    MMM-Calendar not seem to load .ics
    21 Posts 2 Posters 7.1k Views 2 Watching
      sdetweil @Dennis-010
      @Dennis-010 this sounds like an ics data format problem
      change this line in config.js
      logLevel: ["INFO", "LOG", "WARN", "ERROR"],
      to
      logLevel: ["INFO", "LOG", "WARN", "ERROR","DEBUG"],
      then start MM like this
      pm2 stop all
      npm start > somefile.txt 2>&1
      wait 15 seconds
      then in the same window as where you did npm start do
      ctrl-c
      and then examine the somefile.txt to see where that error is…
      i’d like to see the ics file entry for that event
      npm start
        Dennis-010 @sdetweil
        Is this what you are looking for?
        [23.10.2023 23:18.36.721] [ERROR] Calendar Error. Could not fetch calendar:  https://**url**/ical/**url**/Calendar.ics RangeError: Invalid time value
            at Date.toISOString (<anonymous>)
            at /home/dennis/MagicMirror/modules/default/calendar/calendarfetcherutils.js:312:28
            at Array.forEach (<anonymous>)
            at Object.filterEvents (/home/dennis/MagicMirror/modules/default/calendar/calendarfetcherutils.js:140:24)
            at /home/dennis/MagicMirror/modules/default/calendar/calendarfetcher.js:72:36
            at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
        [23.10.2023 23:18.38.049] [DEBUG] parsed data={"ecaf4d70-3f05-470f-a8f3-2566b4f2f1b5":{"type":"VTIMEZONE","params":[],"tzid":"Europe/Amsterdam","487c4058-cf12-4ad3-9d19-abf7c43101a2":{>
        [23.10.2023 23:18.38.053] [DEBUG] There are 327 calendar entries.
        [23.10.2023 23:18.38.055] [DEBUG] Processing entry...
        [23.10.2023 23:18.38.058] [DEBUG] Processing entry...
        [23.10.2023 23:18.38.060] [DEBUG] Event:
        [23.10.2023 23:18.38.153] [ERROR] Calendar Error. Could not fetch calendar:  https://**url**/ical/**url**/Calendar.ics RangeError: Invalid time value
        [23.10.2023 23:18.39.055] [DEBUG] parsed data={"634747":{"type":"VEVENT","params":[],"dtstamp":"2018-03-19T19:38:00.000Z","uid":"634747","description":"Datum: 04/24/2018\nTijd: 19:30\n>
        [23.10.2023 23:18.39.060] [DEBUG] There are 434 calendar entries.
        [23.10.2023 23:18.39.061] [DEBUG] Processing entry...
        [23.10.2023 23:18.39.061] [DEBUG] Event:
        {"type":"VEVENT","params":[],"dtstamp":"2018-03-19T19:38:00.000Z","uid":"634747","description":"Datum: 04/24/2018\nTijd: 19:30\n\nTot dan!\n\nP.S.: Gebruik je GMAIL? Controleer of de t>
        [23.10.2023 23:18.39.062] [DEBUG] start: Tue Apr 24 2018 19:30:00 GMT+0200 (Midden-Europese zomertijd)
          @Dennis-010 thx… I meant download the ics file and find that entry
          like this from my calendar
          BEGIN:VEVENT
          DTSTART:20160729T233000Z
          DTEND:20160730T010000Z
          DTSTAMP:20231023T212812Z
          UID:2prgqt2idcgs5jjf0bvd557v6k@google.com
          CREATED:20160912T121808Z
          LAST-MODIFIED:20160912T121808Z
          SEQUENCE:0
          STATUS:CONFIRMED
          SUMMARY:Dinner at Monument Cafe
          TRANSP:OPAQUE
          END:VEVENT
            I don’t think I understand what you’re asking.
            What event you want me to find?
              @Dennis-010 the one that throws the error in the somefile.txt, then look it up in the ICS file
                Think I found it, will check back tomorrow.
