    White Screen after starting Magic Mirror
    7 Posts 3 Posters 3.3k Views 2 Watching
      Squirrel
      I try to build my own Module. When i start the MagicMirror now i get a blank white screen and i cant Quit the mirror no more. The only way to quit is a restart. but that sucks because i want to read the Terminal. When i Open Terminal then i get a new blank Terminal. How can i Quit the Terminal or how can i see my other Open Windows behind the Mirror?
      • yawnsY Offline
        yawns Moderator
        Are you working on your raspberry directly? You should be able to switch with alt + tab.
        As an alternative you could run node serveronly, open the browser on your own and go to http://localhost:8080
          Squirrel
          Yes i work on raspberry directly. Sadly i did mot found a way to test my work on my mac!? Ok thanks! alt + tab is working. But it still s**** a bit when i have to restart my raspberry after ever fault i did…
          • brobergB Offline
            broberg Project Sponsor
            Ctrl+q quits the mirror, ctrl+r reloads the page.
              Squirrel
              No. Ctrl + q is not working… It works when the mirror is running but with my white screen it is now more possible to quit it with this command…
                Squirrel
                i got it! When i change with alt + tab to the Terminal i can close the Terminal and that also Quits my mirror! Thanks!
                • yawnsY Offline
                  yawns Moderator @Squirrel
                  @Squirrel
                  Yes, I forgot to mention that. You can also press ctrl + c in console to kill the mirror process. So you don’t have to close the terminal every time
