My configuration. Js
7 Posts 4 Posters 1.8k Views 4 Watching
  • V Offline
    videogame95
    I used to be able to change the" localhost “to” 0.0.0.0"
    Its I cannot use this any more ?
    I add remote control to turn on off modules.
    What can I put in the “Localhost” in stead of “0.0.0.0”
    I also would change the brackets to this [] so i can have open post on all IP address.
    Any help please
    S B 2 Replies Last reply Jun 5, 2023, 11:28 AM Reply Quote 0
      sdetweil @videogame95
      @videogame95 why can’t you use “0.0.0.0”?
      I do it all the time
        BKeyport Module Developer @videogame95
        @videogame95 Both should be fully functional - unless you use specific modules, in which case you’d have to set the IP address to the address of the mirror. (192.168.0.x, typical)
        S 1 Reply Last reply Jun 5, 2023, 10:56 PM Reply Quote 0
          sdetweil @BKeyport
          @BKeyport which modules require specific address… I haven’t seen one yet.
          I know a few that want not “locahost”, but “0.0.0.0” works…
          there is a bug on windows recently with “0.0.0.0”… I posted an issue, and a proposed fix… just no PR yet
          B 1 Reply Last reply Jun 6, 2023, 2:43 AM Reply Quote 0
            @sdetweil I know one of the camera apps does it.
            • T Offline
              TDMPro2K
              127.0.0.1
              S 1 Reply Last reply Jun 11, 2023, 10:55 AM Reply Quote 0
                sdetweil @TDMPro2K
                @TDMPro2K that is the same as localhost.which means only apps INSIDE the same machine can connect
