    Testing my module, it is stuck loading
    31 Posts 2 Posters 12.4k Views 2 Watching
    • L
      l0zarus @sdetweil
      @sdetweil I’m not sure I’m following this. Do you mean in VS code or with the Magic Mirror application running?
        sdetweil @l0zarus
        @l0zarus magicmirror… of course
        L 1 Reply Last reply
        • L
          l0zarus @sdetweil
          @sdetweil well my module isn’t even in the modules folder even though it is in the config file which is confusing to me. I noticed in your screenshot that default is a subfolder of modules. That is true in my path to the module, but they are appearing as one combined folder. I’m not sure why that is the case. In any event, clearly my module was never actually loading at all. Any idea what the issue is here? I’ll start to update my code to remove the API call from the getDom function.
            sdetweil @l0zarus
            @l0zarus AH, now we’re getting somewhere
            go to the console tab and put part of your module name in the filter field
            also,
            modulename in config.js = folder name in modules folder = filename of the .js file
            AND the register name
            config.js
                 module:"SampleModule",
            modules/SampleModule/SampleModule.js
            Module.register("SampleModule", {
            ALL these MUST match else your module is not loaded
            system is case sensitive
            L 2 Replies Last reply
            • L
              l0zarus @sdetweil
              @sdetweil Alright I have a few errors showing, and I’m having an issue moving my file to the modules folder. I have verified the name is the same across the folder, the js file, and the config file.
              First, I got the following message when trying to move it:
              mv MMM-ConcertsAroundMe /modules
              mv: cannot move 'MMM-ConcertsAroundMe' to '/modules': Permission denied
              Will paste the console errors as well, I am moving between my mac and raspberry pi
              S 2 Replies Last reply
                sdetweil @l0zarus
                @l0zarus its not /modules (that is in the root)
                depending where your module is , the quick way
                mv MMM-ConcertsAroundMe ~/MagicMirror/modules
                • L
                  l0zarus @sdetweil
                  @sdetweil aha! I had tried that as well, but I did not include the ~. I am learning so much from this project :)
                    sdetweil @l0zarus
                    @l0zarus said in Testing my module, it is stuck loading:
                    magicmirror will run on your mac…
                    use my install script
                      sdetweil @l0zarus
                      @l0zarus ~ means users home folder (less letters to type, remember most of this linux console stuff was created on slow 300bps phone lines… the fewer letters the better)
                      • L
                        l0zarus @sdetweil
                        @sdetweil alright here are the errors:
                          sdetweil @l0zarus
                          @l0zarus did yiu npm install luxon in your module folder
                          npm init -y
                          npm install luxon
                          if u don’t do the npm init in your module folder the module will be installed in the root MM node_modules, then not found here
                          • L
                            l0zarus @sdetweil
                            @sdetweil ok that was an issue! I got luxon installed in the right place. Now I’m getting the following errors:
                            I tested the exact link from the first error “Access to fetch at…” in postman and I get a clean response
                              sdetweil @l0zarus
                              @l0zarus lovely CORS… welcome to the fun
                              postman didn’t use localhost it used the local IP address
                              you ‘might’ get to fix it in config.js ? maybe
                              from terminal window do
                              ip addr
                              that give u the local machine ip address
                              use that in the config.js
                              address:""
                              instead of locahost…
                              CORS basically means, “hey, you are not in our known approved access network, get lost”
                              • L
                                l0zarus @sdetweil
                                @sdetweil ugh, well that did not do it unfortunately. I’m not sure what to do now. It recommends setting the requests mode to ‘no-cors’. Is that something that might work here?
                                  sdetweil @l0zarus
                                  @l0zarus CORS is controlled by the server side, NOTHING the client can do except change the capability
                                  there used to be free services where you could send the request to them and they would forward (from a known address) and send the response back to you
                                  a CORS proxy, most of those have gone away or are no longer free.
                                  we’ve added a cors safe fetch (we think) to the MM system
                                  see ~/MagicMirror/js/server_functions.js
                                  ( I have tried to break that into understandable reusable sections below )
                                  u change your url request to this cors_url
                                  let header_stuff_if_any="sendheaders=header1:value1,header2:value2&expectedheaders=header1,header2"
                                  // empty string, "",  if no headers
                                  let original_url="http://www.test.com/path?param1=value1"
                                  let_cors_url=
                                  "http://"+
                                  // use the config.address value, unless its "0.0.0.0", then use "localhost"
                                  config.address==="0.0.0.0"?"localhost":config.address
                                  +config.port+
                                  "/cors?"+
                                  header_stuff
                                  +"&url="+
                                  original_url
                                  and we will send it, and return the response to your fetch
                                  • L
                                    l0zarus @sdetweil
                                    @sdetweil I’m struggling to understand the first part. I don’t think there is any header stuff that I know of? the url is based on this format: https://api.seatgeek.com/2/events?client_id=MYCLIENTID&client_secret=MYCLIENTSECRET with other stuff added as you saw in my source code in the original post.
                                    honestly the whole thing is a bit confusing to me. I’m not sure where it is supposed to go… as part of where I define the URL variable?
                                      sdetweil @l0zarus
                                      @l0zarus ok, no headers set it to “”
                                      you use that code to build your fetch url (and put it in the original_url variable)
                                      I just created the JS code to do the build from the parts
                                      the comment in the linked file just doesn’t help me at all…
                                      and when you execute the fetch, it sends it to magic mirror code that forwards on supposedly to avoid the cors problem…
                                      • L
                                        l0zarus @sdetweil
                                        @sdetweil I’m going to try to fill it out like a template, let me know if I’m following.
                                        let header = "",
                                        let original_url = "https://api.seatgeek.com/2/events?client_id=MYCLIENTID&client_secret=MYCLIENTSECRET "
                                        let cors_url = "http://" + config.address==="IP ADDRESS HERE"?"localhost":config.address + ":" + config.port + "/cors?" + header + "&url=" + original_url
                                        and then I fetch(cors_url)?
                                        Is this right?
                                          sdetweil @l0zarus
                                          Is this right?
                                          yes
                                          almost …
                                          "IP ADDRESS HERE"
                                          MUST be
                                          "0.0.0.0"
                                          (which is the MM value for listen on any network adapter)
                                          • L
                                            l0zarus @sdetweil
                                            // this next block is to deal with a CORS permissions issue with the API
                                            let header = “”;
                                                // this is the API call url
                                                let original_url = "http://api.seatgeek.com/2/events?lat=" + self.config.latitude + "&lon=" + self.config.longitude + "&per_page=" + self.config.eventCount + "&datetime_utc.gte=" + today + "&datetime_utc.lte=" + oneweek + "&range=" + self.config.range + "&type=concert" + "&client_id=" + self.config.clientID + "&client_secret=" + self.config.clientSecret;
                                                // this is the cors URL
                                                let cors_url = "http://" + config.address==="0.0.0.0"?"localhost":config.address + ":" + config.port + "/cors?" + header + "&url=" + original_url;
