    Automatic checking of all MagicMirror² modules
    83 Posts 9 Posters 103.6k Views 10 Watching
    • KristjanESPERANTOK Offline
      KristjanESPERANTO Module Developer @MMRIZE
      Guys, like I said, the project is in early status! The tests so far should therefore be understood as a proof of concept. Maybe I could have made that a little clearer in my initial post.
      In any case, thanks for the feedback! 😃
      Categorizing the messages would certainly also make sense. Like: critical, warning and information.
      @sdetweil said in Automatic checking of all MagicMirror² modules:
      things that depend of features no longer available in the os like vcgencmd
      Is vcgencmd really no longer available? I don’t have the current OS version yet, but I can’t find any information about removing it in the documentation:
      https://www.raspberrypi.com/documentation/computers/os.html
      If so, what would be the alternative?
      and omxplayer
      Thanks. This is a solid suggestion, just like I was looking for! 😃 I have added this to the check list. There are a handful of modules which contain omxplayer.
      I don’t have a concrete approach for your other suggestions.
      @MMRIZE said in Automatic checking of all MagicMirror² modules:
      There are also wrong checks. (For example, MMM-ModuleMonkeyPatch …
      Ah, I used the module to provoke errors manually. I forgot to remove the folder 🤦. The checks themselves are not wrong.
      dependency checking is information ordinary users …
      Ordinary users are not the target group for this project. The project collects information about modules, the developers can do whatever they want with the information (even ignore it).
      For the core developers it is certainly sometimes interesting (e.g. before breaking changes) which modules still depend on a core functionality.
      it would be better to reveal the last update date or the number of unresolved issues to guess the module’s activation level or popularity
      Those are good points, thank you! I put them on the to-do list.
      Or, if you are going to parse package.json anyway, I think it could be used to organise installation methods, etc.
      Yes, I had already thought about parsing the package.json. What do you mean by “organise installation methods”?
      • karsten13K Offline
        karsten13 @KristjanESPERANTO
        @KristjanESPERANTO
        from the results:
        .gitlab-ci.yml: Change file extention from .yml to .yaml: https://yaml.org/faq.html.
        In this case the .gitlab-ci.yml is the default name of the gitlab pipeline definition file (users can change this but 99% will not) so if you really want to check yml vs. yaml you need a whitelist …
        KristjanESPERANTOK 1 Reply Last reply Reply Quote 1
          @KristjanESPERANTO
          there was a discussion long ago here about 3rd party modules because the current format is very ugly.
          So maybe this could be also a starting point to have the module list as e.g. yaml output with all current stuff and your analysis results. With such an input it would be possible to generate a website (as mentioned in the above issue, examples how this could look were https://tiny-helpers.dev/ or https://www.electronjs.org/apps) …
            KristjanESPERANTO Module Developer @karsten13
            @karsten13 said in Automatic checking of all MagicMirror² modules:
            Yeah, I’ll drop this test for now.
            Interesting direction. I’ll take a look at it 🙂
              @KristjanESPERANTO
              as most modules are hosted on github: You can get such info’s over their api.
              As example you can look at https://api.github.com/repos/MichMich/MagicMirror
              KristjanESPERANTOK 2 Replies Last reply Reply Quote 1
                Wow. That’s really nice! There are certainly some things that can be put to good use.
                After you showed me the examples, I tinkered a bit with a simple frontend (without dependencies): check it out. I just have to fill it with real data.
                karsten13K 1 Reply Last reply Reply Quote 4
                  @KristjanESPERANTO said in Automatic checking of all MagicMirror² modules:
                  cool, exactly what I thougth of …
                  looking at your example json
                      "name": "MMM-PublicTransportHafas",
                      "image": "https://raw.githubusercontent.com/KristjanESPERANTO/MMM-PublicTransportHafas/main/img/Goerdelerring_all.png",
                      "maintainer": "KristjanESPERANTO",
                      "link": "https://github.com/KristjanESPERANTO/MMM-PublicTransportHafas",
                      "category": "Traffic",
                      "tags": ["Schedule", "Public Transport", "Traffic", "HAFAS"],
                      "text": "This module displays real-time departure times for public transportation.",
                      "description": "Stay informed about the upcoming departures from your local public transit stations."
                  there are only a few things which are not available via github api (image, category).
                  category and tags are similar, do we still need a category?
                  tags are similar to api topics (may without magicmirror key words)
                    MMRIZE
                    One of the most popular modules MMM-Remote-Control uses similar JSON as a module-list.
                    And MMM-Remote-Control-Repository are serving that JSON file for MMM-Remote-Control.
                    However, if it is possible to serve a similar JSON URI, it could be a good replacement.
                      Good point! The mass of tags will certainly become a bit confusing. We could replace the category links in the menu by a few selected tags or we highlight certain tags so that they are more noticeable. I think I’ll try it in this direction.
                      You’re right, it would be cool to get compatibility with MMM-Remote-Control. Thanks for the hint!
                        I made some progress: https://kristjanesperanto.github.io/MagicMirror-3rd-Party-Modules/
                        There’s still a lot on the to-do list and some things aren’t working quite smoothly yet. But the website is now filled with data from all modules from the wiki.
                        When changes are made in the wiki, it doesn’t take much effort to update the data in this project - I just have to run a few scripts. Furthermore, no manual work is necessary.
                        • 1 / 9
