    How I got my Magic Mirror working on a Raspberry Pi 0 (zero)
    raspberry pipi0zeropizeropi1
    204 Posts 47 Posters 671.1k Views 47 Watching
    • W
      Wieber @SebTota
      @SebTota I might have received a letter from Hogwarts once, but I would have to kill you if I told you ;)
      Have fun with your mirror!
        SebTota
        @Wieber Not to bother you much more but i still have one more question. When i try to access the MM like you said to change the config file i get an error.
        pi@raspberrypi:~ $ /MagicMirror/Config/config.js.sample
        -bash: /MagicMirror/Config/config.js.sample: No such file or directory
        any idea?
        W 1 Reply Last reply
        • W
          Wieber @SebTota
          @SebTota Uuhm, can’t check right now, but if I recall correctly the directory is /home/MagicMirror/Config/config.js.sample . It’s probably due to an error I made somewhere along the line (not installing in the preferred directory)
            SebTota @Wieber
            @Wieber I have a feeling that there was a problem installing MagicMirror because my SSH disconnected but I just continued through the steps. Do you think it would help to just run the command again to install the program or is there a way to update it and it would find if there are any files missing?
            • W
              Wieber @SebTota
              @SebTota Well I think there isn’t really anything wrong with your Mirror, since it shows the default page for when the Config.js is missing.
              What you could do is search for the ‘config.js.sample’ file with the following command:
              find -name “config.js.sample”
              I haven’t used this command myself, but more info on it is found here: https://www.digitalocean.com/community/tutorials/how-to-use-find-and-locate-to-search-for-files-on-a-linux-vps
              Edit: a loss in SSH connection doesn’t necessarily means that your Pi messed anything up, just like your PC can still run when your monitor disconnects. Although a connection loss could have a lot of reasons that would also mess up the Pi ofc ;)
              S 2 Replies Last reply
                SebTota @Wieber
                  SebTota @Wieber
                    SebTota
                      SebTota
                        SebTota
                        Alright after some time I figured it out.
                        cd MagicMirror
                        cd config
                        sudo nano config.js
                        then the file should open.
                        This is for the noobs like me who might need that.
                        bheplerB 1 Reply Last reply
                        • bheplerB
                          bhepler Module Developer @SebTota
                          @SebTota What @Wieber has forgotten to mention is that the config.js.sample file is the default configuration that is included with the mirror software. The mirror software itself is looking for config.js. So the step that is missing is to copy the sample to the end file name. Once you have it copied over, this will become the file that you use to change your mirror’s behavior.
                          You copy the file with this command: cp ~/MagicMirror/config/config.js.sample ~/MagicMirror/config/config.js
                          You can then edit the config.js command as you have already discovered: nano ~/MagicMirror/config/config.js Nano is the editor, config.js is the file you are editing.
                            piziie
                            Great guide!
                            I have a quick question though. When my pi zero boots, it boots into a command line where i can see the modules are loading. It ends with
                            Ready to go! Please point your browser to: http://localhost:8080
                            { [Error: listen EADDRINUSE :::8080]
                              code: 'EADDRINUSE',
                              errno: 'EADDRINUSE',
                              syscall: 'listen',
                              address: '::',
                              port: 8080 }
                            any ideas what causes this and how it can be fixed?
                            S bheplerB 2 Replies Last reply
                              SebTota @piziie
                              @piziie I believe my pi had the same response but after a few seconds it boots into the browser and shoes the mirror and works fine. Is it the same with you?
                              P 1 Reply Last reply
                                piziie @SebTota
                                @SebTota
                                unfortunately no, it remains on the terminal. When i open a browser and go to localhost:8080 it does appear to be working so i know the MM and modules load correctly.
                                It seems to be an issue with the midori start script?
                                /home/pi/startMidori.sh
                                #!/bin/sh
                                xset -dpms # disable DPMS (Energy Star) features.
                                xset s off # disable screen saver
                                xset s noblank # don’t blank the video device
                                matchbox-window-manager &
                                unclutter &
                                midori -e Fullscreen -a http://localhost:8080
                                My /home/pi/start.sh script:
                                #!/bin/bash
                                node serveronly &
                                sleep 45
                                sudo xinit /home/pi/startMidori.sh
                                and the last line in .bashrc
                                /home/pi/start.sh
                                another side note- on boot i get this error:
                                (EE)
                                Fatal server error:
                                (EE) Server is already active for display 0
                                        If this server is no longer running, remove /tmp/.X0-lock
                                        and start again.
                                (EE)
                                (EE)
                                Please consult the The X.Org Foundation support
                                         at http://wiki.x.org
                                 for help.
                                (EE)
                                Starting MagicMirror: v2.1.0
                                Loading config ...
                                Loading module helpers ...
                                XIO:  fatal IO error 11 (Resource temporarily unavailable) on X server ":0"
                                      after 6 requests (6 known processed) with 0 events remaining.
                                could this be the source of the error?
                                • bheplerB
                                  bhepler Module Developer @piziie
                                  @piziie In my experience, this means that the mirror process is already running and you’ve attempted to start it again. Are you using PM2 to manage the mirror process? Is it possible that two of your scripts are both trying to start the mirror? Have you changed any init settings to auto-boot the mirror?
                                    SebTota @piziie
                                    @piziie if you want I can post my image and you can write my image to your sd
                                      piziie @bhepler
                                      @bhepler pm2 doesnt appear to be installed, however i do have npm installed. Could that cause a conflict?
                                      Any way to the sources from which start the mirror process is starting?
                                      Also i may have created a conflict by following the OP steps as well as the steps outlined by @kobie
                                      Also…
                                      Instead of adding start.sh to the end of .bashrc, it’s better practice to have the
                                      script run automatically on start-up. To do this:
                                      sudo mv /home/pi/start.sh /etc/init.d/startMagicMirror.sh
                                      sudo update-rc.d startMagicMirror.sh defaults 100
                                      This moves the script to the standard location for start-up scripts and tells the
                                      system to run it after each boot.
                                      I went back and deleted the startMagicMirror.sh file, however. Does update-rc.d need to be rolled back as well?
                                      • bheplerB
                                        @piziie That sounds right. Without tracing too closely, it sounds like your startMagicMirror.sh scripts and your start.sh script are both starting the mirror process.
                                          piziie @bhepler
                                          @bhepler after deleting startMagicMirror.sh the same problem exists
                                          • bheplerB
                                            @piziie After you deleted the startMagicMirror.sh did you run the update command you quoted?
                                            sudo update-rc.d startMagicMirror.sh remove
                                            (more information at the the update-rc man page)
                                            • 10
                                            • 11
                                            • 2 / 11
