    MMM-Calendar not seem to load .ics
    21 Posts 2 Posters 5.8k Views 2 Watching
      sdetweil @Dennis-010
      @Dennis-010 the browser has error recovery code that we don’t, probably. they’ve had fetch for a long time. years…
      this is one of the.problens w trying to keep up with changes and general supportability .
        Dennis-010 @sdetweil
        Point is, it has worked before… like a charm for over 2 years.
        Recently we moved to another house and we have not been using the mirror for 8-9 months, now I reinstalled the OS and modules and now the calendar stopped working.
        Is there any way I can try and sort out what the source of this issue could be?
          @Dennis-010 I hear you.
          none of the code that needs to be debugged is ours(mm) it’s all lower layers.
          let me see if there is a hacky way to help you out.
            I’'l be happy to test and try out things or methods to fix this issue.
            Thanks in advance
              @Dennis-010
              ok, lets try this
              cd ~/MagicMirror/modules/default/calendar
              cp calendarfetcher.js  savefetcher.js
              nano calendarfetcher.js
              then insert this line
              const Log = require("logger");
              const fetchit = require('node-fetch');   //<----- add this line
              const NodeHelper = require("node_helper");
              then add this line
              		const nodeVersion = Number(process.version.match(/^v(\d+\.\d+)/)[1]);
              		let fetcher = null //<------ add this line
              		let httpsAgent = null;
              then later change this
              		fetch(url, { headers: headers, agent: httpsAgent })
              to this
              		if (fetcher === null) {
              			fetcher = fetchit(url, { headers: headers, agent: httpsAgent });
              		fetcher
              then save, (ctrl-o)
              and exit nano (ctrl-x)
              then
              npm install node-fetch@2
              then npm start
              calendar should come up
              mine works…
                This seem to work like a charm, thank you for fixing this.
                Now…when I want to add 2 more url’s I get a new error:
                For each of the new url. Both from the same domain.
                is it possible to have a hacky line for that as well?
                [ERROR] Calendar Error. Could not fetch calendar:  https://www.xxxxxxxx/ical/**url**/Calendar.ics RangeError: Invalid time value
                [23.10.2023 22:56.15.687] [LOG]   Create new calendarfetcher for url: https://**url**/ical/**url**/Calendar.ics - Interval: 3600000
                [23.10.2023 22:56.15.728] [LOG]   Create new calendarfetcher for url: https://**url**/ical/**url**/Calendar.ics - Interval: 3600000
                [23.10.2023 22:56.15.733] [LOG]   Create new calendarfetcher for url: https://**url**/ical/**url**/Calendar.ics - Interval: 3600000
                  @Dennis-010 this sounds like an ics data format problem
                  change this line in config.js
                  logLevel: ["INFO", "LOG", "WARN", "ERROR"],
                  to
                  logLevel: ["INFO", "LOG", "WARN", "ERROR","DEBUG"],
                  then start MM like this
                  pm2 stop all
                  npm start > somefile.txt 2>&1
                  wait 15 seconds
                  then in the same window as where you did npm start do
                  ctrl-c
                  and then examine the somefile.txt to see where that error is…
                  i’d like to see the ics file entry for that event
                  npm start
                    Is this what you are looking for?
                    [23.10.2023 23:18.36.721] [ERROR] Calendar Error. Could not fetch calendar:  https://**url**/ical/**url**/Calendar.ics RangeError: Invalid time value
                        at Date.toISOString (<anonymous>)
                        at /home/dennis/MagicMirror/modules/default/calendar/calendarfetcherutils.js:312:28
                        at Array.forEach (<anonymous>)
                        at Object.filterEvents (/home/dennis/MagicMirror/modules/default/calendar/calendarfetcherutils.js:140:24)
                        at /home/dennis/MagicMirror/modules/default/calendar/calendarfetcher.js:72:36
                        at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                    [23.10.2023 23:18.38.049] [DEBUG] parsed data={"ecaf4d70-3f05-470f-a8f3-2566b4f2f1b5":{"type":"VTIMEZONE","params":[],"tzid":"Europe/Amsterdam","487c4058-cf12-4ad3-9d19-abf7c43101a2":{>
                    [23.10.2023 23:18.38.053] [DEBUG] There are 327 calendar entries.
                    [23.10.2023 23:18.38.055] [DEBUG] Processing entry...
                    [23.10.2023 23:18.38.058] [DEBUG] Processing entry...
                    [23.10.2023 23:18.38.060] [DEBUG] Event:
                    [23.10.2023 23:18.38.153] [ERROR] Calendar Error. Could not fetch calendar:  https://**url**/ical/**url**/Calendar.ics RangeError: Invalid time value
                    [23.10.2023 23:18.39.055] [DEBUG] parsed data={"634747":{"type":"VEVENT","params":[],"dtstamp":"2018-03-19T19:38:00.000Z","uid":"634747","description":"Datum: 04/24/2018\nTijd: 19:30\n>
                    [23.10.2023 23:18.39.060] [DEBUG] There are 434 calendar entries.
                    [23.10.2023 23:18.39.061] [DEBUG] Processing entry...
                    [23.10.2023 23:18.39.061] [DEBUG] Event:
                    {"type":"VEVENT","params":[],"dtstamp":"2018-03-19T19:38:00.000Z","uid":"634747","description":"Datum: 04/24/2018\nTijd: 19:30\n\nTot dan!\n\nP.S.: Gebruik je GMAIL? Controleer of de t>
                    [23.10.2023 23:18.39.062] [DEBUG] start: Tue Apr 24 2018 19:30:00 GMT+0200 (Midden-Europese zomertijd)
                      @Dennis-010 thx… I meant download the ics file and find that entry
                      like this from my calendar
                      BEGIN:VEVENT
                      DTSTART:20160729T233000Z
                      DTEND:20160730T010000Z
                      DTSTAMP:20231023T212812Z
                      UID:2prgqt2idcgs5jjf0bvd557v6k@google.com
                      CREATED:20160912T121808Z
                      LAST-MODIFIED:20160912T121808Z
                      SEQUENCE:0
                      STATUS:CONFIRMED
                      SUMMARY:Dinner at Monument Cafe
                      TRANSP:OPAQUE
                      END:VEVENT
                        I don’t think I understand what you’re asking.
                        What event you want me to find?
