    How to add modules. For absolute beginners.
    91 Posts 16 Posters 166.6k Views 24 Watching
    • F
      fsne04 @sdetweil
      I did, maybe I did not copy it correctly. I will check.
      So how do I start a new topic/question and get nice/helpful people like you to answer? I have a few questions on the Remote Control module configuration also.
        sdetweil @fsne04
        @fsne04 see https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners/73?page=8
        F 1 Reply Last reply
        • F
          fsne04 @sdetweil
          In the headder, I see: Unread, Recent, Tags, Unsolved, Solved, Users, Groups, Repository, Documents, Donate, Join Channel… I am sure it’s there, but I don’t see a New Topic, or create Topic button.
          Thank you for your help today, Sam! Greatly appreciate your time.
          Best regards,
          Frank
            sdetweil @fsne04
            @fsne04 when I push unread, I see
            • A
              ashishtank Module Developer @fsne04
              @fsne04 if you check the code of MMM-Screent cast @ https://github.com/kevinatown/MMM-Screencast/blob/master/constants.js then there is no position which supports fullscreen_below.
              you need to set one of the below value as per documentation of the module
              const POSITIONS = {
                bottomRight: 'bottomRight',
                bottomCenter: 'bottomCenter',
                bottomLeft: 'bottomLeft',
                center: 'center',
                topRight: 'topRight',
                topCenter: 'topCenter',
                topLeft: 'topLeft',
                top_bar: 'topRight',
                top_left: 'topLeft',
                top_center: 'topCenter',
                top_right: 'topRight',
                upper_third: 'topRight',
                middle_center: 'center',
                lower_third: 'bottomCenter',
                bottom_left: 'bottomLeft',
                bottom_center: 'bottomCenter',
                bottom_right: 'bottomRight',
                bottom_bar: 'bottomCenter'
              A 1 Reply Last reply
              • A
                ashishtank Module Developer @ashishtank
                @fsne04 Here it checks for the position value (edited my answer above).
                  mishu28nmv
                  Hello guys. Absolute beginner in coding. I would like to make my own module with Flight prices.
                  As default I will have:
                  token: "MyToken",
                  api_host: "travelpayouts-travelpayouts-flight-data-v1.p.rapidapi.com",
                  api_key: "MyApiKey"
                  And as options I will have:
                  origin: "AAA",//Airport 3-Letter code
                  currency: "EUR",
                  depart_date: "2022-06-12",//format YYYY-MM-DD
                  return_date: "2022-06-19",//format YYYY-MM-DD
                  destination: "BBB"//Airport 3-Letter code
                  Is there anyone who can create a right code (module) for this situation? If this is too stupid to ask, or if this already exists, please let me know :(
                    cgillinger
                    Hi! I know this thread is quite old, but since I’m a complete noob, and I’ve followed the specific guide I didn’t want to spam the forum with a new thread.
                    I’ve tried adding this basic module, but the effect is always that the MM wont start.
                    I’m on Windows 10 (using a Surface Pro 4).
                    I’m using Notepad++
                    With the default installation, MM works using a browser.
                    This is how my config looks after adding the Jeopardy module:
                    This is the error output from CMD:
                    What am I doing wrong?
                      sdetweil @cgillinger
                      @cgillinger this module suffers from this problem
                      https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later/1
                      but the output looks different so
                      go to the module folder and do
                      npm init -y
                      npm install request
                      C 1 Reply Last reply
                        cgillinger @sdetweil
                        @sdetweil Tnx, that did the trick. I imagine thats been a problem with other modules that I started with. I’ll try the same on them.
                        Cheers!
                        • 5 / 5
