    MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast
    259 Posts 55 Posters 719.9k Views 57 Watching
      sdetweil @chris1971
      @chris1971 u have to enter the
      export ELECTRON_DISABLE_GPU=1
      EVERY time you open a new terminal window
      so, then i’d look in the MM screen developers window as previously described
      C 1 Reply Last reply
        chris1971 @sdetweil
        @sdetweil I placed the “export ELECTRON_DISABLE_GPU=1” in the install.
        Where do I have to place the “export ELECTRON_DISABLE_GPU=1” in the terminal window?
        Info from console (red):
        >Uncaught TypeError: Cannot read properties of undefined (reading ‘length’)
        at script.onload (MMM-GoogleMapsTraffic.js:77:52)
        MMM-OpenWeatherForecast.js:685 Uncaught (in promise) TypeError: console.log is not a function
        at Class.addIcon (MMM-OpenWeatherForecast.js:685:13)
        at Class.processWeatherData (MMM-OpenWeatherForecast.js:370:61)
        at Class.socketNotificationReceived (MMM-OpenWeatherForecast.js:282:40)
        at module.js:245:9
        at Socket. (socketclient.js:38:4)
        at Emitter.emit (index.mjs:136:20)
        at Socket.emitEvent (socket.js:498:20)
        at Socket.onevent (socket.js:485:18)
        at MMSocket.socket.onevent (socketclient.js:32:11)
        at Socket.onpacket (socket.js:455:22)
        js?key=cccc:221 You have included the Google Maps JavaScript API multiple times on this page. This may cause unexpected errors.
        js?key=uuuuu:217 Google Maps JavaScript API has been loaded directly without a callback. This is not supported and can lead to race conditions and suboptimal performance. For supported loading patterns please see https://goo.gle/js-api-loading
        MMM-GoogleMapsTraffic.js:77 Uncaught TypeError: Cannot read properties of undefined (reading ‘length’)
        S 2 Replies Last reply
          sdetweil @chris1971
          @chris1971 said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
          you just enter that command string and hit enter
            sdetweil @chris1971
            I haven’t seen that one before
            I xxx’ed out your api key in the debug info
              chris1971 @sdetweil
              @sdetweil thanks for xxx
              What is your recommendation? Delete maps and new install?
              Can you explain why I see the MM in the terminal correct, if I stop all and start npm? Is ist possible to delete PM2?
                sdetweil @chris1971
                @chris1971 delete pm2, sure, see the
                pm2 --help
                output
                no idea why u are having trouble
                try this
                instead of npm start
                do
                npm run server
                then access from the remote and see what happens
                  chris1971 @sdetweil
                  npm run server - no success
                  I deleted pm2 - then I was able to start MM from the console without black screen with npm start. But then MM didn’t start on the mirror.
                  Maybe I will setup a new system tomorrow … thanks for your input until now - cheers
                    sdetweil @chris1971
                    @chris1971 hm… are you trying to display mm on multiple monitors at once?
                    if so
                    this is built in function
                    edit the config.js to allow access from outside the mm machine
                    address:'0.0.0.0'
                    ipWhitelist:[],
                    then on the mm machine, in a terminal window, do
                    ip addr
                    and remember that value
                    then
                    npm start
                    then on your other machine, use a browser
                    (Chrome, Edge, Firefox, Midori, Safari)
                    and open http://ip_address_from_above:8080
                      chris1971 @sdetweil
                      Short summary: I installed MM new with your script - I agreed to the installation of pm2 and disable screensaver. To get a connection to my WIN 10 via remote desktop computer I need to install sudo apt-get install xrdp. Without this installation I’m not able to start the remote desktop connetcion - Only via putty.
                      After the installation I am not able to run npm start without getting a black screen. I have to pm2 stop all - then npm start again and I see the MM screen on my computer to update the modules, config, etc.
