Testing my module, it is stuck loading
31 Posts 2 Posters 8.1k Views 2 Watching
  • L Offline
    l0zarus
    Hi folks! I’ve been working on a module to display concerts coming up in my area in the next week using the seatgeek API. I’m not sure why the module will not display now that I’ve added it to the config. I think the code makes sense. Any advice would be greatly appreciated, I’m pasting my getDom function below:
    getDom: function() {
            // create the table element
            const table = document.createElement('table');
            var self = this;
            // set variable for today
            const today = luxon.DateTime.utc().toISODate();
            // set variable for a week from today
            const oneweek = luxon.DateTime.utc().plus({ weeks: 1 }).toISODate();
            // this is the API call url
            var url = "http://api.seatgeek.com/2/events?lat=" + self.config.latitude + "&lon=" + self.config.longitude + "&per_page=" + self.config.eventCount + "&datetime_utc.gte=" + today + "&datetime_utc.lte=" + oneweek + "&range=" + self.config.range + "&type=concert" + "&client_id=" + self.config.apiKey;
            // fetching the data from seatgeek
            fetch(url)
                // parse the json response into a JS object
                .then((response) => response.json())
                // then populate a table with the data
                .then(data => {
                    // define the table headers
                    const headerRow = table.insertRow();
                    const artisthead = headerRow.insertCell(0);
                    artisthead.innerHTML = 'Artist';
                    const datetimehead = headerRow.insertCell(1);
                    datetimehead.innerHTML = 'Date & Time';
                    const cityhead = headerRow.insertCell(2);
                    cityhead.innerHTML = 'City';
                    const venuehead = headerRow.insertCell(3);
                    venuehead.innerHTML = 'Venue'
                    // loop through the data and create row for each item
                    for (let i = 0; i < self.config.eventCount && i < data.events.length; i++) {
                        const row = table.insertRow();
                        // populte the cells with data from the API response
                        const artist = row.insertCell(0);
                        artist.innerHTML = data.events[i].performers[0].name;
                        const datetime = row.insertCell(1);
                        datetime.innerHTML = data.events[i].datetime_local;
                        const city = row.insertCell(2);
                        city.innerHTML = data.events[i].venue.city;
                        const venue = row.insertCell(3);
                        venue.innerHTML = data.events[i].venue.name;
                    // add this table to the wrapper
                    wrapper.appendChild(table);
            .catch(function() {
                // if the API call is unsuccessful, display error message
                wrapper.innerHTML = "Error calling data to display event information";
        return wrapper;
    S 2 Replies Last reply May 7, 2023, 11:35 PM Reply Quote 0
      sdetweil @l0zarus
      @l0zarus open the develpers window , ctrl-shift-i, then select the sources tab, modules in the left nav, and find your module
      click the number in the left nav for the 1st line under your getdom
      and then hit f5 to refesh the page and stop at your getdom function
      L 1 Reply Last reply May 7, 2023, 11:49 PM Reply Quote 0
        sdetweil @l0zarus
        @l0zarus also, NEVER fetch inside getDom()… get the data first, THEN call updateDom() to advise there is data ready …
        you can use the start function, or better, use the notifcationReceived function for “ALL_MODULES_LOADED” then kick off a timer or an interval
        at the end of good data received, call this.updateDom()
        getdom must ALWAYS return a dom element (aka wrapper at least)
        • L Offline
          l0zarus @sdetweil
          @sdetweil I’m not sure I’m following this. Do you mean in VS code or with the Magic Mirror application running?
          S 1 Reply Last reply May 7, 2023, 11:51 PM Reply Quote 0
            sdetweil @l0zarus
            @l0zarus magicmirror… of course
            L 1 Reply Last reply May 7, 2023, 11:57 PM Reply Quote 0
            • L Offline
              l0zarus @sdetweil
              @sdetweil well my module isn’t even in the modules folder even though it is in the config file which is confusing to me. I noticed in your screenshot that default is a subfolder of modules. That is true in my path to the module, but they are appearing as one combined folder. I’m not sure why that is the case. In any event, clearly my module was never actually loading at all. Any idea what the issue is here? I’ll start to update my code to remove the API call from the getDom function.
              S 1 Reply Last reply May 8, 2023, 12:00 AM Reply Quote 0
                sdetweil @l0zarus
                @l0zarus AH, now we’re getting somewhere
                go to the console tab and put part of your module name in the filter field
                also,
                modulename in config.js = folder name in modules folder = filename of the .js file
                AND the register name
                config.js
                     module:"SampleModule",
                modules/SampleModule/SampleModule.js
                Module.register("SampleModule", {
                ALL these MUST match else your module is not loaded
                system is case sensitive
                L 2 Replies Last reply May 8, 2023, 12:13 AM Reply Quote 0
                • L Offline
                  l0zarus @sdetweil
                  @sdetweil Alright I have a few errors showing, and I’m having an issue moving my file to the modules folder. I have verified the name is the same across the folder, the js file, and the config file.
                  First, I got the following message when trying to move it:
                  mv MMM-ConcertsAroundMe /modules
                  mv: cannot move 'MMM-ConcertsAroundMe' to '/modules': Permission denied
                  Will paste the console errors as well, I am moving between my mac and raspberry pi
                  S 2 Replies Last reply May 8, 2023, 12:15 AM Reply Quote 0
                    sdetweil @l0zarus
                    @l0zarus its not /modules (that is in the root)
                    depending where your module is , the quick way
                    mv MMM-ConcertsAroundMe ~/MagicMirror/modules
                    L 1 Reply Last reply May 8, 2023, 12:16 AM Reply Quote 0
                    • L Offline
                      l0zarus @sdetweil
                      @sdetweil aha! I had tried that as well, but I did not include the ~. I am learning so much from this project :)
                      S 1 Reply Last reply May 8, 2023, 12:19 AM Reply Quote 0
                      • 1 / 4
                      1 / 4
