    Testing my module, it is stuck loading
    31 Posts 2 Posters 11.3k Views 2 Watching
    • L Offline
      l0zarus
      Hi folks! I’ve been working on a module to display concerts coming up in my area in the next week using the seatgeek API. I’m not sure why the module will not display now that I’ve added it to the config. I think the code makes sense. Any advice would be greatly appreciated, I’m pasting my getDom function below:
      getDom: function() {
              // create the table element
              const table = document.createElement('table');
              var self = this;
              // set variable for today
              const today = luxon.DateTime.utc().toISODate();
              // set variable for a week from today
              const oneweek = luxon.DateTime.utc().plus({ weeks: 1 }).toISODate();
              // this is the API call url
              var url = "http://api.seatgeek.com/2/events?lat=" + self.config.latitude + "&lon=" + self.config.longitude + "&per_page=" + self.config.eventCount + "&datetime_utc.gte=" + today + "&datetime_utc.lte=" + oneweek + "&range=" + self.config.range + "&type=concert" + "&client_id=" + self.config.apiKey;
              // fetching the data from seatgeek
              fetch(url)
                  // parse the json response into a JS object
                  .then((response) => response.json())
                  // then populate a table with the data
                  .then(data => {
                      // define the table headers
                      const headerRow = table.insertRow();
                      const artisthead = headerRow.insertCell(0);
                      artisthead.innerHTML = 'Artist';
                      const datetimehead = headerRow.insertCell(1);
                      datetimehead.innerHTML = 'Date & Time';
                      const cityhead = headerRow.insertCell(2);
                      cityhead.innerHTML = 'City';
                      const venuehead = headerRow.insertCell(3);
                      venuehead.innerHTML = 'Venue'
                      // loop through the data and create row for each item
                      for (let i = 0; i < self.config.eventCount && i < data.events.length; i++) {
                          const row = table.insertRow();
                          // populte the cells with data from the API response
                          const artist = row.insertCell(0);
                          artist.innerHTML = data.events[i].performers[0].name;
                          const datetime = row.insertCell(1);
                          datetime.innerHTML = data.events[i].datetime_local;
                          const city = row.insertCell(2);
                          city.innerHTML = data.events[i].venue.city;
                          const venue = row.insertCell(3);
                          venue.innerHTML = data.events[i].venue.name;
                      // add this table to the wrapper
                      wrapper.appendChild(table);
              .catch(function() {
                  // if the API call is unsuccessful, display error message
                  wrapper.innerHTML = "Error calling data to display event information";
          return wrapper;
        sdetweil @l0zarus
        @l0zarus open the develpers window , ctrl-shift-i, then select the sources tab, modules in the left nav, and find your module
        click the number in the left nav for the 1st line under your getdom
        and then hit f5 to refesh the page and stop at your getdom function
          sdetweil @l0zarus
          @l0zarus also, NEVER fetch inside getDom()… get the data first, THEN call updateDom() to advise there is data ready …
          you can use the start function, or better, use the notifcationReceived function for “ALL_MODULES_LOADED” then kick off a timer or an interval
          at the end of good data received, call this.updateDom()
          getdom must ALWAYS return a dom element (aka wrapper at least)
          • L Offline
            l0zarus @sdetweil
            @sdetweil I’m not sure I’m following this. Do you mean in VS code or with the Magic Mirror application running?
              sdetweil @l0zarus
              @l0zarus magicmirror… of course
              • L Offline
                l0zarus @sdetweil
                @sdetweil well my module isn’t even in the modules folder even though it is in the config file which is confusing to me. I noticed in your screenshot that default is a subfolder of modules. That is true in my path to the module, but they are appearing as one combined folder. I’m not sure why that is the case. In any event, clearly my module was never actually loading at all. Any idea what the issue is here? I’ll start to update my code to remove the API call from the getDom function.
                  sdetweil @l0zarus
                  @l0zarus AH, now we’re getting somewhere
                  go to the console tab and put part of your module name in the filter field
                  also,
                  modulename in config.js = folder name in modules folder = filename of the .js file
                  AND the register name
                  config.js
                       module:"SampleModule",
                  modules/SampleModule/SampleModule.js
                  Module.register("SampleModule", {
                  ALL these MUST match else your module is not loaded
                  system is case sensitive
                  L 2 Replies Last reply Reply Quote 0
                  • L Offline
                    l0zarus @sdetweil
                    @sdetweil Alright I have a few errors showing, and I’m having an issue moving my file to the modules folder. I have verified the name is the same across the folder, the js file, and the config file.