                      This is what we have seen before:
                      [31.03.2023 14:13.31.869] [LOG] Starting server on port 8080 …
                      [31.03.2023 14:13.31.892] [WARN] You’re using a full whitelist configuration to allow for all IPs
                      [31.03.2023 14:13.31.940] [ERROR] Whoops! There was an uncaught exception…
                      [31.03.2023 14:13.31.961] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
                      at Server.setupListenHandle [as _listen2] (node:net:1432:16)
                      at listenInCluster (node:net:1480:12)
                      at doListen (node:net:1629:7)
                      at process.processTicksAndRejections (node:internal/process/task_queues:84:21) {
                      code: ‘EADDRINUSE’,
                      errno: -98,
                      syscall: ‘listen’,
                      address: ‘0.0.0.0’,
                      port: 8080
                      With this error MM is running on the Mirror screen without problems.
                      When I install MMM-GoogleMapsTraffic I get following message:
                      npm ERR! code ERESOLVE
                      npm ERR! ERESOLVE could not resolve
                      npm ERR!
                      npm ERR! While resolving: MMM-GoogleMapsTraffic@1.0.0
                      npm ERR! Found: stylelint@14.16.1
                      npm ERR! node_modules/stylelint
                      npm ERR! peer stylelint@“14.x” from grunt-stylelint@0.18.0
                      npm ERR! node_modules/grunt-stylelint
                      npm ERR! dev grunt-stylelint@“latest” from the root project
                      npm ERR!
                      npm ERR! Could not resolve dependency:
                      npm ERR! dev stylelint-config-standard@“latest” from the root project
                      npm ERR!
                      npm ERR! Conflicting peer dependency: stylelint@15.4.0
                      npm ERR! peer stylelint@“^15.4.0” from stylelint-config-standard@32.0.0
                      npm ERR! node_modules/stylelint-config-standard
                      npm ERR!
                      npm ERR! Fix the upstream dependency conflict, or retry
                      npm ERR! this command with --force, or --legacy-peer-deps
                      npm ERR! to accept an incorrect (and potentially broken) dependency resolution.
                      npm ERR!
                      npm ERR! See /home/pi/.npm/eresolve-report.txt for a full report.
                      npm ERR! /home/pi/.npm/_logs/2023-04-01T11_07_55_012Z-debug-0.log
                      After installation of MMM-GoogleMapsTraffic the Openweather is not loading anymore.
                        sdetweil @chris1971
                        @chris1971 we have two different problems going on.
                        1. when u start MagicMirror, it will display on the monitor attached to the system. NOT any remote console.
                          it IS a mirror on the wall after all
                        IF you want to show the mirror screen on a remote system, phone, laptop, tablet, desktop
                        then you use a browser on that other device to show the mm screen from it’s server on the mirror system.
                        you do not start another running copy of MagicMirror . you do not need rdp to do this.
                        just a browser.
                        IF you want to display MagicMirror over your rdp session, then you would open a browser thru the rdp session and use the url
                        http://localhost:8080
                        as rdp makes it like you are at the local desktop
                        I’ll look at the Googlemapstraffic problem
                          chris1971 @sdetweil
                          @sdetweil many thanks - but I have to install/ modify the Mirror from my computer. That’s the reason why I would like to connect via WIFI and get easy access to the modules/ config, etc.
                          With Putty I only have access to the terminal - not to the PI Explorer…
                          Your recommendation is not to install sudo apt-get install xrdp - it seems that this install mekes the trouble with 2 systems…
                            sdetweil @chris1971
                            @chris1971 yes, rdp is fine to access the console.
                            but from the remote system u just use a browser to see the mm contents
                            same as if you used putty to edit the config.js
                            try it. that is the whole point of pm2, start the mirror/web server without user intervention
                            as u have removed pm2, use putty to logon and npm start. , then disconnect putty
                            now use your browser on windows to access the mm web server BEFORE STARTING rdp, using the same IP address as you used for putty
                            and port 8080 (the port number in mm config.js)
                            if u make a change and restart mm. then hit refresh on the browser page
                              chris1971 @sdetweil
                              @sdetweil Thanks for your support - a solution for the maps issue would be really nice!!!
