    MMM-Calendar not seem to load .ics
    21 Posts 2 Posters 7.0k Views 2 Watching
      Dennis-010 @sdetweil
      Thank you for replying, I hope you can make something out of it.
      I posted a snap from the config and some errors from the log.
                              header: "Agenda",
                                  coloredText: true,
                                  fade: false,
                                              url: "https://www.xxx.xx/ical/xxxx@xxx.xx/Calendar.ics",
                                              symbol: "calendar-check",
                                              color:  "#ffb350"
      [1917:1023/200030.144271:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: Bestand of map bestaat niet (2)
      [ERROR] Calendar Error. Could not fetch calendar:  https://www.xxx.xx/ical/xxxxs@xxx.xx/Calendar.ics TypeError: terminated
        sdetweil @Dennis-010
        @Dennis-010 said in MMM-Calendar not seem to load .ics:
        https://www.xxx.xx/ical TypeError: terminated
        this seems to indicate a problem with the server not sending the required info. ( and terminating the connection before the complete transmission was received) . the new internal fetch is enforcing the spec, which the prior node-fetch did not.
        can u identify what
        https://www.xxx.xx
        this is exactly?
          This is the url of my Kerio mailserver. It is my own dedicated server running in NL.
          You asked to xxx out the url right?
          If the connection is terminated before completion of the transmission, why is it that if I just paste the url in the default browser on raspberry, I just get to download the .ics file? What am I missing here?
            @Dennis-010 the browser has error recovery code that we don’t, probably. they’ve had fetch for a long time. years…
            this is one of the.problens w trying to keep up with changes and general supportability .
              Point is, it has worked before… like a charm for over 2 years.
              Recently we moved to another house and we have not been using the mirror for 8-9 months, now I reinstalled the OS and modules and now the calendar stopped working.
              Is there any way I can try and sort out what the source of this issue could be?
                @Dennis-010 I hear you.
                none of the code that needs to be debugged is ours(mm) it’s all lower layers.
                let me see if there is a hacky way to help you out.
                  I’'l be happy to test and try out things or methods to fix this issue.
                  Thanks in advance
                    @Dennis-010
                    ok, lets try this
                    cd ~/MagicMirror/modules/default/calendar
                    cp calendarfetcher.js  savefetcher.js
                    nano calendarfetcher.js
                    then insert this line
                    const Log = require("logger");
                    const fetchit = require('node-fetch');   //<----- add this line
                    const NodeHelper = require("node_helper");
                    then add this line
                    		const nodeVersion = Number(process.version.match(/^v(\d+\.\d+)/)[1]);
                    		let fetcher = null //<------ add this line
                    		let httpsAgent = null;
                    then later change this
                    		fetch(url, { headers: headers, agent: httpsAgent })
                    to this
                    		if (fetcher === null) {
                    			fetcher = fetchit(url, { headers: headers, agent: httpsAgent });
                    		fetcher
                    then save, (ctrl-o)
                    and exit nano (ctrl-x)
                    then
                    npm install node-fetch@2
                    then npm start
                    calendar should come up
                    mine works…
                      This seem to work like a charm, thank you for fixing this.
                      Now…when I want to add 2 more url’s I get a new error:
                      For each of the new url. Both from the same domain.
                      is it possible to have a hacky line for that as well?
                      [ERROR] Calendar Error. Could not fetch calendar:  https://www.xxxxxxxx/ical/**url**/Calendar.ics RangeError: Invalid time value
                      [23.10.2023 22:56.15.687] [LOG]   Create new calendarfetcher for url: https://**url**/ical/**url**/Calendar.ics - Interval: 3600000
                      [23.10.2023 22:56.15.728] [LOG]   Create new calendarfetcher for url: https://**url**/ical/**url**/Calendar.ics - Interval: 3600000
                      [23.10.2023 22:56.15.733] [LOG]   Create new calendarfetcher for url: https://**url**/ical/**url**/Calendar.ics - Interval: 3600000
                        @Dennis-010 this sounds like an ics data format problem
                        change this line in config.js
                        logLevel: ["INFO", "LOG", "WARN", "ERROR"],
                        to
                        logLevel: ["INFO", "LOG", "WARN", "ERROR","DEBUG"],
                        then start MM like this
                        pm2 stop all
                        npm start > somefile.txt 2>&1
                        wait 15 seconds
                        then in the same window as where you did npm start do
                        ctrl-c
                        and then examine the somefile.txt to see where that error is…
                        i’d like to see the ics file entry for that event
                        npm start
                          Is this what you are looking for?
