    MM as Desktop background (for MacOS / Linux)
    7 Posts 4 Posters 3.6k Views 5 Watching
      MMRIZE
      Though I’m not using Windows anymore, I always envy the Rainmeter despite its ridiculous instability and low performance.
      10 minutes ago, suddenly I remembered the idea that the Electron could be used for that purpose. That means I can use MM as a desktop wallpaper. So I did.
      Here’s how to do it.
      For disclaimers, Electron cannot hook Windows Desktop by itself. There are a few solutions for that, but I don’t want to hack MM heavily. For Windows, use Rainmeter.
      custom.css
      :root {
        --color-text: #DDD;
        --color-text-dimmed: #BBB;
        --color-text-bright: #fff;
        --color-background: rgba(0, 0, 0, 0);
       /* make fonts color brighter */
        --font-size: 2vh;
        --font-size-small: 0.75rem;
        --gap-body-top: 20px;
        --gap-body-right: 120px;
        --gap-body-bottom: 20px;
        --gap-body-left: 40px;
      /* adjust margin for your screen */
        text-shadow: 2px 2px 5px #000000; /* make text more readable on the background image */
      config.js
      In the case of Linux, some options might need to be modified.
      electronOptions: {
        x: 1920,
        y: -320,
        width: 3360,
        height: 1892,
        width: 1920,
        height: 1200,
        fullscreen:  false,
        backgroundColor: '#00000000',
        titleBarStyle: 'none',
        frame: false,
        type: 'desktop',
        hasShadow: false,
        transparent: true,
        resizable:   false,
      • width, height : Your screen resolution
      • x, y : position offset from 0, 0 for the left-upper corner of MM screen.
      If you are using multi-screen like this and you want to place MM to secondary monitor;
      You can adjust x and y to move MM to the secondary monitor.
      js/electron.js
      I’m not sure this is necessary. but when above modification is not enough, try this.
      // line 22 of electron.js
      // Change this line
      app.commandLine.appendSwitch("autoplay-policy", "no-user-gesture-required");
      // to this.
      app.commandLine.appendSwitch("autoplay-policy", "no-user-gesture-required", "enable-transparent-visuals");
      This needs source modification. I already made a PR to enable customizing electron switches, but this online source modification is needed before acceptance of that PR.
      I tested it on macOS, and I believe it will be working on Linux also. Have good luck.
        sdetweil @MMRIZE
        @mmrize u can pass the electronOptions in config.js
          MMRIZE @sdetweil
          @sdetweil said in MM as Desktop background (for MacOS / Linux):
          Yup, I did it so of course. But the switch (not electronOptions) is not customizable in MM.
            sdetweil @MMRIZE
            @mmrize yes, correct.
              boblewis
              @MMRIZE why your weather app is overlapping with other apps?
                MMRIZE @boblewis
                @boblewis ??? I cannot catch your words. More details?
                ankonaskiff17A 1 Reply Last reply Reply Quote 0
                • ankonaskiff17A Offline
                  ankonaskiff17 @MMRIZE
                  @MMRIZE I think he sees icons in front of the weather module, doesn’t realize MM is the desktop
