    MMM-CalendarExt3
    689 Posts 82 Posters 3.2m Views 86 Watching
      MMRIZE @CurlyQ12391
      @CurlyQ12391
      There is the selector “.weekday_N”(0-6). ATM I cannot remember exactly but “weekday_0” probably is “Sunday” (or Monday), anyway try it.
      https://github.com/MMRIZE/MMM-CalendarExt3#styling-with-css
        CurlyQ12391 @MMRIZE
        @MMRIZE,
        That did the trick! Adding “weekday” prevented the image from populating on multiple cells :) This module is by far my favorite because of how customizable it is.
        /* Labor Day - First Monday in September */
        .CX3 .month_9.date_1.weekday_1,
        .CX3 .month_9.date_2.weekday_1,
        .CX3 .month_9.date_3.weekday_1,
        .CX3 .month_9.date_4.weekday_1  {
          background-image: url("/modules/MMM-CalendarExt3/Backgrounds/LaborDay");
          background-position: center center;
          background-size: 60%;
          background-repeat: no-repeat;
        The only one I haven’t been able to figure out is Easter Sunday because it is the first between March 22 and April 25. I dont believe CSS can handle that type of logic, maybe JS but thats a little too complex for me. For now I will just leave Easter off the calendar.
          MMRIZE @CurlyQ12391
          @CurlyQ12391
          I think it is possible with “manipulateDateCell”. I will show example after my return from a business trip in a few days.
            MMRIZE @CurlyQ12391
            @CurlyQ12391
              module: "MMM-CalendarExt3",
              position: "bottom_bar",
                mode: 'month',
                manipulateDateCell: (dom, events) => {
                  let date = new Date(+dom.dataset.date)
                  if (date.getMonth() == 8 && date.getDate() == 2) { // specific cell by absolute date
                    dom.classList.add('specialHoliday')
                    dom.style.backgroundColor = 'red'
                    // do whatever you want.
                  if (events.some(e => e.title.search("Gelber") > -1)){ // specific cell by event
                    dom.classList.add('specialEvent')
                    dom.style.backgroundColor = 'yellow'
            • N
              nekreg9
              How can I delay the start of the MMM-CalendarExt3 module? I have the default calendar module showing and I can see the 3 calendars load events into it. The problem is CalendarExt3 starts while the calendars are still loading. I changed the refreshInterval to more frequent to deal with that, but really a delay start would be more efficient.
              I supposed this would only be a problem while I am troubleshooting.
                MMRIZE @nekreg9
                @nekreg9
                There is a configurable option “waitFetch”.
                But I doubt your real issue would be that. Because, CX3 starts rendering after one calendar which has at least one event have fetched successfully. (and in a “waitFetch”, no more calendar is fetched)
                So if your CX3 starts late, It means your events source provider(usually default calendar module) might have timing issue to fetch calendars(e.g. too frequent fetch cycles or something else)
                • K
                  Kaisies 0
                  Is it at all possible to alter the grid to only divide the screen into 5 sections? I was able to alter code to only show m-f, but the sat and sun sections are still there. Just completely blank. For the life of me I can’t figure out where in the code it sets this part up.
                    MMRIZE @Kaisies 0
                    @Kaisies-0
                      MMRIZE @Kaisies 0
                      @Kaisies-0
                      Anyway,
                      For the firstDayOfWeek: 1 (Week starts from Monday), It could be achieved like below;
                      .CX3 .weekGrid {
                        grid-template-columns: repeat(5, [cell-start] 1fr [cell-end]) 0fr 0fr;
                      .CX3 .weekday.weekday_6,
                      .CX3 .weekday.weekday_0 {
                        display: none;
                      .CX3 .cell.weekday_6,
                      .CX3 .cell.weekday_0 {
                        display: none;
                      This will work.
                      But for the firstDayOfWeek:0 or another case, .weekGrid should be adjusted more heavily. And not sure side-effects.
                      • BKeyportB
                        BKeyport Module Developer @MMRIZE
                        @MMRIZE I wanna do things a little different (of course) - what I’d like is to have CX3 display the calendar symbol only. No title, preferably horizontally. I can get the title out of the way, but the rest of it I’m not quite sure how - for some reason I’m having a hard time deconstructing how you build.
                        Thanks!
                          MMRIZE @BKeyport
                          @BKeyport
                          Is this what you want?
                            MMRIZE @BKeyport
                            @BKeyport
                            What a coincidence.
                            Yesterday, a user asked me how to manipulate day-cell and remove events together at the same time. It is ideally the same with your purpose.
                            To reach your goal; 1) extracting an icon from an event and 2) putting it into the daycell would be needed.
                            However, manipulateDayCell is executed after all events processes are done, so it cannot be achieved with CX3 alone. With manipulateDayCell, you can extract icons and inject them into the daycell, but you cannot remove original events together easily.
