    MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast
    259 Posts 55 Posters 719.9k Views 57 Watching
      chris1971 @sdetweil
      @sdetweil thanks for xxx
      What is your recommendation? Delete maps and new install?
      Can you explain why I see the MM in the terminal correct, if I stop all and start npm? Is ist possible to delete PM2?
        sdetweil @chris1971
        @chris1971 delete pm2, sure, see the
        pm2 --help
        output
        no idea why u are having trouble
        try this
        instead of npm start
        do
        npm run server
        then access from the remote and see what happens
        C 1 Reply Last reply
          chris1971 @sdetweil
          npm run server - no success
          I deleted pm2 - then I was able to start MM from the console without black screen with npm start. But then MM didn’t start on the mirror.
          Maybe I will setup a new system tomorrow … thanks for your input until now - cheers
            sdetweil @chris1971
            @chris1971 hm… are you trying to display mm on multiple monitors at once?
            if so
            this is built in function
            edit the config.js to allow access from outside the mm machine
            address:'0.0.0.0'
            ipWhitelist:[],
            then on the mm machine, in a terminal window, do
            ip addr
            and remember that value
            then
            npm start
            then on your other machine, use a browser
            (Chrome, Edge, Firefox, Midori, Safari)
            and open http://ip_address_from_above:8080
              chris1971 @sdetweil
              Short summary: I installed MM new with your script - I agreed to the installation of pm2 and disable screensaver. To get a connection to my WIN 10 via remote desktop computer I need to install sudo apt-get install xrdp. Without this installation I’m not able to start the remote desktop connetcion - Only via putty.
              After the installation I am not able to run npm start without getting a black screen. I have to pm2 stop all - then npm start again and I see the MM screen on my computer to update the modules, config, etc.
              This is what we have seen before:
              [31.03.2023 14:13.31.869] [LOG] Starting server on port 8080 …
              [31.03.2023 14:13.31.892] [WARN] You’re using a full whitelist configuration to allow for all IPs
              [31.03.2023 14:13.31.940] [ERROR] Whoops! There was an uncaught exception…
              [31.03.2023 14:13.31.961] [ERROR] Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
              at Server.setupListenHandle [as _listen2] (node:net:1432:16)
              at listenInCluster (node:net:1480:12)
              at doListen (node:net:1629:7)
              at process.processTicksAndRejections (node:internal/process/task_queues:84:21) {
              code: ‘EADDRINUSE’,
              errno: -98,
              syscall: ‘listen’,
              address: ‘0.0.0.0’,
              port: 8080
              With this error MM is running on the Mirror screen without problems.
              When I install MMM-GoogleMapsTraffic I get following message:
              npm ERR! code ERESOLVE
              npm ERR! ERESOLVE could not resolve
              npm ERR!
              npm ERR! While resolving: MMM-GoogleMapsTraffic@1.0.0
              npm ERR! Found: stylelint@14.16.1
              npm ERR! node_modules/stylelint
              npm ERR! peer stylelint@“14.x” from grunt-stylelint@0.18.0
              npm ERR! node_modules/grunt-stylelint
              npm ERR! dev grunt-stylelint@“latest” from the root project
              npm ERR!
              npm ERR! Could not resolve dependency:
              npm ERR! dev stylelint-config-standard@“latest” from the root project
              npm ERR!
              npm ERR! Conflicting peer dependency: stylelint@15.4.0
              npm ERR! peer stylelint@“^15.4.0” from stylelint-config-standard@32.0.0
              npm ERR! node_modules/stylelint-config-standard
              npm ERR!
              npm ERR! Fix the upstream dependency conflict, or retry
              npm ERR! this command with --force, or --legacy-peer-deps
              npm ERR! to accept an incorrect (and potentially broken) dependency resolution.
              npm ERR!
              npm ERR! See /home/pi/.npm/eresolve-report.txt for a full report.
              npm ERR! /home/pi/.npm/_logs/2023-04-01T11_07_55_012Z-debug-0.log
              After installation of MMM-GoogleMapsTraffic the Openweather is not loading anymore.
                sdetweil @chris1971
                @chris1971 we have two different problems going on.
                1. when u start MagicMirror, it will display on the monitor attached to the system. NOT any remote console.
                  it IS a mirror on the wall after all
                IF you want to show the mirror screen on a remote system, phone, laptop, tablet, desktop
                then you use a browser on that other device to show the mm screen from it’s server on the mirror system.
                you do not start another running copy of MagicMirror . you do not need rdp to do this.
                just a browser.
                IF you want to display MagicMirror over your rdp session, then you would open a browser thru the rdp session and use the url
                http://localhost:8080
                as rdp makes it like you are at the local desktop
                I’ll look at the Googlemapstraffic problem
                  chris1971 @sdetweil
                  @sdetweil many thanks - but I have to install/ modify the Mirror from my computer. That’s the reason why I would like to connect via WIFI and get easy access to the modules/ config, etc.
