    Upgrade errors?
    35 Posts 9 Posters 17.7k Views 10 Watching
    • mumblebajM
      @sdetweil Thanks Sam. A bunch of missing libs but all working again.
      Now to add my modules I had running on the dev machine. The joy. :-)
        sdetweil @mumblebaj
        @mumblebaj always backup
        I have one that makes a small image
        https://github.com/sdetweil/MagicMirror-backup-restore
        mumblebajM 1 Reply Last reply
        • mumblebajM
          @sdetweil I use your backup scripts on my main mirror. My dev machine I did not backup. Will teach me for next time. :crying_face:
          • BKeyportB
            @sdetweil turns out there was an update to MMM-Wallpaper that missed due to all the bugs in upgrading. 😉
            S kaiK 2 Replies Last reply
              sdetweil @BKeyport
              @BKeyport yes I saw that too
                sdetweil @mumblebaj
                @mumblebaj My scripts don’t depend on node or anything else they’re all bash scripts. So if you haven’t deleted anything you can still run the back up there and be able to restore it later
                • kaiK
                  kai @BKeyport
                  @BKeyport said in Upgrade errors?:
                  …just in case this might be interesting for anyone: I had the same problems on my Raspberry Pi 4 Model B (Rev 1.2) with buster (armv71).
                  • node 20 gave me the `GLIBCXX_3.4.26’ not found (required by node) error
                  • I had the “failed to load swrast driver”
                  I checked my modules, and the solution for my MM was (thanks to @sdetweil and @BKeyport here):
                  • installing node 18 (I did it manually like mentioned here)
                  • removing “DWD Warn Weather” (which caused the swrast error) from config.js
                  Now MagicMirror v2.25.0 is up and running! :beaming_face_with_smiling_eyes:
                  Thank you for all your effort and your tireless support!
                  May the code be with you.
                  -kai
                    JohnGalt
                    @sdetweil - I’m not sure this the correct topic for my error, so if not we can move it - but I am having the issues described above, but on an initial install [as opposed to an upgrade]. This is on a freshly created VirtualBox VM using the current RaspbianOS version of Debian, using Sam’s install script.
                    After a long series of lines indicating it was setting up various node packages, the install.log file ends with a message that node failed to install:
                    added 1 package, and audited 2 packages in 1s
                    found 0 vulnerabilities
                    installing on bullseye
                    installing correct version of node and npm, please wait
                      installing : node-v20.8.0
                           mkdir : /usr/local/n/versions/node/20.8.0
                           fetch : https://nodejs.org/dist/v20.8.0/node-v20.8.0-linux-x64.tar.xz
                         copying : node/20.8.0
                       installed :  (with npm )
                    Note: the node command changed location and the old location may be remembered in your current shell.
                             old : /usr/bin/node
                             new : /usr/local/bin/node
                    If "node --version" shows the old version then start a new shell, or reset the location hash with:
                    hash -r  (for bash, zsh, ash, dash, and ksh)
                    rehash   (for csh and tcsh)
                    node failed to install, exiting
                    Thoughts??
                      sdetweil @JohnGalt
                      @JohnGalt can u send me the install.log file…
                      I have a vm of raspi x86 as well…
                      this same userid at gmail… thx
                        JohnGalt
                        @sdetweil - Thanks, the log file is on its way to you…
                          JohnGalt
                          @sdetweil - Thanks for the help here and offline. My problem is solved, and for the sake of others following is the resolution.
                          Problem: MagicMirror install script outputs node.js errors on new RaspbianOS install running under VirtualBox.
                          Diagnosis [by sdetweil]: “so, the problem is that the intel raspian is a hybrid, x86_64 kernel with a i386 user runtime.
                          and they stopped making a nodejs for i386 after node 12”
                          Solution: Rebuilt the virtual machine using Ubuntu instead of RaspbianOS. [I’m sure any Debian or other Linux distribution would work just fine…]
                          Thanks again - I can now use this as a dev machine and spare myself the risks associated with fiddling with the production machine!
