2465:0331/171919.478457:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=6
                      …/…/buildtools/third_party/libc++/trunk/include/vector:1425: assertion __n < size() failed: vector[] index out of bounds[2465:0331/171920.679631:ERROR:gpu_process_host.cc(991)] GPU process exited unexpectedly: exit_code=6
                      [2509:0331/171921.424506:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
                      [31.03.2023 17:19.25.235] [LOG] Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/c.euro%40gmx.de/private-8dd63e4cddfec3349/basic.ics - Interval: 50000
                      [31.03.2023 17:19.25.774] [LOG] Create new newsfetcher for url: http://www.radiomuelheim.de/lokalnachrichten.xml - Interval: 300000
                      [31.03.2023 17:19.25.793] [LOG] Create new newsfetcher for url: http://www.tagesschau.de/xml/rss2 - Interval: 300000
                      [31.03.2023 17:19.25.813] [LOG] Working notification system. Notification: MMM-GOOGLE_MAPS_TRAFFIC-GET payload: { style: ‘standard’ }
                      have to go out for a beer now…:dizzy_face:
                        sdetweil @chris1971
                        @chris1971 u have to enter the
                        export ELECTRON_DISABLE_GPU=1
                        EVERY time you open a new terminal window
                        so, then i’d look in the MM screen developers window as previously described
                          chris1971 @sdetweil
                          @sdetweil I placed the “export ELECTRON_DISABLE_GPU=1” in the install.
                          Where do I have to place the “export ELECTRON_DISABLE_GPU=1” in the terminal window?
                          Info from console (red):
                          >Uncaught TypeError: Cannot read properties of undefined (reading ‘length’)
                          at script.onload (MMM-GoogleMapsTraffic.js:77:52)
                          MMM-OpenWeatherForecast.js:685 Uncaught (in promise) TypeError: console.log is not a function
                          at Class.addIcon (MMM-OpenWeatherForecast.js:685:13)
                          at Class.processWeatherData (MMM-OpenWeatherForecast.js:370:61)
                          at Class.socketNotificationReceived (MMM-OpenWeatherForecast.js:282:40)
                          at module.js:245:9
                          at Socket. (socketclient.js:38:4)
                          at Emitter.emit (index.mjs:136:20)
                          at Socket.emitEvent (socket.js:498:20)
                          at Socket.onevent (socket.js:485:18)
                          at MMSocket.socket.onevent (socketclient.js:32:11)
                          at Socket.onpacket (socket.js:455:22)
                          js?key=cccc:221 You have included the Google Maps JavaScript API multiple times on this page. This may cause unexpected errors.
                          js?key=uuuuu:217 Google Maps JavaScript API has been loaded directly without a callback. This is not supported and can lead to race conditions and suboptimal performance. For supported loading patterns please see https://goo.gle/js-api-loading
                          MMM-GoogleMapsTraffic.js:77 Uncaught TypeError: Cannot read properties of undefined (reading ‘length’)
                          S 2 Replies Last reply
                            sdetweil @chris1971
                            you just enter that command string and hit enter
                              sdetweil @chris1971
                              I haven’t seen that one before
                              I xxx’ed out your api key in the debug info
                                chris1971 @sdetweil
                                @sdetweil thanks for xxx
                                What is your recommendation? Delete maps and new install?
                                Can you explain why I see the MM in the terminal correct, if I stop all and start npm? Is ist possible to delete PM2?
                                  sdetweil @chris1971
                                  @chris1971 delete pm2, sure, see the
                                  pm2 --help
                                  output
                                  no idea why u are having trouble
                                  try this
                                  instead of npm start
                                  do
                                  npm run server
                                  then access from the remote and see what happens
                                    chris1971 @sdetweil
                                    npm run server - no success
                                    I deleted pm2 - then I was able to start MM from the console without black screen with npm start. But then MM didn’t start on the mirror.
                                    Maybe I will setup a new system tomorrow … thanks for your input until now - cheers
                                      sdetweil @chris1971
                                      @chris1971 hm… are you trying to display mm on multiple monitors at once?
