    MMM-PublicTransportHafas from KristjanESPERANTO
    7 Posts 3 Posters 2.4k Views 3 Watching
    • O Offline
      onkelbobby @thgmirror
      @thgmirror
      Thank you for this hint… I’ll try it once I’m back from my business trip.
      • KristjanESPERANTOK Offline
        KristjanESPERANTO Module Developer @onkelbobby
        Hi @onkelbobby,
        nice that you use my fork :slightly_smiling_face:
        The reason why the columns have different widths is that you enabled the platform in the first module and not in the others. The simplest option would be to display the column for the second and third module as well. But maybe that doesn’t make sense with this two stops, then you could try the approach of setting the width in your custom.css like this:
        table.mmm-pth-table {
        width: fit-content;
        .mmm-pth-time-cell {
        width: 10ch;
        .mmm-pth-sign {
        width: 6ch;
        • O Offline
          onkelbobby
          thank you @KristjanESPERANTO for your reply and sorry for my late response due to my business trip.
          I just implemented your recommendation into styles.css and it worked great. The only thing that’s now different is how to arrange the track number that it is aligned to the right?
          Maybe you also have an idea how to solve why all of a sudden several delay times are displayed as “?”
          thank you for your great help
            @onkelbobby
            Try it with that addition to your CSS file:
            .mmm-pth-platform-cell  {
            width: 3ch;
            I’ve never noticed the question mark before. I assume that this is displayed when no real time data is available. I just tried it with Adunistraße and didn’t see a question mark. The problem was probably only temporary on the API side.
            • O Offline
              onkelbobby @KristjanESPERANTO
              @KristjanESPERANTO
              thanks again but unfortunately this did not help. It increases the space between the platform number and the right edge but does not move the platform number to the right. Even if I add
                width: 3ch;
                text-align: right;
              it will stay same.
              the question marks indeed traced back to the API. they disappeared the next day.