                          [23.10.2023 23:18.36.721] [ERROR] Calendar Error. Could not fetch calendar:  https://**url**/ical/**url**/Calendar.ics RangeError: Invalid time value
                              at Date.toISOString (<anonymous>)
                              at /home/dennis/MagicMirror/modules/default/calendar/calendarfetcherutils.js:312:28
                              at Array.forEach (<anonymous>)
                              at Object.filterEvents (/home/dennis/MagicMirror/modules/default/calendar/calendarfetcherutils.js:140:24)
                              at /home/dennis/MagicMirror/modules/default/calendar/calendarfetcher.js:72:36
                              at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                          [23.10.2023 23:18.38.049] [DEBUG] parsed data={"ecaf4d70-3f05-470f-a8f3-2566b4f2f1b5":{"type":"VTIMEZONE","params":[],"tzid":"Europe/Amsterdam","487c4058-cf12-4ad3-9d19-abf7c43101a2":{>
                          [23.10.2023 23:18.38.053] [DEBUG] There are 327 calendar entries.
                          [23.10.2023 23:18.38.055] [DEBUG] Processing entry...
                          [23.10.2023 23:18.38.058] [DEBUG] Processing entry...
                          [23.10.2023 23:18.38.060] [DEBUG] Event:
                          [23.10.2023 23:18.38.153] [ERROR] Calendar Error. Could not fetch calendar:  https://**url**/ical/**url**/Calendar.ics RangeError: Invalid time value
                          [23.10.2023 23:18.39.055] [DEBUG] parsed data={"634747":{"type":"VEVENT","params":[],"dtstamp":"2018-03-19T19:38:00.000Z","uid":"634747","description":"Datum: 04/24/2018\nTijd: 19:30\n>
                          [23.10.2023 23:18.39.060] [DEBUG] There are 434 calendar entries.
                          [23.10.2023 23:18.39.061] [DEBUG] Processing entry...
                          [23.10.2023 23:18.39.061] [DEBUG] Event:
                          {"type":"VEVENT","params":[],"dtstamp":"2018-03-19T19:38:00.000Z","uid":"634747","description":"Datum: 04/24/2018\nTijd: 19:30\n\nTot dan!\n\nP.S.: Gebruik je GMAIL? Controleer of de t>
                          [23.10.2023 23:18.39.062] [DEBUG] start: Tue Apr 24 2018 19:30:00 GMT+0200 (Midden-Europese zomertijd)
                            @Dennis-010 thx… I meant download the ics file and find that entry
                            like this from my calendar
                            BEGIN:VEVENT
                            DTSTART:20160729T233000Z
                            DTEND:20160730T010000Z
                            DTSTAMP:20231023T212812Z
                            UID:2prgqt2idcgs5jjf0bvd557v6k@google.com
                            CREATED:20160912T121808Z
                            LAST-MODIFIED:20160912T121808Z
                            SEQUENCE:0
                            STATUS:CONFIRMED
                            SUMMARY:Dinner at Monument Cafe
                            TRANSP:OPAQUE
                            END:VEVENT
                              I don’t think I understand what you’re asking.
                              What event you want me to find?
                                @Dennis-010 the one that throws the error in the somefile.txt, then look it up in the ICS file
                                  Think I found it, will check back tomorrow.
