    Automatic checking of all MagicMirror² modules
    83 Posts 9 Posters 124.8k Views 10 Watching
    • KristjanESPERANTOK Online
      KristjanESPERANTO Module Developer
      I started a small project. It’s still in its early stages and I don’t know where it’s going yet, but maybe it’ll be interesting for you.
      Since the quality of the modules varies greatly, I thought about how to automatically detect easily recognizable issues (e.g. typos or dependencies on deprecated packages).
      Basically it already works.
      This is what it does:
      1. Clone all modules from the wiki page: https://github.com/MichMich/MagicMirror/wiki/3rd-party-modules
      2. Search each module according to certain criteria
      3. Write the result to a file
      This is the result of the last check: https://github.com/KristjanESPERANTO/MagicMirror-3rd-Party-Modules/blob/main/result.md
      Do you have any ideas about useful checks?
      S BKeyportB JalibuJ karsten13K 5 Replies Last reply Reply Quote 2
        sdetweil @KristjanESPERANTO
        @KristjanESPERANTO I think your two primary tests are useless
        module name pattern is subjective
        MagicMirror vs with the superscript 2
        those have no operational impact.
        many modules will never be updated.
        things that would make a difference :
        libs referenced that are not shipped in the base
        APIs that changed
        things that depend of features no longer available in the os
        like vcgencmd, and omxplayer
        API keys required, API no longer free
        • BKeyportB Offline
          BKeyport Module Developer @KristjanESPERANTO
          @KristjanESPERANTO I personally think that it’s pretty useless - for example, it’s being picky about MagicMirror(squared) vs Magic Mirror. We use many different names for the project in shorthand, and it’s generally understood that it all refers to MagicMirror(squared).
          As you can tell, I’m using a PC and haven’t bothered to learn how to type a superscript 2, and don’t plan to…
          Like Sam said, a lot of the checks are useless - It’s much better to test actual functionality - does it still work? Is it missing declared dependencies, etc.
          1 Reply Last reply Reply Quote -1
          • JalibuJ Offline
            Jalibu Module Developer @KristjanESPERANTO
            I think that such checks can be valuable. perhaps not the ones which are implemented yet, but this can still be a good starting point for other checks.
            but it will be challenging to automate some of the proposed checks.
              MMRIZE
              It is a good try, Although most checklists are meaningless rather than useless. There are also wrong checks. (For example, MMM-ModuleMonkeyPatch doesn’t have node_modules directory. It doesn’t have node_helper.js at all.)
              However, I would like to praise it because it is a good-looking list. It’s a good attempt.
              In any case, dependency checking is information ordinary users cannot deal with even if they know it. Unless he is a developer, there is nothing he can do with that information.
              Rather than performing a dependency check, it would be better to reveal the last update date or the number of unresolved issues to guess the module’s activation level or popularity.
              Or, if you are going to parse package.json anyway, I think it could be used to organise installation methods, etc.
              KristjanESPERANTOK 1 Reply Last reply Reply Quote 2
                KristjanESPERANTO Module Developer @MMRIZE
                Guys, like I said, the project is in early status! The tests so far should therefore be understood as a proof of concept. Maybe I could have made that a little clearer in my initial post.
                In any case, thanks for the feedback! 😃
                Categorizing the messages would certainly also make sense. Like: critical, warning and information.
                @sdetweil said in Automatic checking of all MagicMirror² modules:
                things that depend of features no longer available in the os like vcgencmd
                Is vcgencmd really no longer available? I don’t have the current OS version yet, but I can’t find any information about removing it in the documentation:
                https://www.raspberrypi.com/documentation/computers/os.html
                If so, what would be the alternative?
                and omxplayer
                Thanks. This is a solid suggestion, just like I was looking for! 😃 I have added this to the check list. There are a handful of modules which contain omxplayer.
                I don’t have a concrete approach for your other suggestions.
                @MMRIZE said in Automatic checking of all MagicMirror² modules:
                There are also wrong checks. (For example, MMM-ModuleMonkeyPatch …
                Ah, I used the module to provoke errors manually. I forgot to remove the folder 🤦. The checks themselves are not wrong.
                dependency checking is information ordinary users …
                Ordinary users are not the target group for this project. The project collects information about modules, the developers can do whatever they want with the information (even ignore it).
                For the core developers it is certainly sometimes interesting (e.g. before breaking changes) which modules still depend on a core functionality.
                Those are good points, thank you! I put them on the to-do list.
                Yes, I had already thought about parsing the package.json. What do you mean by “organise installation methods”?
