    MMM-CalendarEXT2 mulitple time zones
    6 Posts 4 Posters 952 Views 4 Watching
      pastormingle
      I’ve been runing the EXT2 calendar for sometime now… I have 2 google calendars and one outlook calendar that it pulls data from to displays on my MM. The issue i am having is when meeting are set in a regions outside of mine it use that person region… Say India time and its 12 hours different from what i am on… Do you know how to change it to use only local time.
      BKeyportB M 2 Replies Last reply Reply Quote 0
      • BKeyportB Offline
        BKeyport Module Developer @pastormingle
        I don’t remember if there’s an option for that in the abandoned EXT2, I don’t believe so.
        However, if you’d switch to EXT3 and/or EXT3Agenda as appropriate, you’d get full support from MMRize and sdetweil, who are the maintainers of the two modules used (EXT3/EXT3Agenda and calendar). Bonus, it’s a much easier config to do the same things.
          sdetweil @BKeyport
          @BKeyport I am not a maintainer of any of @MMRIZE beautiful modules
          • BKeyportB Offline
            @sdetweil You maintain the calendar module it’s reading from, no?
              sdetweil @BKeyport
              @BKeyport only the data parser.
              he does all the magic
                MMRIZE @pastormingle
                @pastormingle
                “forceLocalTZ” option in the calendar might be.
                https://github.com/MMM-CalendarExt2/MMM-CalendarExt2/blob/main/docs/Configuration/Calendar.md#default-values-of-calendar
                But not sure it would fix your issue.
