install upgrade scripts changed for version 2.25 and node 20
@sdetweil Great work Sam. Do we need to run the node script first?
bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/node20_install.sh)”
Or just the normal upgrade process with apply?
After fixing my dev machine I am about ready to give your script a go on my mirror but want to just double check if the node script is still required.
@bdream try this
curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/testit/upgrade-script.sh
@sdetweil I get the whole script shown on the screen
@bdream as it should,
I see there was a problem with the " in the 1st post…
try again, copy/paste that line again
@sdetweil Just to let you know this script worked fine on my Mirror first time. Did not need to run the Node one
@mumblebaj said in install upgrade scripts changed for version 2.25 and node 20:
correct… it is part of the install and upgrade scripts now
did u run the testit branch version?
@sdetweil That is correct and worked first time. Checked the installers log and no errors or issues either. Strange thing though, it had no issue with MMM-NewsAPI either and that works fine.
@sdetweil yes, script is running now :beaming_face_with_smiling_eyes:
MM is not starting automatic, also not after reboot.
But this work finepm2 start 0
@bdream ok
probably missing library on some module
do this
pm2 stop all cd ~/MagicMirror npm start >/somefile.txt 2>&1
wait 15 seconds
in this same terminal window do
ctrl-cthen examine somefile.txt
@sdetweil do I have to use sudo?
And what exactly you mean “then examine somefile.txt”?