                    First, I got the following message when trying to move it:
                    mv MMM-ConcertsAroundMe /modules
                    mv: cannot move 'MMM-ConcertsAroundMe' to '/modules': Permission denied
                    Will paste the console errors as well, I am moving between my mac and raspberry pi
                      sdetweil @l0zarus
                      @l0zarus its not /modules (that is in the root)
                      depending where your module is , the quick way
                      mv MMM-ConcertsAroundMe ~/MagicMirror/modules
                      • L Offline
                        l0zarus @sdetweil
                        @sdetweil aha! I had tried that as well, but I did not include the ~. I am learning so much from this project :)
                          sdetweil @l0zarus
                          @l0zarus said in Testing my module, it is stuck loading:
                          magicmirror will run on your mac…
                          use my install script
                            sdetweil @l0zarus
                            @l0zarus ~ means users home folder (less letters to type, remember most of this linux console stuff was created on slow 300bps phone lines… the fewer letters the better)
                            • L Offline
                              l0zarus @sdetweil
                              @sdetweil alright here are the errors:
                                sdetweil @l0zarus
                                @l0zarus did yiu npm install luxon in your module folder
                                npm init -y
                                npm install luxon
                                if u don’t do the npm init in your module folder the module will be installed in the root MM node_modules, then not found here
                                • L Offline
                                  l0zarus @sdetweil
                                  @sdetweil ok that was an issue! I got luxon installed in the right place. Now I’m getting the following errors:
                                  I tested the exact link from the first error “Access to fetch at…” in postman and I get a clean response
                                    sdetweil @l0zarus
                                    @l0zarus lovely CORS… welcome to the fun
                                    postman didn’t use localhost it used the local IP address
                                    you ‘might’ get to fix it in config.js ? maybe
                                    from terminal window do
                                    ip addr
                                    that give u the local machine ip address
                                    use that in the config.js
                                    address:""
                                    instead of locahost…
                                    CORS basically means, “hey, you are not in our known approved access network, get lost”
                                    • L Offline
                                      l0zarus @sdetweil
                                      @sdetweil ugh, well that did not do it unfortunately. I’m not sure what to do now. It recommends setting the requests mode to ‘no-cors’. Is that something that might work here?
                                        sdetweil @l0zarus
                                        @l0zarus CORS is controlled by the server side, NOTHING the client can do except change the capability
                                        there used to be free services where you could send the request to them and they would forward (from a known address) and send the response back to you
                                        a CORS proxy, most of those have gone away or are no longer free.
                                        we’ve added a cors safe fetch (we think) to the MM system
                                        see ~/MagicMirror/js/server_functions.js
                                        ( I have tried to break that into understandable reusable sections below )
                                        u change your url request to this cors_url
                                        let header_stuff_if_any="sendheaders=header1:value1,header2:value2&expectedheaders=header1,header2"
                                        // empty string, "",  if no headers
                                        let original_url="http://www.test.com/path?param1=value1"
                                        let_cors_url=
                                        "http://"+
                                        // use the config.address value, unless its "0.0.0.0", then use "localhost"
                                        config.address==="0.0.0.0"?"localhost":config.address
                                        +config.port+
                                        "/cors?"+
                                        header_stuff
                                        +"&url="+
                                        original_url
                                        and we will send it, and return the response to your fetch
                                        • L Offline
                                          l0zarus @sdetweil
                                          @sdetweil I’m struggling to understand the first part. I don’t think there is any header stuff that I know of? the url is based on this format: https://api.seatgeek.com/2/events?client_id=MYCLIENTID&client_secret=MYCLIENTSECRET with other stuff added as you saw in my source code in the original post.
                                          honestly the whole thing is a bit confusing to me. I’m not sure where it is supposed to go… as part of where I define the URL variable?
                                            sdetweil @l0zarus
                                            @l0zarus ok, no headers set it to “”
                                            you use that code to build your fetch url (and put it in the original_url variable)
                                            I just created the JS code to do the build from the parts
                                            the comment in the linked file just doesn’t help me at all…
                                            and when you execute the fetch, it sends it to magic mirror code that forwards on supposedly to avoid the cors problem…