                            With MMM-ModuleMonkeyPatch, you can remove events after rendering (before revealing)
                            /* In MMM-CalendarExt3 config */
                              manipulateDateCell: (cellDom, events) => {
                                let body = cellDom.querySelector('.cellBody')
                                Array.from(events).forEach((e) => {
                                  if (Array.isArray(e.symbol) && e.symbol.length > 0) {
                                    let icon = document.createElement('span')
                                    icon.className = e.symbol
                                    body.appendChild(icon)
                                    icon.style.color = e.color
                              maxEventLines: 1,
                            /* MMM-ModuleMonkeyPatch */
                              module: "MMM-ModuleMonkeyPatch",
                                patches: [
                                    method: "getDom",
                                    patch: function (original, args) {
                                      let dom = original(args)
                                      let target = Array.from(dom.querySelectorAll('.event')) || []
                                      target.forEach((e) => {
                                        e.style.display = 'none'
                                      return dom
                            These codes are just concept-proof. There are many holes like overflowed events, order of events, … I bet you can improve codes for your purpose.
                            • BKeyportB
                              @MMRIZE that would be perfect, yes.
                              • BKeyportB
                                @MMRIZE actually, I don’t need to extract - the symbols are set by default Calendar app, so I’d be using “useSymbol:True” to get them only.
                                • X
                                  XDmToter
                                  I am having trouble integrating MMM-CalendarExt3 with MMM-GoogleCalendar.
                                  I’m not sure what else is required other than adding a “name” to the Google Calendar and then listing that in the “calendarSet” parameter in CalendarExt3.
                                  Can anyone point out what I am missing?
                                  Here is my config:
                                              module: 'MMM-GoogleCalendar',
                                              header: "Family Calendar",
                                                  maximumEntries: 4,
                                                  broadcastPastEvents: true,
                                                      symbol: "calendar-week",
                                                      calendarID: "XXXXXXXXXXXXXXXXXXXX@group.calendar.google.com",
                                              title: "Family Calendar",
                                                  mode: "week",
                                                  instanceId: "basicCalendar",
                                                  calendarSet: ['famCal'],
                                  I see the List view from MMM-GoogleCalendar, but I just get a blank calendar from MMM-CalendarExt3
                                    MMRIZE @XDmToter
                                    @XDmToter
                                    Read this. https://github.com/MMRIZE/MMM-CalendarExt3#compatible-with-randombrainstormermmm-googlecalendar
                                    By the way, this is a pure question.
                                    Google Calendar provides iCAL format(.ics), so the default calendar module can also parse it. Why people use MMM-GoogleCalendar instead of the default calendar? Is there any special thing?
                                    I ask this because one of the most frequently asked issues is how to use with MMM-GoogleCalendar.
                                    X 1 Reply Last reply Reply Quote 0
                                      MMRIZE @XDmToter
                                      @XDmToter
                                      Anyway, I requested PR of MMM-GoogleCalendar to solve this incompatible broadcasting. When @randomBrainstorm adopts the PR, this issue will be solved.
                                      • X
                                        XDmToter @MMRIZE
                                        @MMRIZE Thank you for your reply. As I understand it, in order to use an ICal URL from Google Calendar, you have to make your calendar Public. Using MMM-GoogleCalendar is Authenticated using an API Token, so your calendar does Not need to be public.
                                        I tried adding the “preProcessor” settings, but I still get a blank calendar. Does this get added to the “config” section, or the “module” section? I put it inside the config array.
                                                        mode: "week",
                                                        preProcessor: (e) => {
                                                            if (e.start?.dateTime) {
        e.startDate = new Date(e.start.dateTime).valueOf()
                                                            } else if (e.start?.date) {
        e.startDate = new Date(`${e.start.date}T00:00:00`).valueOf()
                                                            if (e.end?.dateTime) {
        e.endDate = new Date(e.end.dateTime).valueOf()
                                                            } else if (e.end?.date) {
        e.endDate = new Date(`${e.end.date}T00:00:00`).valueOf()
                                                            e.title = e.summary
                                                            e.fullDayEvent = (e.start?.date) ? true : false
                                                            return e
                                        M G 2 Replies Last reply Reply Quote 0
                                          MMRIZE @XDmToter
                                          @XDmToter
                                          Your configuration seems all right unless you may be missing some brackets matching or commas at the end of the continuous module definitions.
                                          In MM screen, Ctrl+Shift+i will open dev console. You may see suspicious error messages if they happen.
                                          • G
                                            gonzonia @XDmToter
                                            @XDmToter
                                            There’s a way to get an iCal URL without making it public. I see this in my “Settings and Sharing” section of Google Calendar. Screenshot 2023-10-11 at 2.28.40 PM.png
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 34
                                            • 35
                                            • 18 / 35
