    MMM-Calendar not seem to load .ics
    21 Posts 2 Posters 7.0k Views 2 Watching
      Dennis-010
      Today I have installed a fresh copy of MagicMirror on my PI.
      When I edit the calendar config and a update and restart my MagicMirror pid. The calander comes with an error: " Calendar Error. Could not fetch calendar"
      When I try the URL on the raspberrry pi itself it does download an .ics file which I can open and can see lines of text.
      Anyone has an idea what could possible gowrong here.
      In did work in the past with the same URL, like a year ago.
        sdetweil @Dennis-010
        @Dennis-010 do you mean the default calendar built into mm?
        I cannot find a module called MMM-Calendar
        if u mean the default
        can you show the config.js section for the calendar
        xxx out the url
          Dennis-010 @sdetweil
          Thank you for replying, I hope you can make something out of it.
          I posted a snap from the config and some errors from the log.
                                  header: "Agenda",
                                      coloredText: true,
                                      fade: false,
                                                  url: "https://www.xxx.xx/ical/xxxx@xxx.xx/Calendar.ics",
                                                  symbol: "calendar-check",
                                                  color:  "#ffb350"
          [1917:1023/200030.144271:ERROR:gbm_wrapper.cc(253)] Failed to export buffer to dma_buf: Bestand of map bestaat niet (2)
          [ERROR] Calendar Error. Could not fetch calendar:  https://www.xxx.xx/ical/xxxxs@xxx.xx/Calendar.ics TypeError: terminated
            @Dennis-010 said in MMM-Calendar not seem to load .ics:
            https://www.xxx.xx/ical TypeError: terminated
            this seems to indicate a problem with the server not sending the required info. ( and terminating the connection before the complete transmission was received) . the new internal fetch is enforcing the spec, which the prior node-fetch did not.
            can u identify what
            https://www.xxx.xx
            this is exactly?
              This is the url of my Kerio mailserver. It is my own dedicated server running in NL.
              You asked to xxx out the url right?
              If the connection is terminated before completion of the transmission, why is it that if I just paste the url in the default browser on raspberry, I just get to download the .ics file? What am I missing here?
                @Dennis-010 the browser has error recovery code that we don’t, probably. they’ve had fetch for a long time. years…
                this is one of the.problens w trying to keep up with changes and general supportability .
                  Point is, it has worked before… like a charm for over 2 years.
                  Recently we moved to another house and we have not been using the mirror for 8-9 months, now I reinstalled the OS and modules and now the calendar stopped working.
                  Is there any way I can try and sort out what the source of this issue could be?
                    @Dennis-010 I hear you.
                    none of the code that needs to be debugged is ours(mm) it’s all lower layers.
                    let me see if there is a hacky way to help you out.
                      I’'l be happy to test and try out things or methods to fix this issue.
                      Thanks in advance
                        @Dennis-010
                        ok, lets try this
                        cd ~/MagicMirror/modules/default/calendar
                        cp calendarfetcher.js  savefetcher.js
                        nano calendarfetcher.js
                        then insert this line
                        const Log = require("logger");
                        const fetchit = require('node-fetch');   //<----- add this line
                        const NodeHelper = require("node_helper");
                        then add this line
                        		const nodeVersion = Number(process.version.match(/^v(\d+\.\d+)/)[1]);
                        		let fetcher = null //<------ add this line
                        		let httpsAgent = null;
                        then later change this
                        		fetch(url, { headers: headers, agent: httpsAgent })
                        to this
                        		if (fetcher === null) {
                        			fetcher = fetchit(url, { headers: headers, agent: httpsAgent });
                        		fetcher
                        then save, (ctrl-o)
                        and exit nano (ctrl-x)
                        then
                        npm install node-fetch@2
                        then npm start
                        calendar should come up
                        mine works…
                          This seem to work like a charm, thank you for fixing this.
                          Now…when I want to add 2 more url’s I get a new error:
                          For each of the new url. Both from the same domain.
                          is it possible to have a hacky line for that as well?
                          [ERROR] Calendar Error. Could not fetch calendar:  https://www.xxxxxxxx/ical/**url**/Calendar.ics RangeError: Invalid time value
                          [23.10.2023 22:56.15.687] [LOG]   Create new calendarfetcher for url: https://**url**/ical/**url**/Calendar.ics - Interval: 3600000
                          [23.10.2023 22:56.15.728] [LOG]   Create new calendarfetcher for url: https://**url**/ical/**url**/Calendar.ics - Interval: 3600000
                          [23.10.2023 22:56.15.733] [LOG]   Create new calendarfetcher for url: https://**url**/ical/**url**/Calendar.ics - Interval: 3600000
                            @Dennis-010 this sounds like an ics data format problem
                            change this line in config.js
                            logLevel: ["INFO", "LOG", "WARN", "ERROR"],
                            to
                            logLevel: ["INFO", "LOG", "WARN", "ERROR","DEBUG"],
                            then start MM like this
                            pm2 stop all
                            npm start > somefile.txt 2>&1
                            wait 15 seconds
                            then in the same window as where you did npm start do
                            ctrl-c
                            and then examine the somefile.txt to see where that error is…
                            i’d like to see the ics file entry for that event
                            npm start
                              Is this what you are looking for?