                BEGIN:VEVENT
                DTSTAMP:20210413T203456Z
                UID:E689AEB8C02C4E2CADD8C7D3D303CEAD0
                DTSTART;TZID="Amsterdam, Belgrade, Berlin, Brussels, Budapest, Madrid, Paris, Prague, Stockholm":20210415T190000
                DTEND;TZID="Amsterdam, Belgrade, Berlin, Brussels, Budapest, Madrid, Paris, Prague, Stockholm":20210415T210000
                CLASS:PUBLIC
                SUMMARY:xxx xxxx
                SEQUENCE:10
                RRULE:FREQ=DAILY;UNTIL=20210418T170000Z
                EXDATE;TZID="Amsterdam, Belgrade, Berlin, Brussels, Budapest, Madrid, Paris, Prague, Stockholm":20210417T190000
                EXDATE;TZID="Amsterdam, Belgrade, Berlin, Brussels, Budapest, Madrid, Paris, Prague, Stockholm":20210416T190000
                EXDATE;TZID="Amsterdam, Belgrade, Berlin, Brussels, Budapest, Madrid, Paris, Prague, Stockholm":20210415T190000
                BEGIN:VALARM
                ACTION:DISPLAY
                TRIGGER;RELATED=START:-PT15M
                END:VALARM
                END:VEVENT
                {"type":"VEVENT","params":[],"uid":"E689AEB8C02C4E2CADD8C7D3D303CEAD0","start":"2021-04-15T17:00:00.000Z","datetype":"date-time","end":"2021-04-15T19:00:00.000Z","a94d8d2a-3>
                [24.10.2023 00:16.22.001] [DEBUG] start: Thu Apr 15 2021 19:00:00 GMT+0200 (Midden-Europese zomertijd)
                [24.10.2023 00:16.22.001] [DEBUG] end:: Thu Apr 15 2021 21:00:00 GMT+0200 (Midden-Europese zomertijd)
                [24.10.2023 00:16.22.002] [DEBUG] duration: 7200000
                [24.10.2023 00:16.22.002] [DEBUG] title: xxx xxxx
                [24.10.2023 00:16.22.002] [DEBUG] Search for recurring events between: Tue Oct 24 2023 00:16:22 GMT+0200 (Midden-Europese zomertijd) and Tue Oct 22 2024 23:59:59 GMT+0200 (M>
                [24.10.2023 00:16.22.051] [DEBUG] Title: xxx xxxx, with dates: [null,null,null,null]
                [24.10.2023 00:16.22.051] [DEBUG] event.recurrences: [object Object]
                [24.10.2023 00:16.22.055] [ERROR] Calendar Error. Could not fetch calendar:  https://url/ical/url/Calendar.ics RangeError: Invalid time value
                  @Dennis-010 awesome, will need you to run it again with one debugging change
                  in calendarfetchutils.js
                  change this
                  					Log.debug(`event.recurrences: ${event.recurrences}`);
                  to this
                  			Log.debug("event.recurrences:" +JSON.stringify(event.recurrences));
                  but I really think its THIS
                  the until is outside the event window start/end (04/15, this is 04/18)
                  AND the event is in the past 2021
                  but the code tried to find recurrences THIS year
                  [24.10.2023 00:16.22.051] [DEBUG] Title: xxx xxxx, with dates: [null,null,null,null]  <----- and returned junk.. those are bad dates.
                    @Dennis-010 try this
                    cd ~/MagicMirror/modules/default/calendar
                    cp calendarfetcherutils.js  utils.js
                    nano calendarfetcherutils.js
                    insert this line
                    						futureLocal = futureMoment.toDate(); // future
                    					if(moment(endDate)>=moment(pastLocal)){ //<--- this line (approx line 283)
                    						Log.debug(`Search for recurring events between: ${pastLocal} and ${futureLocal}`);
                    						const dates = rule.between(pastLocal, futureLocal, true, limitFunction);
                    and this line
                    							i
                    									description: description
                    						} // < ----- this line (approx line 454)
                    this adds a check if the event end is after the calculated start (for include past events thats a year back) , then process the event, else skip it…
                    let me know
                      This did the trick, thank you very much.
                      You are a genius!!
                        @Dennis-010 said in MMM-Calendar not seem to load .ics:
                        You are a genius!!
                        well, i don’t know about that… I’ve just spent the last few years fixing bugs in there