                              The 1st topic with the remote desktop is my minor challenge
                                sdetweil @chris1971
                                @chris1971 so looking at MMM-GoogleMapsTraffic , it uses very old stuff (5 years) in its dev dependencies section of package.json
                                sadly there is no way to get rid of the error messages without a tiny change
                                when u install a module using npm you can ‘omit’ installing the development stuff… BUT, it STILL goes thru all the WORK to check them out (I don’t know why this is stupid)
                                anyhow, the ONLY fix is to trick the installer to not FIND any dev dependencies…
                                edit package.json
                                and change this
                                "devDependencies": {
                                to this
                                "devDependencies1": {
                                notice I added the ‘1’ at the end… when npm install runs it will look for “devDependencies”
                                and not find it… and skip all the junk (You are not going to be developing on the module anyhow…so no loss and the stuff eliminated is formatting tools anyhow)
                                now, that said,
                                I installed the module
                                copied the default config entry from the readme
                                fixed the text typo (missing trailing comma)
                                added my apikey from google dev console and
                                worked like a champ…
                                i did this on two separate systems
                                my linux desktop
                                and a pi4 w 7in screen
                                  sdetweil @chris1971
                                  @chris1971 you can also use Winscp or bitvise ssh clients
                                  these give you an ssh terminal AND a file browser over the PI files…just click and double click,
                                  I use notepad++ on my windows system to edit the config and css files.
                                  and the ssh terminal to install mm and modules (where to run commands)
                                  and start/restart via pm2 or npm start
                                    chris1971 @sdetweil
                                    @sdetweil Thanks for this outstanding support!!!
                                    I learned o lot - I have installed the MM some years ago and was a little bit concerned if I can do this again…
                                    Now the best: The MM is running with Openweather and Goggle Maps - I tried several times install/ deinstall and found your modified script for Maps - maybe this was a solution at the end. I still see some errors in the strting script - but MM is running now with the weather module after shutdown the Darksky service - this was the only reason for me to change the system again…
                                    Thanks again!!!
                                      sdetweil @chris1971
                                      @chris1971 glad you got it running
                                      • E
                                        Egnos
                                        Hello there!
                                        Unfortunatly It’s arrived the moment: “… on March 31st, 2023 the Dark Sky API will no longer be available.”, as recalled by the Dark Sky Team in this post: Infos from the Dark Sky Team
                                        In fact today morning MMM-DarkSkyForecast stopped working!
                                        I tried to install its replacement MMM-OpenWeatherForecast, but it didn’t work!
                                        On terminal i hve this error:
                                        [MMM-OpenWeatherForecast] 2-Apr-23 17:23 ** ERROR ** Error: Request failed with status code 401
                                        I have already try to regen the API key on OpenWeatherMap site but the problem persist.
                                        I’m using MagicMirror: v2.22.0
                                        For now i’m using the simple configuration:
                                            module: "MMM-OpenWeatherForecast",
                                            header: "Forecast",
                                              apikey: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx", //only string here
                                              latitude: 45.072870,            //number works here
                                              longitude: 7.558791          //so does a string
                                        Has anyone had this problem before?
                                        Can you help me?
                                        Thanks.
                                          sdetweil @Egnos
                                          @Egnos see https://github.com/jclarke0000/MMM-OpenWeatherForecast/issues/23
                                          new openweather api version is 3.0, code is hard coded to 2.5
                                          E 1 Reply Last reply
                                          • E
                                            Egnos @sdetweil
                                            Hi @sdetweil thanks for answering me!
                                            I had read this post but I didn’t understand what I have to do.
                                            I have to update the node_helper.js version 2.5 to 3.0?
                                            Can you help me?
                                            Thanks.
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 12 / 13
