    Automatic checking of all MagicMirror² modules
    83 Posts 9 Posters 127.0k Views 10 Watching
    • KristjanESPERANTOK
      KristjanESPERANTO Module Developer @MMRIZE
      @karsten13 said in Automatic checking of all MagicMirror² modules:
      category and tags are similar, do we still need a category?
      Good point! The mass of tags will certainly become a bit confusing. We could replace the category links in the menu by a few selected tags or we highlight certain tags so that they are more noticeable. I think I’ll try it in this direction.
      @MMRIZE said in Automatic checking of all MagicMirror² modules:
      MMM-Remote-Control uses similar JSON as a module-list.
      You’re right, it would be cool to get compatibility with MMM-Remote-Control. Thanks for the hint!
        KristjanESPERANTO Module Developer @karsten13
        I made some progress: https://kristjanesperanto.github.io/MagicMirror-3rd-Party-Modules/
        There’s still a lot on the to-do list and some things aren’t working quite smoothly yet. But the website is now filled with data from all modules from the wiki.
        When changes are made in the wiki, it doesn’t take much effort to update the data in this project - I just have to run a few scripts. Furthermore, no manual work is necessary.
          You can get such info’s over their api.
          Unfortunately the API blocks me when I make queries for almost 1000 modules in a short time 🤪
          I now take the tags from keywords in the package.json.
          • karsten13K
            karsten13 @KristjanESPERANTO
            @KristjanESPERANTO
            from your todo list
            Is there also a GitLab API?
            yes, as example you can look at MMM-RepoStats
            Another thing is what the source of the list should be, still the wiki (which is very error prone since anyone can edit things).
            Alternatively, you could store a list in your repo and we need something for users to add to their repo (e.g. as a PR in the repo or with website functionality).
            But maybe there are even better ideas.
            • JalibuJ
              Jalibu Module Developer
              hmm… if this is the cornerstone for a proper MagicMirror Appstore, then I should consider renaming all my modules to start with the letter “A” to attract more attention on the landing page :-D
              M BKeyportB KristjanESPERANTOK 3 Replies Last reply Reply Quote 3
                MMRIZE @Jalibu
                @Jalibu Didn’t do that yet? :D
                • BKeyportB
                  BKeyport Module Developer @Jalibu
                  @Jalibu AAA-Module instead of MMM? 🤣🤣🤣🤣
                  JalibuJ 1 Reply Last reply Reply Quote 0
                  • JalibuJ
                    Jalibu Module Developer @BKeyport
                    @BKeyport or MMM-a-fancy-weather-module, MMM-a-powerful-stock-ticker, MMM-a-bosch-smart-home-dashboard, etc…
                      KristjanESPERANTO Module Developer @Jalibu
                      @Jalibu said in Automatic checking of all MagicMirror² modules:
                      Yeah, I’m already have some ideas about the default sort order (like a combination of stars, issues and activity), this will prevent that :beaming_face_with_smiling_eyes:
                      KristjanESPERANTOK 1 Reply Last reply Reply Quote 2
                        KristjanESPERANTO Module Developer @KristjanESPERANTO
                        In the last few days I have worked on some details on the site. So if you’re interested, take a look: https://kristjanesperanto.github.io/MagicMirror-3rd-Party-Modules/.
                        And there is now a little statistics table on the results page: https://github.com/KristjanESPERANTO/MagicMirror-3rd-Party-Modules/blob/main/result.md#statistics
                        I have also created a few PRs based on the list for some modules. Most of them have already been accepted :-)
                        mumblebajM S 4 Replies Last reply Reply Quote 2
                        • mumblebajM
                          mumblebaj Module Developer @KristjanESPERANTO
                          @KristjanESPERANTO Looks good. Just out of interest, which image does it select as the thumbnail? Just noticed 2 of the modules of mines does not have the correct images. Both Growatt modules are the ones I am referring to.
                          • mumblebajM
                            @KristjanESPERANTO Stats were great, fixed most of the issues identified in my modules. Majority package.json issues.
                            Great work @KristjanESPERANTO
                              sdetweil @KristjanESPERANTO
                              @KristjanESPERANTO
                              could we separate out the cosmetic issues (MagicMirror vs the one with the superscript 2, as I don’t know how to make that happen in my text editor…) and its useless
                              and this is misleading
                              MMM-AareGuru by buge
                              There is no package.json. We need this file to gather information about the module.
                              there is no need for a package,json… as this module does all its work inside the modulename.js
                              there is no functional requirement as there is no node_helper.js
                              KristjanESPERANTOK 1 Reply Last reply Reply Quote 1
                                @KristjanESPERANTO
                                additionally… a module I forked was marked as present and attributed to me, but I never posted it… MMM-Alexa (and I deleted it from your list… and it is NOT present in the master list )
                                and one of my modules (the only one I have ever posted) is not present in the master list , and I did not remove it
                                MMM-SleepWake.
                                  @mumblebaj said in Automatic checking of all MagicMirror² modules:
                                  If the script doesn’t find an image with ‘screenshot’ or ‘example’ at the beginning of the name it takes the first it finds .
                                  The prerequisite for the whole thing is that a free license is specified in the package.json. If there is no package.json and no free license, no image will be searched.
                                  Nice, thank you! I just updated the list and a lot of issues disappeared 👏
                                  @sdetweil said in Automatic checking of all MagicMirror² modules:
                                  On my keyboard it’s just +
                                  and its useless
                                  I think it’s worth striving to call things by their proper names, so I don’t find the test useless. Feel free to just ignore it :-)
                                  there is no need for a package,json… as this module does all its work inside the modulename.js there is no functional requirement
                                  You are right, functionally there is no need for this. However, the file is a good source of information that is interesting for the website - e.g. keywords.
                                  MMM-Alexa
                                  Do you know if the original module (https://github.com/sakirtemel/MMM-alexa) still works? Otherwise I should mark it as outdated.
                                  and one of my modules (the only one I have ever posted) is not present in the master list , and I did not remove it. MMM-SleepWake
                                  I’ve added it now :-)
                                  S JalibuJ 2 Replies Last reply Reply Quote 0
                                    @KristjanESPERANTO I have no info on MMM-Alexa or why i forked it
                                      I added ‘for the website’ at the end of the sentence. I hope that this is clearer.
                                      Thanks for the feedback :-)
                                      S mumblebajM 3 Replies Last reply Reply Quote 0
                                        @KristjanESPERANTO I have no website.
                                          @sdetweil Yes, I mean this website: https://kristjanesperanto.github.io/MagicMirror-3rd-Party-Modules/. Information from the package.json files is used there.
                                          • BKeyportB
                                            BKeyport Module Developer @KristjanESPERANTO
                                            @KristjanESPERANTO “This” instead of “The” perhaps?
                                            • 2 / 5