                                  BEGIN:VEVENT
                                  DTSTAMP:20210413T203456Z
                                  UID:E689AEB8C02C4E2CADD8C7D3D303CEAD0
                                  DTSTART;TZID="Amsterdam, Belgrade, Berlin, Brussels, Budapest, Madrid, Paris, Prague, Stockholm":20210415T190000
                                  DTEND;TZID="Amsterdam, Belgrade, Berlin, Brussels, Budapest, Madrid, Paris, Prague, Stockholm":20210415T210000
                                  CLASS:PUBLIC
                                  SUMMARY:xxx xxxx
                                  SEQUENCE:10
                                  RRULE:FREQ=DAILY;UNTIL=20210418T170000Z
                                  EXDATE;TZID="Amsterdam, Belgrade, Berlin, Brussels, Budapest, Madrid, Paris, Prague, Stockholm":20210417T190000
                                  EXDATE;TZID="Amsterdam, Belgrade, Berlin, Brussels, Budapest, Madrid, Paris, Prague, Stockholm":20210416T190000
                                  EXDATE;TZID="Amsterdam, Belgrade, Berlin, Brussels, Budapest, Madrid, Paris, Prague, Stockholm":20210415T190000
                                  BEGIN:VALARM
                                  ACTION:DISPLAY
                                  TRIGGER;RELATED=START:-PT15M
                                  END:VALARM
                                  END:VEVENT
                                  {"type":"VEVENT","params":[],"uid":"E689AEB8C02C4E2CADD8C7D3D303CEAD0","start":"2021-04-15T17:00:00.000Z","datetype":"date-time","end":"2021-04-15T19:00:00.000Z","a94d8d2a-3>
                                  [24.10.2023 00:16.22.001] [DEBUG] start: Thu Apr 15 2021 19:00:00 GMT+0200 (Midden-Europese zomertijd)
                                  [24.10.2023 00:16.22.001] [DEBUG] end:: Thu Apr 15 2021 21:00:00 GMT+0200 (Midden-Europese zomertijd)
                                  [24.10.2023 00:16.22.002] [DEBUG] duration: 7200000
                                  [24.10.2023 00:16.22.002] [DEBUG] title: xxx xxxx
                                  [24.10.2023 00:16.22.002] [DEBUG] Search for recurring events between: Tue Oct 24 2023 00:16:22 GMT+0200 (Midden-Europese zomertijd) and Tue Oct 22 2024 23:59:59 GMT+0200 (M>
                                  [24.10.2023 00:16.22.051] [DEBUG] Title: xxx xxxx, with dates: [null,null,null,null]
                                  [24.10.2023 00:16.22.051] [DEBUG] event.recurrences: [object Object]
                                  [24.10.2023 00:16.22.055] [ERROR] Calendar Error. Could not fetch calendar:  https://url/ical/url/Calendar.ics RangeError: Invalid time value
                                    @Dennis-010 awesome, will need you to run it again with one debugging change
                                    in calendarfetchutils.js
                                    change this
                                    					Log.debug(`event.recurrences: ${event.recurrences}`);
                                    to this
                                    			Log.debug("event.recurrences:" +JSON.stringify(event.recurrences));
                                    but I really think its THIS
                                    the until is outside the event window start/end (04/15, this is 04/18)
                                    AND the event is in the past 2021
                                    but the code tried to find recurrences THIS year
                                    [24.10.2023 00:16.22.051] [DEBUG] Title: xxx xxxx, with dates: [null,null,null,null]  <----- and returned junk.. those are bad dates.
                                      @Dennis-010 try this
                                      cp calendarfetcherutils.js  utils.js
                                      nano calendarfetcherutils.js
                                      insert this line
                                      						futureLocal = futureMoment.toDate(); // future
                                      					if(moment(endDate)>=moment(pastLocal)){ //<--- this line (approx line 283)
                                      						Log.debug(`Search for recurring events between: ${pastLocal} and ${futureLocal}`);
                                      						const dates = rule.between(pastLocal, futureLocal, true, limitFunction);
                                      and this line
                                      							i
                                      									description: description
                                      						} // < ----- this line (approx line 454)
                                      this adds a check if the event end is after the calculated start (for include past events thats a year back) , then process the event, else skip it…
                                      let me know
                                        This did the trick, thank you very much.
                                        You are a genius!!
                                          You are a genius!!
                                          well, i don’t know about that… I’ve just spent the last few years fixing bugs in there