                • karsten13K Offline
                  karsten13 @KristjanESPERANTO
                  @KristjanESPERANTO
                  from the results:
                  .gitlab-ci.yml: Change file extention from .yml to .yaml: https://yaml.org/faq.html.
                  In this case the .gitlab-ci.yml is the default name of the gitlab pipeline definition file (users can change this but 99% will not) so if you really want to check yml vs. yaml you need a whitelist …
                  KristjanESPERANTOK 1 Reply Last reply Reply Quote 1
                    @KristjanESPERANTO
                    there was a discussion long ago here about 3rd party modules because the current format is very ugly.
                    So maybe this could be also a starting point to have the module list as e.g. yaml output with all current stuff and your analysis results. With such an input it would be possible to generate a website (as mentioned in the above issue, examples how this could look were https://tiny-helpers.dev/ or https://www.electronjs.org/apps) …
                      KristjanESPERANTO Module Developer @karsten13
                      @karsten13 said in Automatic checking of all MagicMirror² modules:
                      Yeah, I’ll drop this test for now.
                      Interesting direction. I’ll take a look at it 🙂
                        @KristjanESPERANTO
                        as most modules are hosted on github: You can get such info’s over their api.
                        As example you can look at https://api.github.com/repos/MichMich/MagicMirror
                        KristjanESPERANTOK 2 Replies Last reply Reply Quote 1
                          Wow. That’s really nice! There are certainly some things that can be put to good use.
                          After you showed me the examples, I tinkered a bit with a simple frontend (without dependencies): check it out. I just have to fill it with real data.
                          karsten13K 1 Reply Last reply Reply Quote 4
                            @KristjanESPERANTO said in Automatic checking of all MagicMirror² modules:
                            cool, exactly what I thougth of …
                            looking at your example json
                                "name": "MMM-PublicTransportHafas",
                                "image": "https://raw.githubusercontent.com/KristjanESPERANTO/MMM-PublicTransportHafas/main/img/Goerdelerring_all.png",
                                "maintainer": "KristjanESPERANTO",
                                "link": "https://github.com/KristjanESPERANTO/MMM-PublicTransportHafas",
                                "category": "Traffic",
                                "tags": ["Schedule", "Public Transport", "Traffic", "HAFAS"],
                                "text": "This module displays real-time departure times for public transportation.",
                                "description": "Stay informed about the upcoming departures from your local public transit stations."
                            there are only a few things which are not available via github api (image, category).
                            category and tags are similar, do we still need a category?
                            tags are similar to api topics (may without magicmirror key words)
                              MMRIZE
                              One of the most popular modules MMM-Remote-Control uses similar JSON as a module-list.
                              And MMM-Remote-Control-Repository are serving that JSON file for MMM-Remote-Control.
                              However, if it is possible to serve a similar JSON URI, it could be a good replacement.
                                Good point! The mass of tags will certainly become a bit confusing. We could replace the category links in the menu by a few selected tags or we highlight certain tags so that they are more noticeable. I think I’ll try it in this direction.
                                You’re right, it would be cool to get compatibility with MMM-Remote-Control. Thanks for the hint!
                                  I made some progress: https://kristjanesperanto.github.io/MagicMirror-3rd-Party-Modules/
                                  There’s still a lot on the to-do list and some things aren’t working quite smoothly yet. But the website is now filled with data from all modules from the wiki.
                                  When changes are made in the wiki, it doesn’t take much effort to update the data in this project - I just have to run a few scripts. Furthermore, no manual work is necessary.
                                    Unfortunately the API blocks me when I make queries for almost 1000 modules in a short time 🤪
                                    I now take the tags from keywords in the package.json.
                                      @KristjanESPERANTO
                                      from your todo list
                                      Is there also a GitLab API?
                                      yes, as example you can look at MMM-RepoStats
                                      Another thing is what the source of the list should be, still the wiki (which is very error prone since anyone can edit things).
                                      Alternatively, you could store a list in your repo and we need something for users to add to their repo (e.g. as a PR in the repo or with website functionality).
                                      But maybe there are even better ideas.
                                      • JalibuJ Offline
                                        hmm… if this is the cornerstone for a proper MagicMirror Appstore, then I should consider renaming all my modules to start with the letter “A” to attract more attention on the landing page :-D
                                        M BKeyportB KristjanESPERANTOK 3 Replies Last reply Reply Quote 3
                                          MMRIZE @Jalibu
                                          @Jalibu Didn’t do that yet? :D
                                          • BKeyportB Offline
                                            BKeyport Module Developer @Jalibu
                                            @Jalibu AAA-Module instead of MMM? 🤣🤣🤣🤣
                                            JalibuJ 1 Reply Last reply Reply Quote 0
                                            • 1 / 5
