    Testing my module, it is stuck loading
    31 Posts 2 Posters 9.6k Views 2 Watching
    • L Offline
      l0zarus
      Hi folks! I’ve been working on a module to display concerts coming up in my area in the next week using the seatgeek API. I’m not sure why the module will not display now that I’ve added it to the config. I think the code makes sense. Any advice would be greatly appreciated, I’m pasting my getDom function below:
      getDom: function() {
              // create the table element
              const table = document.createElement('table');
              var self = this;
              // set variable for today
              const today = luxon.DateTime.utc().toISODate();
              // set variable for a week from today
              const oneweek = luxon.DateTime.utc().plus({ weeks: 1 }).toISODate();
              // this is the API call url
              var url = "http://api.seatgeek.com/2/events?lat=" + self.config.latitude + "&lon=" + self.config.longitude + "&per_page=" + self.config.eventCount + "&datetime_utc.gte=" + today + "&datetime_utc.lte=" + oneweek + "&range=" + self.config.range + "&type=concert" + "&client_id=" + self.config.apiKey;
              // fetching the data from seatgeek
              fetch(url)
                  // parse the json response into a JS object
                  .then((response) => response.json())
                  // then populate a table with the data
                  .then(data => {
                      // define the table headers
                      const headerRow = table.insertRow();
                      const artisthead = headerRow.insertCell(0);
                      artisthead.innerHTML = 'Artist';
                      const datetimehead = headerRow.insertCell(1);
                      datetimehead.innerHTML = 'Date & Time';
                      const cityhead = headerRow.insertCell(2);
                      cityhead.innerHTML = 'City';
                      const venuehead = headerRow.insertCell(3);
                      venuehead.innerHTML = 'Venue'
                      // loop through the data and create row for each item
                      for (let i = 0; i < self.config.eventCount && i < data.events.length; i++) {
                          const row = table.insertRow();
                          // populte the cells with data from the API response
                          const artist = row.insertCell(0);
                          artist.innerHTML = data.events[i].performers[0].name;
                          const datetime = row.insertCell(1);
                          datetime.innerHTML = data.events[i].datetime_local;
                          const city = row.insertCell(2);
                          city.innerHTML = data.events[i].venue.city;
                          const venue = row.insertCell(3);
                          venue.innerHTML = data.events[i].venue.name;
                      // add this table to the wrapper
                      wrapper.appendChild(table);
              .catch(function() {
                  // if the API call is unsuccessful, display error message
                  wrapper.innerHTML = "Error calling data to display event information";
          return wrapper;
        sdetweil @l0zarus
        @l0zarus open the develpers window , ctrl-shift-i, then select the sources tab, modules in the left nav, and find your module
        click the number in the left nav for the 1st line under your getdom
        and then hit f5 to refesh the page and stop at your getdom function
          sdetweil @l0zarus
          @l0zarus also, NEVER fetch inside getDom()… get the data first, THEN call updateDom() to advise there is data ready …
          you can use the start function, or better, use the notifcationReceived function for “ALL_MODULES_LOADED” then kick off a timer or an interval
          at the end of good data received, call this.updateDom()
          getdom must ALWAYS return a dom element (aka wrapper at least)
          • L Offline
            l0zarus @sdetweil
            @sdetweil I’m not sure I’m following this. Do you mean in VS code or with the Magic Mirror application running?
              sdetweil @l0zarus
              @l0zarus magicmirror… of course
              • L Offline
                l0zarus @sdetweil
                @sdetweil well my module isn’t even in the modules folder even though it is in the config file which is confusing to me. I noticed in your screenshot that default is a subfolder of modules. That is true in my path to the module, but they are appearing as one combined folder. I’m not sure why that is the case. In any event, clearly my module was never actually loading at all. Any idea what the issue is here? I’ll start to update my code to remove the API call from the getDom function.
                  sdetweil @l0zarus
                  @l0zarus AH, now we’re getting somewhere
                  go to the console tab and put part of your module name in the filter field
                  also,
                  modulename in config.js = folder name in modules folder = filename of the .js file
                  AND the register name
                  config.js
                       module:"SampleModule",
                  modules/SampleModule/SampleModule.js
                  Module.register("SampleModule", {
                  ALL these MUST match else your module is not loaded
                  system is case sensitive
                  L 2 Replies Last reply Reply Quote 0
                  • L Offline
                    l0zarus @sdetweil
                    @sdetweil Alright I have a few errors showing, and I’m having an issue moving my file to the modules folder. I have verified the name is the same across the folder, the js file, and the config file.
                    First, I got the following message when trying to move it:
                    mv MMM-ConcertsAroundMe /modules
                    mv: cannot move 'MMM-ConcertsAroundMe' to '/modules': Permission denied
                    Will paste the console errors as well, I am moving between my mac and raspberry pi
                      sdetweil @l0zarus
                      @l0zarus its not /modules (that is in the root)
                      depending where your module is , the quick way
                      mv MMM-ConcertsAroundMe ~/MagicMirror/modules
                      • L Offline
                        l0zarus @sdetweil
                        @sdetweil aha! I had tried that as well, but I did not include the ~. I am learning so much from this project :)
                        • 1 / 4
