    How to add modules. For absolute beginners.
    91 Posts 16 Posters 166.6k Views 24 Watching
    • F
      fsne04 @sdetweil
      No worries, at least I know how to find errors now, Thanks! I guess I also have an issue with the weathermap setup, according to the error message below the screencast one.
        sdetweil @fsne04
        @fsne04 weather u need to sign up and get an api token just for you…
        F 1 Reply Last reply
        • F
          fsne04 @sdetweil
          I did, maybe I did not copy it correctly. I will check.
          So how do I start a new topic/question and get nice/helpful people like you to answer? I have a few questions on the Remote Control module configuration also.
            sdetweil @fsne04
            @fsne04 see https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners/73?page=8
            • F
              fsne04 @sdetweil
              In the headder, I see: Unread, Recent, Tags, Unsolved, Solved, Users, Groups, Repository, Documents, Donate, Join Channel… I am sure it’s there, but I don’t see a New Topic, or create Topic button.
              Thank you for your help today, Sam! Greatly appreciate your time.
              Best regards,
              Frank
                sdetweil @fsne04
                @fsne04 when I push unread, I see
                • A
                  ashishtank Module Developer @fsne04
                  @fsne04 if you check the code of MMM-Screent cast @ https://github.com/kevinatown/MMM-Screencast/blob/master/constants.js then there is no position which supports fullscreen_below.
                  you need to set one of the below value as per documentation of the module
                  const POSITIONS = {
                    bottomRight: 'bottomRight',
                    bottomCenter: 'bottomCenter',
                    bottomLeft: 'bottomLeft',
                    center: 'center',
                    topRight: 'topRight',
                    topCenter: 'topCenter',
                    topLeft: 'topLeft',
                    top_bar: 'topRight',
                    top_left: 'topLeft',
                    top_center: 'topCenter',
                    top_right: 'topRight',
                    upper_third: 'topRight',
                    middle_center: 'center',
                    lower_third: 'bottomCenter',
                    bottom_left: 'bottomLeft',
                    bottom_center: 'bottomCenter',
                    bottom_right: 'bottomRight',
                    bottom_bar: 'bottomCenter'
                  A 1 Reply Last reply
                  • A
                    ashishtank Module Developer @ashishtank
                    @fsne04 Here it checks for the position value (edited my answer above).
                      mishu28nmv
                      Hello guys. Absolute beginner in coding. I would like to make my own module with Flight prices.
                      As default I will have:
                      token: "MyToken",
                      api_host: "travelpayouts-travelpayouts-flight-data-v1.p.rapidapi.com",
                      api_key: "MyApiKey"
                      And as options I will have:
                      origin: "AAA",//Airport 3-Letter code
                      currency: "EUR",
                      depart_date: "2022-06-12",//format YYYY-MM-DD
                      return_date: "2022-06-19",//format YYYY-MM-DD
                      destination: "BBB"//Airport 3-Letter code
                      Is there anyone who can create a right code (module) for this situation? If this is too stupid to ask, or if this already exists, please let me know :(
                        cgillinger
                        Hi! I know this thread is quite old, but since I’m a complete noob, and I’ve followed the specific guide I didn’t want to spam the forum with a new thread.
                        I’ve tried adding this basic module, but the effect is always that the MM wont start.
                        I’m on Windows 10 (using a Surface Pro 4).
                        I’m using Notepad++
                        With the default installation, MM works using a browser.
                        This is how my config looks after adding the Jeopardy module:
                        This is the error output from CMD:
                        What am I doing wrong?
                          sdetweil @cgillinger
                          @cgillinger this module suffers from this problem
                          https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later/1
                          but the output looks different so
                          go to the module folder and do
                          npm init -y
                          npm install request
                          C 1 Reply Last reply
                            cgillinger @sdetweil
                            @sdetweil Tnx, that did the trick. I imagine thats been a problem with other modules that I started with. I’ll try the same on them.
                            Cheers!
                            • 5 / 5
