    How to add modules. For absolute beginners.
    91 Posts 16 Posters 166.6k Views 24 Watching
      sdetweil @fsne04
      @fsne04 ignore the warning. put ‘cast’ in the filter field (no quotes)
      the error may not be in the browser side of the module, but this is how you find out…
      otherwise, u need to look in the console where u started MM, either npm start, or if using pm2, then pm2 logs --lines=??? where ??? is a number, default 15
      F 1 Reply Last reply
      • F
        fsne04 @sdetweil
        Found something on the bottom:
        an error with my positioning config. Is not possible to have 2 modules on the same position? I have the image app on fullscreen_bottom also
        S A 3 Replies Last reply
          sdetweil @fsne04
          @fsne04 ok, there u go!..
            sdetweil @fsne04
            @fsne04 said in How to add modules. For absolute beginners.:
            sorry, don’t know anything about the module itself… so , not sure what that means
            • F
              fsne04 @sdetweil
              No worries, at least I know how to find errors now, Thanks! I guess I also have an issue with the weathermap setup, according to the error message below the screencast one.
                sdetweil @fsne04
                @fsne04 weather u need to sign up and get an api token just for you…
                • F
                  fsne04 @sdetweil
                  I did, maybe I did not copy it correctly. I will check.
                  So how do I start a new topic/question and get nice/helpful people like you to answer? I have a few questions on the Remote Control module configuration also.
                    sdetweil @fsne04
                    @fsne04 see https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners/73?page=8
                    • F
                      fsne04 @sdetweil
                      In the headder, I see: Unread, Recent, Tags, Unsolved, Solved, Users, Groups, Repository, Documents, Donate, Join Channel… I am sure it’s there, but I don’t see a New Topic, or create Topic button.
                      Thank you for your help today, Sam! Greatly appreciate your time.
                      Best regards,
                      Frank
                        sdetweil @fsne04
                        @fsne04 when I push unread, I see
                        • A
                          ashishtank Module Developer @fsne04
                          @fsne04 if you check the code of MMM-Screent cast @ https://github.com/kevinatown/MMM-Screencast/blob/master/constants.js then there is no position which supports fullscreen_below.
                          you need to set one of the below value as per documentation of the module
                          const POSITIONS = {
                            bottomRight: 'bottomRight',
                            bottomCenter: 'bottomCenter',
                            bottomLeft: 'bottomLeft',
                            center: 'center',
                            topRight: 'topRight',
                            topCenter: 'topCenter',
                            topLeft: 'topLeft',
                            top_bar: 'topRight',
                            top_left: 'topLeft',
                            top_center: 'topCenter',
                            top_right: 'topRight',
                            upper_third: 'topRight',
                            middle_center: 'center',
                            lower_third: 'bottomCenter',
                            bottom_left: 'bottomLeft',
                            bottom_center: 'bottomCenter',
                            bottom_right: 'bottomRight',
                            bottom_bar: 'bottomCenter'
                          A 1 Reply Last reply
                          • A
                            ashishtank Module Developer @ashishtank
                            @fsne04 Here it checks for the position value (edited my answer above).
                              mishu28nmv
                              Hello guys. Absolute beginner in coding. I would like to make my own module with Flight prices.
                              As default I will have:
                              token: "MyToken",
                              api_host: "travelpayouts-travelpayouts-flight-data-v1.p.rapidapi.com",
                              api_key: "MyApiKey"
                              And as options I will have:
                              origin: "AAA",//Airport 3-Letter code
                              currency: "EUR",
                              depart_date: "2022-06-12",//format YYYY-MM-DD
                              return_date: "2022-06-19",//format YYYY-MM-DD
                              destination: "BBB"//Airport 3-Letter code
                              Is there anyone who can create a right code (module) for this situation? If this is too stupid to ask, or if this already exists, please let me know :(
                                cgillinger
                                Hi! I know this thread is quite old, but since I’m a complete noob, and I’ve followed the specific guide I didn’t want to spam the forum with a new thread.
                                I’ve tried adding this basic module, but the effect is always that the MM wont start.
                                I’m on Windows 10 (using a Surface Pro 4).
                                I’m using Notepad++
                                With the default installation, MM works using a browser.
                                This is how my config looks after adding the Jeopardy module:
                                This is the error output from CMD:
                                What am I doing wrong?
                                  sdetweil @cgillinger
                                  @cgillinger this module suffers from this problem
                                  https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later/1
                                  but the output looks different so
                                  go to the module folder and do
                                  npm init -y
                                  npm install request
                                  C 1 Reply Last reply
                                    cgillinger @sdetweil
                                    @sdetweil Tnx, that did the trick. I imagine thats been a problem with other modules that I started with. I’ll try the same on them.
                                    Cheers!
                                    • 5 / 5
