    I'm getting error -MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: Permission denied
    10 Posts 3 Posters 4.2k Views 3 Watching
    • V Offline
      vpanse
      Re: MMM-FlightsAbove - Display all flights in the sky above you
        sdetweil @vpanse
        @vpanse yes, it’s a display driver config issue on the base is. no good fix
        but you can suppress the messages
        where you do npm start
        add
        export ELECTRON_DISABLE_GPU=1
        before the npm start line
        if you use my install scripts, the file to modify is
        ~/MagicMirror/installers/mm.sh
        • V Offline
          vpanse
          I’m trying to run https://github.com/E3V3A/MMM-FlightsAbove
          but getting following errors
          GMESA-LOADER: failed to retrieve device information
          MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib>failed to load driver: kms_swrast
          MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/arm-lin>failed to load swrast driver
          /home/vinayak/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
          [10.07.2023 02:06.43.861] [ERROR] (node:7189) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘pinkie-promise’
          Require stack:
          • /home/vinayak/MagicMirror/modules/MMM-FlightsAbove/lib/radar.js
          • /home/vinayak/MagicMirror/modules/MMM-FlightsAbove/node_helper.js
          • /home/vinayak/MagicMirror/js/app.js
          • /home/vinayak/MagicMirror/js/electron.js
          • /home/vinayak/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
          • at Module._resolveFilename (node:internal/modules/cjs/loader:1082:15)
            at n._resolveFilename (node:electron/js2c/browser_init:2:117457)
            at Module._resolveFilename (/home/vinayak/MagicMirror/node_modules/module-alias/index.js:49:29)
            at Module._load (node:internal/modules/cjs/loader:927:27)
            at f._load (node:electron/js2c/asar_bundle:2:13330)
            at Module.require (node:internal/modules/cjs/loader:1148:19)
            at require (node:internal/modules/cjs/helpers:110:18)
            at Object. (/home/vinayak/MagicMirror/modules/MMM-FlightsAbove/lib/radar.js:36:53)
            at Module._compile (node:internal/modules/cjs/loader:1269:14)
            at Module._extensions…js (node:internal/modules/cjs/loader:1324:10)
            at Module.load (node:internal/modules/cjs/loader:1124:32)
            at Module._load (node:internal/modules/cjs/loader:965:12)
            at Object. (/home/vinayak/MagicMirror/modules/MMM-FlightsAbove/node_helper.js:43:15)
            (Use electron --trace-warnings ... to show where the warning was created)
            [10.07.2023 02:06.43.861] [ERROR] (node:7189) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by thr>MESA-LOADER: failed to retrieve device information
            sdetweil @vpanse
            @vpanse see the post directly above your
            • V Offline
              vpanse
              I already did try that , it does not work for modules
              https://github.com/mykle1/MMM-BMW-CC and
              https://github.com/E3V3A/MMM-FlightsAbove.
              Still getting error as below.
              require stack:
              • /home/vinayak/MagicMirror/modules/MMM-BMW-CC/node_helper.js
                at n._resolveFilename (node:electron/js2c/browser_init:2:117469)
                at Object. (/home/vinayak/MagicMirror/modules/MMM-BMW-CC/node_helper.js:8:17)
                at loadModule (/home/vinayak/MagicMirror/js/app.js:180:19)
                [16.07.2023 18:40.43.267] [ERROR] (node:989) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejectin>MESA-LOADER: failed to retrieve device information
                MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/arm-linux-gnueabihf/dri:$${ORIGIN}/dri:/usr/lib/dri)
                MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/arm-linux-gnueabihf/dri:$${ORIGIN}/dri:/usr/lib/dri)
                sdetweil @vpanse
                @vpanse see
                • karsten13K Offline
                  karsten13 @sdetweil
                  or forgot to run npm install in the module folder of MMM-FlightsAbove
                  • V Offline
                    vpanse
                    I did many changes suggested in Form but still little different issue
                    [17.07.2023 05:21.57.786] [ERROR] (node:932) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘fetch-ponyfill’
                    Require stack:
                      at Object. (/home/vinayak/MagicMirror/modules/MMM-FlightsAbove/lib/radar.js:36:17)
                      [17.07.2023 05:21.57.787] [ERROR] (node:932) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a c>
                      sdetweil @vpanse
                      @vpanse said in I'm getting error -MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: Permission denied:
                      yes, unfortunately this module does not document in it’s package.json all the library dependencies it requires.
                      so, for each one you have to do
                      npm install xxxxx
                      where xxxxx is the missing library from the message above (in single quotes)
                      the module hasn’t been updated since 2018, so no idea if it still works after all that
                      your other post was marked as spam, which I cannot override
                      • V Offline
                        vpanse
                        Excellent, It works now . thanks a lot ,
