    Weather Forecast: showRainAmount displays in mm even when config.units='imperial'
    9 Posts 3 Posters 4.7k Views 2 Watching
    • F Offline
      fjnorb
      Hello. Brand new MM2 user, I love it. Thank you for taking the time to make it easy to install and configure. I spent weeks last year fighting with Conky to do my own thing and I had this running immediately after installation.
      I have a small issue, however, that I hope someone has solved. Being in the United States, I have units set to ‘imperial’ in my config, and both the Current Weather and Weather Forecast are using imperial units for temperature and other things. But I enabled showRainAmount, and the rain amounts are showing in millimeters.
      Is this a limitation with OpenWeatherMap, a missing conversion in the Weather Forecast module, or a mistake on my part?
      Thanks for any and all assistance.
      • MichMichM Offline
        MichMich
        It seems the “mm” part is hard coded:
        https://github.com/MichMich/MagicMirror/blob/master/modules/default/weatherforecast/weatherforecast.js#L153
        Does it really show the amount in mm? or does it just show the wrong unit?
        • MichMichM Offline
          MichMich
          Hmmm… it seems OpenWeatherMap returns the data in MM no matter which what we request.
          What unit would be preferred? Inch? What notation would you recommend?
          • strawberry 3.141S Offline
            strawberry 3.141 Project Sponsor Module Developer @MichMich
            @MichMich wikipedia tells inch for rain measurements https://en.wikipedia.org/wiki/Rain#Measurement
            if(config.units === "imperial"{
              rainCell.innerHTML = forecast.rain / 25.4 + " in";
            probably need parseFloat() for the data if its a string
            • F Offline
              fjnorb
              It looks like it is returning millimeters. For instance, it says on Tuesday we’re going to get 15mm of rain, that’s about a half an inch, which is much more reasonable than the notion that we’d get 15 inches (381mm) of rain in one day. That sort of thing would be in the news feed, lol.
              • MichMichM Offline
                MichMich
                I pushed an update to the develop branch. Please give it a try.
                • F Offline
                  fjnorb
                  Can you give me a quick idea of how to do that please? Installation was so simple I don’t know how.
                    strawberry 3.141 Project Sponsor Module Developer @fjnorb
                    @fjnorb
                    git fetch
                    git checkout develop
                    npm install
                    • F Offline
                      fjnorb
                      Looks great! Appreciate the quick fix and quick responses, wish more FOSS projects were this professional and responsive.
