    Automatic checking of all MagicMirror² modules
    83 Posts 9 Posters 129.7k Views 10 Watching
    • JalibuJ
      Jalibu Module Developer @KristjanESPERANTO
      I think that such checks can be valuable. perhaps not the ones which are implemented yet, but this can still be a good starting point for other checks.
      but it will be challenging to automate some of the proposed checks.
      Reply Quote 3
        MMRIZE
        It is a good try, Although most checklists are meaningless rather than useless. There are also wrong checks. (For example, MMM-ModuleMonkeyPatch doesn’t have node_modules directory. It doesn’t have node_helper.js at all.)
        However, I would like to praise it because it is a good-looking list. It’s a good attempt.
        In any case, dependency checking is information ordinary users cannot deal with even if they know it. Unless he is a developer, there is nothing he can do with that information.
        Rather than performing a dependency check, it would be better to reveal the last update date or the number of unresolved issues to guess the module’s activation level or popularity.
        Or, if you are going to parse package.json anyway, I think it could be used to organise installation methods, etc.
        KristjanESPERANTOK 1 Reply Last reply
        Reply Quote 2
        • KristjanESPERANTOK
          KristjanESPERANTO Module Developer @MMRIZE
          Guys, like I said, the project is in early status! The tests so far should therefore be understood as a proof of concept. Maybe I could have made that a little clearer in my initial post.
          In any case, thanks for the feedback! 😃
          Categorizing the messages would certainly also make sense. Like: critical, warning and information.
          @sdetweil said in Automatic checking of all MagicMirror² modules:
          things that depend of features no longer available in the os like vcgencmd
          Is vcgencmd really no longer available? I don’t have the current OS version yet, but I can’t find any information about removing it in the documentation:
          https://www.raspberrypi.com/documentation/computers/os.html
          If so, what would be the alternative?
          and omxplayer
          Thanks. This is a solid suggestion, just like I was looking for! 😃 I have added this to the check list. There are a handful of modules which contain omxplayer.
          I don’t have a concrete approach for your other suggestions.
          @MMRIZE said in Automatic checking of all MagicMirror² modules:
          There are also wrong checks. (For example, MMM-ModuleMonkeyPatch …
          Ah, I used the module to provoke errors manually. I forgot to remove the folder 🤦. The checks themselves are not wrong.
          dependency checking is information ordinary users …
          Ordinary users are not the target group for this project. The project collects information about modules, the developers can do whatever they want with the information (even ignore it).
          For the core developers it is certainly sometimes interesting (e.g. before breaking changes) which modules still depend on a core functionality.
          Those are good points, thank you! I put them on the to-do list.
          Yes, I had already thought about parsing the package.json. What do you mean by “organise installation methods”?
          • karsten13K
            karsten13 @KristjanESPERANTO
            @KristjanESPERANTO
            from the results:
            .gitlab-ci.yml: Change file extention from .yml to .yaml: https://yaml.org/faq.html.
            In this case the .gitlab-ci.yml is the default name of the gitlab pipeline definition file (users can change this but 99% will not) so if you really want to check yml vs. yaml you need a whitelist …
            • karsten13K
              @KristjanESPERANTO
              there was a discussion long ago here about 3rd party modules because the current format is very ugly.
              So maybe this could be also a starting point to have the module list as e.g. yaml output with all current stuff and your analysis results. With such an input it would be possible to generate a website (as mentioned in the above issue, examples how this could look were https://tiny-helpers.dev/ or https://www.electronjs.org/apps) …
                KristjanESPERANTO Module Developer @karsten13
                @karsten13 said in Automatic checking of all MagicMirror² modules:
                Yeah, I’ll drop this test for now.
                Interesting direction. I’ll take a look at it 🙂
                karsten13K 1 Reply Last reply
                • karsten13K
                  @KristjanESPERANTO
                  as most modules are hosted on github: You can get such info’s over their api.
                  As example you can look at https://api.github.com/repos/MichMich/MagicMirror
                  KristjanESPERANTOK 2 Replies Last reply
                    Wow. That’s really nice! There are certainly some things that can be put to good use.
                    After you showed me the examples, I tinkered a bit with a simple frontend (without dependencies): check it out. I just have to fill it with real data.
