    MMM-WeatherGraph - new module using OpenWeatherMap
    15 Posts 6 Posters 10.6k Views 7 Watching
    • N
      nixdg
      Im new and just setting up my first MM and found your module. I get accurate info with the stock module, but get a constant Loading Weather when I have your module in place. Any thoughts as to why it is not loading?
        JoeFranz
        Same here, still loading…
          sdetweil @nixdg
          @nixdg @JoeFranz ‘Loading…’, is the default message put up while waiting for data…
          in my opinon, modules SHOULD (but don’t) report errors to the user instead of leaving the Loading… message up
          so, the data api calls have failed for some reason…
          this module does all its work in the browser so, lets look in the developer window console for any clues
          ctrl-shift-i,
          select the console tab
          and put some unique part of the module name in the filter field
          weatherg
          and report what you see
            JoeFranz
            Nothing changed and now it works :-)
            Maybe it took a while for the API key to work
              sdetweil @JoeFranz
              @JoeFranz there are call limits… 100 /day I think…
              • FlatPepsiF
                FlatPepsi @FlatPepsi
                @FlatPepsi So I finally added an option I wanted, but never got around to doing. I originally wanted this module to let me know if I needed to get up early and shovel the driveway… which means I want daily precipitation totals handy.
                Now it’s available as an option!
                The latest code can be found on GitHub. Let me know if you find any bugs. Precipitation totals use inches or mm/cm, following the existing Imperial/Metric setting.
                Enjoy!
                https://github.com/FlatPepsi17/MMM-WeatherGraph
                S FlatPepsiF 2 Replies Last reply
                  sdetweil @FlatPepsi
                  @FlatPepsi very cool!
                  • FlatPepsiF
                    Pushed out a fix today…
                    Most weather sources give snow in the liquid equivalent, thus you need to multiply by 10 for snow.
                    Turns out OpenWeather does this math for us, and I was over estimating the snow by a factor of 10. Today I’m expecting 1.6" of snow & ice, module was saying 16" - prompting today’s fix!
                    Fixed.
                    • MarosM
                      Maros
                      Hi, great module. Is it possible to change the white between temperatures to f.e. “/” ?
                      also is it possible to add “C” to temperature ? so it will show °C
                        bbbeat
                        I’m getting an error, could not load datan TypeError: forecast is not iterable.
                        Do you know what might be wrong?
                        I checked and the API key is valid
