    Magic Dashboard & Whiteboard
    10 Posts 7 Posters 6.2k Views 7 Watching
      sum2023
      The solution is a vertical 23 inch display (23" LG IPS231P FullHD) and a whiteboard of the same size.
      They are built together in a wooden frame.
      A Raspberry pi4 runs MagicMirror, it is in the frame behind the display, it is controlled remotely by VNC Viewer.
      I use the following modules
      Clock
      Calendar
      Weather
      MMM-AutoDimmer
      MMM-Namnsdag
      MMM-Moon
      MMM-Pinfo
      MMM-homeassistant-sensors
      MMM-Worldclock
      MMM-HTMLSnippet
      MMM-EmbedYoutube
      MMM-CalendarExt3
      with 7 different google calendars
      - Family calendar
      - Mom’s calendar
      - Dad’s calendar
      - the daughter’s calendar
      - the son’s calendar
      - the son’s soccer team
      - birthdays
      Then also some that are currently disabled:
      MMM-HumanClock
      MMM-PlaceInfo
      MMM-EmbedURL
      MMM-Skolmaten
      MMM-EyeCandy
      MMM-EARTH
      MMM-Wallpaper
      Thanks to all who developed the great modules and keep them alive! :clapping_hands: :grinning_face_with_smiling_eyes: :thumbs_up_medium-light_skin_tone:
      B T 2 Replies Last reply Reply Quote 6
      • zdenekZ
        zdenek
        @sum2023 said in Magic Dashboard & Whiteboard:
        MMM-CalendarExt3
        amazing - u did something with CSS? Or how did u get agenda view (MMM-CalendarExt3) over all width of screen?
        thanks
        • BKeyportB
          BKeyport Module Developer @zdenek
          @zdenek That’s either bottom_bar or CSS to stretch it.
          zdenekZ 1 Reply Last reply Reply Quote 0
          • zdenekZ
            zdenek @BKeyport
            @BKeyport ok, thanks
              bhepler Module Developer @sum2023
              @sum2023 - Excellent idea. And great execution.
              • T
                themoe
                Very nice solution!
                I was thinking about a very similar setup. But I would like to have very thin or no borders between the screen and the whiteboard.
                And is there a white background scene for magic mirror with dark font colours?
                Best case would be the white of the screen is the same white of the whiteboard.
                  bhepler Module Developer @themoe
                  @themoe - I’m pretty sure one of the forum members has a custom CSS file that does a white background. If you check out that portion of the forum you can probably find it.
                  karsten13K BKeyportB 2 Replies Last reply Reply Quote 0
                  • karsten13K
                    karsten13 @bhepler
                    https://forum.magicmirror.builders/topic/12815/bright-ui?page=1
                    https://forum.magicmirror.builders/topic/13108/css-experiments-for-newbies
                    • BKeyportB
                      BKeyport Module Developer @bhepler
                      @themoe Most of what you need is the root section of main.css, which you can modify by adding it to custom.css
                      Here’s the defaults, adjust as you desire. However, I will warn you, you may also have to do it on a module by module basis - many modules don’t use these defaults for even their base text.
                      :root {
                        --color-text: #999;
                        --color-text-dimmed: #666;
                        --color-text-bright: #fff;
                        --color-background: #000;
                        --font-primary: "Roboto Condensed";
                        --font-secondary: "Roboto";
                        --font-size: 20px;
                        --font-size-xsmall: 0.75rem;
                        --font-size-small: 1rem;
                        --font-size-medium: 1.5rem;
                        --font-size-large: 3.25rem;
                        --font-size-xlarge: 3.75rem;
                        --gap-body-top: 60px;
                        --gap-body-right: 60px;
                        --gap-body-bottom: 60px;
                        --gap-body-left: 60px;
                        --gap-modules: 30px;
                      • T
                        ToneStrife @sum2023
                        @sum2023 Do you mind sharing your CSS code or config? I’m looking to do somethign similar but a newbie here
