    How I got my Magic Mirror working on a Raspberry Pi 0 (zero)
    raspberry pipi0zeropizeropi1
    204 Posts 47 Posters 666.6k Views 47 Watching
      SebTota
        SebTota
        Alright after some time I figured it out.
        cd MagicMirror
        cd config
        sudo nano config.js
        then the file should open.
        This is for the noobs like me who might need that.
          bhepler Module Developer @SebTota
          @SebTota What @Wieber has forgotten to mention is that the config.js.sample file is the default configuration that is included with the mirror software. The mirror software itself is looking for config.js. So the step that is missing is to copy the sample to the end file name. Once you have it copied over, this will become the file that you use to change your mirror’s behavior.
          You copy the file with this command: cp ~/MagicMirror/config/config.js.sample ~/MagicMirror/config/config.js
          You can then edit the config.js command as you have already discovered: nano ~/MagicMirror/config/config.js Nano is the editor, config.js is the file you are editing.
            piziie
            Great guide!
            I have a quick question though. When my pi zero boots, it boots into a command line where i can see the modules are loading. It ends with
            Ready to go! Please point your browser to: http://localhost:8080
            { [Error: listen EADDRINUSE :::8080]
              code: 'EADDRINUSE',
              errno: 'EADDRINUSE',
              syscall: 'listen',
              address: '::',
              port: 8080 }
            any ideas what causes this and how it can be fixed?
            S B 2 Replies Last reply Reply Quote 0
              SebTota @piziie
              @piziie I believe my pi had the same response but after a few seconds it boots into the browser and shoes the mirror and works fine. Is it the same with you?
                piziie @SebTota
                @SebTota
                unfortunately no, it remains on the terminal. When i open a browser and go to localhost:8080 it does appear to be working so i know the MM and modules load correctly.
                It seems to be an issue with the midori start script?
                /home/pi/startMidori.sh
                #!/bin/sh
                xset -dpms # disable DPMS (Energy Star) features.
                xset s off # disable screen saver
                xset s noblank # don’t blank the video device
                matchbox-window-manager &
                unclutter &
                midori -e Fullscreen -a http://localhost:8080
                My /home/pi/start.sh script:
                #!/bin/bash
                node serveronly &
                sleep 45
                sudo xinit /home/pi/startMidori.sh
                and the last line in .bashrc
                /home/pi/start.sh
                another side note- on boot i get this error:
                (EE)
                Fatal server error:
                (EE) Server is already active for display 0
                        If this server is no longer running, remove /tmp/.X0-lock
                        and start again.
                (EE)
                (EE)
                Please consult the The X.Org Foundation support
                         at http://wiki.x.org
                 for help.
                (EE)
                Starting MagicMirror: v2.1.0
                Loading config ...
                Loading module helpers ...
                XIO:  fatal IO error 11 (Resource temporarily unavailable) on X server ":0"
                      after 6 requests (6 known processed) with 0 events remaining.
                could this be the source of the error?
                  bhepler Module Developer @piziie
                  @piziie In my experience, this means that the mirror process is already running and you’ve attempted to start it again. Are you using PM2 to manage the mirror process? Is it possible that two of your scripts are both trying to start the mirror? Have you changed any init settings to auto-boot the mirror?
                    SebTota @piziie
                    @piziie if you want I can post my image and you can write my image to your sd
                      piziie @bhepler
                      @bhepler pm2 doesnt appear to be installed, however i do have npm installed. Could that cause a conflict?
                      Any way to the sources from which start the mirror process is starting?
                      Also i may have created a conflict by following the OP steps as well as the steps outlined by @kobie
                      Also…
                      Instead of adding start.sh to the end of .bashrc, it’s better practice to have the
                      script run automatically on start-up. To do this:
                      sudo mv /home/pi/start.sh /etc/init.d/startMagicMirror.sh
                      sudo update-rc.d startMagicMirror.sh defaults 100
                      This moves the script to the standard location for start-up scripts and tells the
                      system to run it after each boot.
                      I went back and deleted the startMagicMirror.sh file, however. Does update-rc.d need to be rolled back as well?
                        @piziie That sounds right. Without tracing too closely, it sounds like your startMagicMirror.sh scripts and your start.sh script are both starting the mirror process.
                          piziie @bhepler
                          @bhepler after deleting startMagicMirror.sh the same problem exists
                            @piziie After you deleted the startMagicMirror.sh did you run the update command you quoted?
                            sudo update-rc.d startMagicMirror.sh remove
                            (more information at the the update-rc man page)
                              piziie @bhepler
                              @bhepler i have run that command, same issue persists.
                              Could it have something to do with VNCserver?
                                Mar
                                I have MM2 running quite well on my Pi3 but I’d like to free up the Pi3 and use my zero for the MM2. Has anyone seen any real downsides to using the Pi Zero over the Pi3?
                                • W
                                  Wieber @Mar
                                  @Mar compared to the Pi3 the processing power is way lower, so from that point of view some modules wouldnt work properly. That said, for the ‘stock’ modules and API driven modules it should all work fine. Besides that the installing process is a bit more difficult as you can read above ;)
                                    Mar @Wieber
                                    @Wieber Thanks, I would be using the Button module, PIR sensor module, Wunderlist module, and I want to try adding the Alexa module once i transfer it over to the Pi?
                                    Another thing I was thinking would be to integrate this into my openhab setup to bring in the status of various sensors.
                                      SebTota
                                      I have another question. How could i get into the terminal when the pi goes right into the browser? I cant ssh into it for some reason so is there anyway to exit the browser and go into the terminal?
                                        @SebTota Try CTRL+ALT+F2 (note: I have not tried this myself, but it works on other systems I use)
                                          SebTota
                                          Yet another question. I tried all other forums but i cant find my answer so I figured id ask here. If i have jessie lite with just the terminal, can I open up a file explorer to copy and paste a folder. I need to copy two folders over but I cant figure out how to do it.
                                          • Y
                                            yawns Moderator @SebTota
                                            @SebTota
                                            cp -r source destination
                                            • 10
                                            • 11
                                            • 2 / 11