                    Reply Quote 4
                    • karsten13K
                      @KristjanESPERANTO said in Automatic checking of all MagicMirror² modules:
                      cool, exactly what I thougth of …
                      looking at your example json
                          "name": "MMM-PublicTransportHafas",
                          "image": "https://raw.githubusercontent.com/KristjanESPERANTO/MMM-PublicTransportHafas/main/img/Goerdelerring_all.png",
                          "maintainer": "KristjanESPERANTO",
                          "link": "https://github.com/KristjanESPERANTO/MMM-PublicTransportHafas",
                          "category": "Traffic",
                          "tags": ["Schedule", "Public Transport", "Traffic", "HAFAS"],
                          "text": "This module displays real-time departure times for public transportation.",
                          "description": "Stay informed about the upcoming departures from your local public transit stations."
                      there are only a few things which are not available via github api (image, category).
                      category and tags are similar, do we still need a category?
                      tags are similar to api topics (may without magicmirror key words)
                        MMRIZE
                        One of the most popular modules MMM-Remote-Control uses similar JSON as a module-list.
                        And MMM-Remote-Control-Repository are serving that JSON file for MMM-Remote-Control.
                        However, if it is possible to serve a similar JSON URI, it could be a good replacement.
                          Good point! The mass of tags will certainly become a bit confusing. We could replace the category links in the menu by a few selected tags or we highlight certain tags so that they are more noticeable. I think I’ll try it in this direction.
                          You’re right, it would be cool to get compatibility with MMM-Remote-Control. Thanks for the hint!
                            I made some progress: https://kristjanesperanto.github.io/MagicMirror-3rd-Party-Modules/
                            There’s still a lot on the to-do list and some things aren’t working quite smoothly yet. But the website is now filled with data from all modules from the wiki.
                            When changes are made in the wiki, it doesn’t take much effort to update the data in this project - I just have to run a few scripts. Furthermore, no manual work is necessary.
                            Reply Quote 3
                              Unfortunately the API blocks me when I make queries for almost 1000 modules in a short time 🤪
                              I now take the tags from keywords in the package.json.
                              • karsten13K
                                @KristjanESPERANTO
                                from your todo list
                                Is there also a GitLab API?
                                yes, as example you can look at MMM-RepoStats
                                Another thing is what the source of the list should be, still the wiki (which is very error prone since anyone can edit things).
                                Alternatively, you could store a list in your repo and we need something for users to add to their repo (e.g. as a PR in the repo or with website functionality).
                                But maybe there are even better ideas.
                                • JalibuJ
                                  hmm… if this is the cornerstone for a proper MagicMirror Appstore, then I should consider renaming all my modules to start with the letter “A” to attract more attention on the landing page :-D
                                  M BKeyportB KristjanESPERANTOK 3 Replies Last reply
                                  Reply Quote 3
                                    MMRIZE @Jalibu
                                    @Jalibu Didn’t do that yet? :D
                                    • BKeyportB
                                      BKeyport Module Developer @Jalibu
                                      @Jalibu AAA-Module instead of MMM? 🤣🤣🤣🤣
                                      JalibuJ 1 Reply Last reply
                                      • JalibuJ
                                        Jalibu Module Developer @BKeyport
                                        @BKeyport or MMM-a-fancy-weather-module, MMM-a-powerful-stock-ticker, MMM-a-bosch-smart-home-dashboard, etc…
                                          KristjanESPERANTO Module Developer @Jalibu
                                          @Jalibu said in Automatic checking of all MagicMirror² modules:
                                          Yeah, I’m already have some ideas about the default sort order (like a combination of stars, issues and activity), this will prevent that :beaming_face_with_smiling_eyes:
                                          Reply Quote 2
                                            KristjanESPERANTO Module Developer @KristjanESPERANTO
                                            In the last few days I have worked on some details on the site. So if you’re interested, take a look: https://kristjanesperanto.github.io/MagicMirror-3rd-Party-Modules/.
                                            And there is now a little statistics table on the results page: https://github.com/KristjanESPERANTO/MagicMirror-3rd-Party-Modules/blob/main/result.md#statistics
                                            I have also created a few PRs based on the list for some modules. Most of them have already been accepted :-)
                                            mumblebajM S 4 Replies Last reply
                                            Reply Quote 2
                                            • 1 / 5
