Solved Upgrade errors?
@sdetweil I use your backup scripts on my main mirror. My dev machine I did not backup. Will teach me for next time. :crying_face:
@sdetweil turns out there was an update to MMM-Wallpaper that missed due to all the bugs in upgrading. š
@BKeyport yes I saw that too
@mumblebaj My scripts donāt depend on node or anything else theyāre all bash scripts. So if you havenāt deleted anything you can still run the back up there and be able to restore it later
@BKeyport said in Upgrade errors?:
ā¦just in case this might be interesting for anyone: I had the same problems on my Raspberry Pi 4 Model B (Rev 1.2) with buster (armv71).
- node 20 gave me the `GLIBCXX_3.4.26ā not found (required by node) error
- I had the āfailed to load swrast driverā
I checked my modules, and the solution for my MM was (thanks to @sdetweil and @BKeyport here):
- installing node 18 (I did it manually like mentioned here)
- removing āDWD Warn Weatherā (which caused the swrast error) from config.js
Now MagicMirror v2.25.0 is up and running! :beaming_face_with_smiling_eyes:
Thank you for all your effort and your tireless support!
May the code be with you.
-kai -
@sdetweil - Iām not sure this the correct topic for my error, so if not we can move it - but I am having the issues described above, but on an initial install [as opposed to an upgrade]. This is on a freshly created VirtualBox VM using the current RaspbianOS version of Debian, using Samās install script.
After a long series of lines indicating it was setting up various node packages, the install.log file ends with a message that node failed to install:
added 1 package, and audited 2 packages in 1s found 0 vulnerabilities installing on bullseye [96minstalling correct version of node and npm, please wait[90m installing : node-v20.8.0 mkdir : /usr/local/n/versions/node/20.8.0 fetch : https://nodejs.org/dist/v20.8.0/node-v20.8.0-linux-x64.tar.xz copying : node/20.8.0 installed : (with npm ) Note: the node command changed location and the old location may be remembered in your current shell. old : /usr/bin/node new : /usr/local/bin/node If "node --version" shows the old version then start a new shell, or reset the location hash with: hash -r (for bash, zsh, ash, dash, and ksh) rehash (for csh and tcsh) node failed to install, exiting
Thoughts??
@JohnGalt can u send me the install.log fileā¦
I have a vm of raspi x86 as wellā¦
this same userid at gmailā¦ thx
@sdetweil - Thanks, the log file is on its way to youā¦
@sdetweil - Thanks for the help here and offline. My problem is solved, and for the sake of others following is the resolution.
Problem: MagicMirror install script outputs node.js errors on new RaspbianOS install running under VirtualBox.
Diagnosis [by sdetweil]: āso, the problem is that the intel raspian is a hybrid, x86_64 kernel with a i386 user runtime.
and they stopped making a nodejs for i386 after node 12āSolution: Rebuilt the virtual machine using Ubuntu instead of RaspbianOS. [Iām sure any Debian or other Linux distribution would work just fineā¦]
Thanks again - I can now use this as a dev machine and spare myself the risks associated with fiddling with the production machine!