                                      if so
                                      this is built in function
                                      edit the config.js to allow access from outside the mm machine
                                      address:'0.0.0.0'
                                      ipWhitelist:[],
                                      then on the mm machine, in a terminal window, do
                                      ip addr
                                      and remember that value
                                      then
                                      npm start
                                      then on your other machine, use a browser
                                      (Chrome, Edge, Firefox, Midori, Safari)
                                      and open http://ip_address_from_above:8080
                                        chris1971 @sdetweil
                                        Short summary: I installed MM new with your script - I agreed to the installation of pm2 and disable screensaver. To get a connection to my WIN 10 via remote desktop computer I need to install sudo apt-get install xrdp. Without this installation I’m not able to start the remote desktop connetcion - Only via putty.
                                        After the installation I am not able to run npm start without getting a black screen. I have to pm2 stop all - then npm start again and I see the MM screen on my computer to update the modules, config, etc.
                                        This is what we have seen before:
                                        [31.03.2023 14:13.31.869] [LOG] Starting server on port 8080 …
                                        [31.03.2023 14:13.31.892] [WARN] You’re using a full whitelist configuration to allow for all IPs
                                        [31.03.2023 14:13.31.940] [ERROR] Whoops! There was an uncaught exception…
                                        [31.03.2023 14:13.31.961] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                                        code: ‘EADDRINUSE’,
                                        errno: -98,
                                        syscall: ‘listen’,
                                        address: ‘0.0.0.0’,
                                        port: 8080
                                        With this error MM is running on the Mirror screen without problems.
                                        When I install MMM-GoogleMapsTraffic I get following message:
                                        npm ERR! code ERESOLVE
                                        npm ERR! ERESOLVE could not resolve
                                        npm ERR!
                                        npm ERR! While resolving: MMM-GoogleMapsTraffic@1.0.0
                                        npm ERR! Found: stylelint@14.16.1
                                        npm ERR! node_modules/stylelint
                                        npm ERR! peer stylelint@“14.x” from grunt-stylelint@0.18.0
                                        npm ERR! node_modules/grunt-stylelint
                                        npm ERR! dev grunt-stylelint@“latest” from the root project
                                        npm ERR!
                                        npm ERR! Could not resolve dependency:
                                        npm ERR! dev stylelint-config-standard@“latest” from the root project
                                        npm ERR!
                                        npm ERR! Conflicting peer dependency: stylelint@15.4.0
                                        npm ERR! peer stylelint@“^15.4.0” from stylelint-config-standard@32.0.0
                                        npm ERR! node_modules/stylelint-config-standard
                                        npm ERR!
                                        npm ERR! Fix the upstream dependency conflict, or retry
                                        npm ERR! this command with --force, or --legacy-peer-deps
                                        npm ERR! to accept an incorrect (and potentially broken) dependency resolution.
                                        npm ERR!
                                        npm ERR! See /home/pi/.npm/eresolve-report.txt for a full report.
                                        npm ERR! /home/pi/.npm/_logs/2023-04-01T11_07_55_012Z-debug-0.log
                                        After installation of MMM-GoogleMapsTraffic the Openweather is not loading anymore.
                                          sdetweil @chris1971
                                          @chris1971 we have two different problems going on.
                                          1. when u start MagicMirror, it will display on the monitor attached to the system. NOT any remote console.
                                            it IS a mirror on the wall after all
                                          IF you want to show the mirror screen on a remote system, phone, laptop, tablet, desktop
                                          then you use a browser on that other device to show the mm screen from it’s server on the mirror system.
                                          you do not start another running copy of MagicMirror . you do not need rdp to do this.
                                          just a browser.
                                          IF you want to display MagicMirror over your rdp session, then you would open a browser thru the rdp session and use the url
                                          http://localhost:8080
                                          as rdp makes it like you are at the local desktop
                                          I’ll look at the Googlemapstraffic problem
                                            chris1971 @sdetweil
                                            @sdetweil many thanks - but I have to install/ modify the Mirror from my computer. That’s the reason why I would like to connect via WIFI and get easy access to the modules/ config, etc.
                                            With Putty I only have access to the terminal - not to the PI Explorer…
                                            Your recommendation is not to install sudo apt-get install xrdp - it seems that this install mekes the trouble with 2 systems…
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 11 / 13