                  With Putty I only have access to the terminal - not to the PI Explorer…
                  Your recommendation is not to install sudo apt-get install xrdp - it seems that this install mekes the trouble with 2 systems…
                  S 2 Replies Last reply
                    sdetweil @chris1971
                    @chris1971 yes, rdp is fine to access the console.
                    but from the remote system u just use a browser to see the mm contents
                    same as if you used putty to edit the config.js
                    try it. that is the whole point of pm2, start the mirror/web server without user intervention
                    as u have removed pm2, use putty to logon and npm start. , then disconnect putty
                    now use your browser on windows to access the mm web server BEFORE STARTING rdp, using the same IP address as you used for putty
                    and port 8080 (the port number in mm config.js)
                    if u make a change and restart mm. then hit refresh on the browser page
                      chris1971 @sdetweil
                      @sdetweil Thanks for your support - a solution for the maps issue would be really nice!!!
                      The 1st topic with the remote desktop is my minor challenge
                        sdetweil @chris1971
                        @chris1971 so looking at MMM-GoogleMapsTraffic , it uses very old stuff (5 years) in its dev dependencies section of package.json
                        sadly there is no way to get rid of the error messages without a tiny change
                        when u install a module using npm you can ‘omit’ installing the development stuff… BUT, it STILL goes thru all the WORK to check them out (I don’t know why this is stupid)
                        anyhow, the ONLY fix is to trick the installer to not FIND any dev dependencies…
                        edit package.json
                        and change this
                        "devDependencies": {
                        to this
                        "devDependencies1": {
                        notice I added the ‘1’ at the end… when npm install runs it will look for “devDependencies”
                        and not find it… and skip all the junk (You are not going to be developing on the module anyhow…so no loss and the stuff eliminated is formatting tools anyhow)
                        now, that said,
                        I installed the module
                        copied the default config entry from the readme
                        fixed the text typo (missing trailing comma)
                        added my apikey from google dev console and
                        worked like a champ…
                        i did this on two separate systems
                        my linux desktop
                        and a pi4 w 7in screen
                          sdetweil @chris1971
                          @chris1971 you can also use Winscp or bitvise ssh clients
                          these give you an ssh terminal AND a file browser over the PI files…just click and double click,
                          I use notepad++ on my windows system to edit the config and css files.
                          and the ssh terminal to install mm and modules (where to run commands)
                          and start/restart via pm2 or npm start
                            chris1971 @sdetweil
                            @sdetweil Thanks for this outstanding support!!!
                            I learned o lot - I have installed the MM some years ago and was a little bit concerned if I can do this again…
                            Now the best: The MM is running with Openweather and Goggle Maps - I tried several times install/ deinstall and found your modified script for Maps - maybe this was a solution at the end. I still see some errors in the strting script - but MM is running now with the weather module after shutdown the Darksky service - this was the only reason for me to change the system again…
                            Thanks again!!!
                              sdetweil @chris1971
                              @chris1971 glad you got it running
                              • E
                                Egnos
                                Hello there!
                                Unfortunatly It’s arrived the moment: “… on March 31st, 2023 the Dark Sky API will no longer be available.”, as recalled by the Dark Sky Team in this post: Infos from the Dark Sky Team
                                In fact today morning MMM-DarkSkyForecast stopped working!
                                I tried to install its replacement MMM-OpenWeatherForecast, but it didn’t work!
                                On terminal i hve this error:
                                [MMM-OpenWeatherForecast] 2-Apr-23 17:23 ** ERROR ** Error: Request failed with status code 401
                                I have already try to regen the API key on OpenWeatherMap site but the problem persist.
                                I’m using MagicMirror: v2.22.0
                                For now i’m using the simple configuration:
                                    module: "MMM-OpenWeatherForecast",
                                    header: "Forecast",
                                      apikey: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx", //only string here
                                      latitude: 45.072870,            //number works here
                                      longitude: 7.558791          //so does a string
                                Has anyone had this problem before?
                                Can you help me?
                                Thanks.
                                  sdetweil @Egnos
                                  @Egnos see https://github.com/jclarke0000/MMM-OpenWeatherForecast/issues/23
                                  new openweather api version is 3.0, code is hard coded to 2.5
                                  E 1 Reply Last reply
                                  • E
                                    Egnos @sdetweil
                                    Hi @sdetweil thanks for answering me!
                                    I had read this post but I didn’t understand what I have to do.
                                    I have to update the node_helper.js version 2.5 to 3.0?
                                    Can you help me?
                                    Thanks.
                                      sdetweil @Egnos
                                      @Egnos yes,
                                      just edit the file and change 2.5 to 3.0
                                      • E
                                        Egnos @sdetweil
                                        @sdetweil said in MMM-OpenWeatherForecast - Replacement for MMM-DarkSkyForecast:
                                        edit the file an
                                        In the file “node_helper.js” I have modify:
                                        this https://api.openweathermap.org/data/2.5/onecall?
                                        with this https://api.openweathermap.org/data/3.0/onecall?
                                        but I have the same error:
                                        [02.04.2023 17:58.05.910] [LOG]   [MMM-OpenWeatherForecast] 2-Apr-23 17:58 ** ERROR ** Error: Request failed with status code 401
                                        Where am I doing wrong?
                                          sdetweil @Egnos
                                          @Egnos i’ve seen a number of these…
                                          something to do with registering correctly with version 3 onecall
                                          someone else said
                                          I used the API keys from the website as the one sent in my email did not work.
                                          • E
                                            Egnos @sdetweil
                                            @sdetweil I’ve already gone to the OpenWeatherMap site, I’ve regenerated a new API key but still the error…
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 12 / 13
