I'm getting error -MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: Permission denied
10 Posts 3 Posters 3.3k Views 3 Watching
  • V Offline
    vpanse
    Re: MMM-FlightsAbove - Display all flights in the sky above you
    S 1 Reply Last reply Jul 10, 2023, 11:01 AM Reply Quote 0
      sdetweil @vpanse
      @vpanse yes, it’s a display driver config issue on the base is. no good fix
      but you can suppress the messages
      where you do npm start
      add
      export ELECTRON_DISABLE_GPU=1
      before the npm start line
      if you use my install scripts, the file to modify is
      ~/MagicMirror/installers/mm.sh
      • V Offline
        vpanse
        I’m trying to run https://github.com/E3V3A/MMM-FlightsAbove
        but getting following errors
        GMESA-LOADER: failed to retrieve device information
        MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib>failed to load driver: kms_swrast
        MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/arm-lin>failed to load swrast driver
        /home/vinayak/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
        [10.07.2023 02:06.43.861] [ERROR] (node:7189) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘pinkie-promise’
        Require stack:
        • /home/vinayak/MagicMirror/modules/MMM-FlightsAbove/lib/radar.js
        • /home/vinayak/MagicMirror/modules/MMM-FlightsAbove/node_helper.js
        • /home/vinayak/MagicMirror/js/app.js
        • /home/vinayak/MagicMirror/js/electron.js
        • /home/vinayak/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js
        • at Module._resolveFilename (node:internal/modules/cjs/loader:1082:15)
          at n._resolveFilename (node:electron/js2c/browser_init:2:117457)
          at Module._resolveFilename (/home/vinayak/MagicMirror/node_modules/module-alias/index.js:49:29)
          at Module._load (node:internal/modules/cjs/loader:927:27)
          at f._load (node:electron/js2c/asar_bundle:2:13330)
          at Module.require (node:internal/modules/cjs/loader:1148:19)
          at require (node:internal/modules/cjs/helpers:110:18)
          at Object. (/home/vinayak/MagicMirror/modules/MMM-FlightsAbove/lib/radar.js:36:53)
          at Module._compile (node:internal/modules/cjs/loader:1269:14)
          at Module._extensions…js (node:internal/modules/cjs/loader:1324:10)
          at Module.load (node:internal/modules/cjs/loader:1124:32)
          at Module._load (node:internal/modules/cjs/loader:965:12)
          at Object. (/home/vinayak/MagicMirror/modules/MMM-FlightsAbove/node_helper.js:43:15)
          (Use electron --trace-warnings ... to show where the warning was created)
          [10.07.2023 02:06.43.861] [ERROR] (node:7189) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by thr>MESA-LOADER: failed to retrieve device information
        S 1 Reply Last reply Jul 15, 2023, 11:16 AM Reply Quote 0
          sdetweil @vpanse
          @vpanse see the post directly above your
          • V Offline
            vpanse
            I already did try that , it does not work for modules
            https://github.com/mykle1/MMM-BMW-CC and
            https://github.com/E3V3A/MMM-FlightsAbove.
            Still getting error as below.
            require stack:
            • /home/vinayak/MagicMirror/modules/MMM-BMW-CC/node_helper.js
              at n._resolveFilename (node:electron/js2c/browser_init:2:117469)
              at Object. (/home/vinayak/MagicMirror/modules/MMM-BMW-CC/node_helper.js:8:17)
              at loadModule (/home/vinayak/MagicMirror/js/app.js:180:19)
              [16.07.2023 18:40.43.267] [ERROR] (node:989) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejectin>MESA-LOADER: failed to retrieve device information
              MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/arm-linux-gnueabihf/dri:$${ORIGIN}/dri:/usr/lib/dri)
              MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/arm-linux-gnueabihf/dri:$${ORIGIN}/dri:/usr/lib/dri)
            S 1 Reply Last reply Jul 16, 2023, 6:40 PM Reply Quote 0
              sdetweil @vpanse
              @vpanse see
              K 1 Reply Last reply Jul 16, 2023, 9:37 PM Reply Quote 0
              • K Offline
                karsten13 @sdetweil
                or forgot to run npm install in the module folder of MMM-FlightsAbove
                • V Offline
                  vpanse
                  I did many changes suggested in Form but still little different issue
                  [17.07.2023 05:21.57.786] [ERROR] (node:932) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘fetch-ponyfill’
                  Require stack:
                    at Object. (/home/vinayak/MagicMirror/modules/MMM-FlightsAbove/lib/radar.js:36:17)
                    [17.07.2023 05:21.57.787] [ERROR] (node:932) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a c>
                  S 1 Reply Last reply Jul 17, 2023, 11:34 AM Reply Quote 0
                    sdetweil @vpanse
                    @vpanse said in I'm getting error -MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: Permission denied:
                    yes, unfortunately this module does not document in it’s package.json all the library dependencies it requires.
                    so, for each one you have to do
                    npm install xxxxx
                    where xxxxx is the missing library from the message above (in single quotes)
                    the module hasn’t been updated since 2018, so no idea if it still works after all that
                    your other post was marked as spam, which I cannot override
                    • V Offline
                      vpanse
                      Excellent, It works now . thanks a lot ,
