    Default Clock wrong after update
    26 Posts 4 Posters 10.9k Views 4 Watching
      sdetweil @BKeyport
      @BKeyport said in Default Clock wrong after update:
      This is what I was correcting.
      I don’t understand…
      what I said was
      this module only adjusts the timezone when
          config :{
              timezone: '??????',
      in its module definition
      NOT when its set in the global configuration, (before modules defined)
      timeFormat: 24,
      	units: "metric",
      	timezone:"UTC",  <---  added this for testing, value NOT set in module config
      so I don’t see what you are ‘correcting’
        drstang @sdetweil
        @sdetweil thats correct - when I changed timezone from ‘null’ to ‘America/New_York,’ the module did not work at all. When I went into the MM config.js and added the timezone line, it worked.
        Which now I realize is also a bit frustrating because one of my modules also shows sunrise/sunset times, and thats still off (EST + 4 hrs).
          drstang @sdetweil
          @sdetweil and also, yes. prior to the upgrade, my general config was NOT set to a TZ prior to the upgrade. I
            sdetweil @drstang
            @drstang said in Default Clock wrong after update:
            correct… as there is no general timezone property
              drstang @sdetweil
              @sdetweil and what also confuses me is if I access the mirror via a web browser, the times are right!
                sdetweil @drstang
                @drstang I understand and agree with that…
                the clock code runs in the browser… so one can only assume that the
                moment code running in the browser is different between instances…
                BKeyportB 1 Reply Last reply Reply Quote 1
                • BKeyportB
                  @sdetweil Curious - are we still using Moment.js in default clock? I’ve heard issues relating with Moment and newer code - I think it might be failing to the point of no return.
                    sdetweil @BKeyport
                    @BKeyport AND it looks like we SHIP a copy… that is PROBABLY the problem
                      drstang @sdetweil
                      @sdetweil Makes sense - and certainly frustrating, as I realize I’m having issues with other modules that show times as well (showing sunrise/sunset, tide charts).
                      Any suggestions on a fix - as it is essentially making my MM unusable since my ‘main’ modules rely on time…
                        sdetweil @drstang
                        @drstang I am away til Tuesday.
                        not sure what a fix would be
                          drstang @sdetweil
                          @sdetweil I am a total novice at JS - but I fixed my modules by adjusting the configs - I incorporated moment-timezone.js and changed my code from ‘.local()’ to ‘.tz(America/New_York)’ Seems moment was having issues with the ‘local’ part of the code.
                          A bit annoying, and I’m sure another way could have been used, but the modules are at least showing correct time now!
                          • BKeyportB
                            BKeyport Module Developer @drstang
                            @drstang Ahh, perhaps a forgotten requirement. It seems clear we need to get rid of Moment.js