                              [23.10.2023 23:18.36.721] [ERROR] Calendar Error. Could not fetch calendar:  https://**url**/ical/**url**/Calendar.ics RangeError: Invalid time value
                                  at Date.toISOString (<anonymous>)
                                  at /home/dennis/MagicMirror/modules/default/calendar/calendarfetcherutils.js:312:28
                                  at Array.forEach (<anonymous>)
                                  at Object.filterEvents (/home/dennis/MagicMirror/modules/default/calendar/calendarfetcherutils.js:140:24)
                                  at /home/dennis/MagicMirror/modules/default/calendar/calendarfetcher.js:72:36
                                  at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                              [23.10.2023 23:18.38.049] [DEBUG] parsed data={"ecaf4d70-3f05-470f-a8f3-2566b4f2f1b5":{"type":"VTIMEZONE","params":[],"tzid":"Europe/Amsterdam","487c4058-cf12-4ad3-9d19-abf7c43101a2":{>
                              [23.10.2023 23:18.38.053] [DEBUG] There are 327 calendar entries.
                              [23.10.2023 23:18.38.055] [DEBUG] Processing entry...
                              [23.10.2023 23:18.38.058] [DEBUG] Processing entry...
                              [23.10.2023 23:18.38.060] [DEBUG] Event:
                              [23.10.2023 23:18.38.153] [ERROR] Calendar Error. Could not fetch calendar:  https://**url**/ical/**url**/Calendar.ics RangeError: Invalid time value
                              [23.10.2023 23:18.39.055] [DEBUG] parsed data={"634747":{"type":"VEVENT","params":[],"dtstamp":"2018-03-19T19:38:00.000Z","uid":"634747","description":"Datum: 04/24/2018\nTijd: 19:30\n>
                              [23.10.2023 23:18.39.060] [DEBUG] There are 434 calendar entries.
                              [23.10.2023 23:18.39.061] [DEBUG] Processing entry...
                              [23.10.2023 23:18.39.061] [DEBUG] Event:
                              {"type":"VEVENT","params":[],"dtstamp":"2018-03-19T19:38:00.000Z","uid":"634747","description":"Datum: 04/24/2018\nTijd: 19:30\n\nTot dan!\n\nP.S.: Gebruik je GMAIL? Controleer of de t>
                              [23.10.2023 23:18.39.062] [DEBUG] start: Tue Apr 24 2018 19:30:00 GMT+0200 (Midden-Europese zomertijd)
                                @Dennis-010 thx… I meant download the ics file and find that entry
                                like this from my calendar
                                BEGIN:VEVENT
                                DTSTART:20160729T233000Z
                                DTEND:20160730T010000Z
                                DTSTAMP:20231023T212812Z
                                UID:2prgqt2idcgs5jjf0bvd557v6k@google.com
                                CREATED:20160912T121808Z
                                LAST-MODIFIED:20160912T121808Z
                                SEQUENCE:0
                                STATUS:CONFIRMED
                                SUMMARY:Dinner at Monument Cafe
                                TRANSP:OPAQUE
                                END:VEVENT
                                  I don’t think I understand what you’re asking.
                                  What event you want me to find?
                                    @Dennis-010 the one that throws the error in the somefile.txt, then look it up in the ICS file
                                      Think I found it, will check back tomorrow.
                                      BEGIN:VEVENT
                                      DTSTAMP:20210413T203456Z
                                      UID:E689AEB8C02C4E2CADD8C7D3D303CEAD0
                                      DTSTART;TZID="Amsterdam, Belgrade, Berlin, Brussels, Budapest, Madrid, Paris, Prague, Stockholm":20210415T190000
                                      DTEND;TZID="Amsterdam, Belgrade, Berlin, Brussels, Budapest, Madrid, Paris, Prague, Stockholm":20210415T210000
                                      CLASS:PUBLIC
                                      SUMMARY:xxx xxxx
                                      SEQUENCE:10
                                      RRULE:FREQ=DAILY;UNTIL=20210418T170000Z
                                      EXDATE;TZID="Amsterdam, Belgrade, Berlin, Brussels, Budapest, Madrid, Paris, Prague, Stockholm":20210417T190000
                                      EXDATE;TZID="Amsterdam, Belgrade, Berlin, Brussels, Budapest, Madrid, Paris, Prague, Stockholm":20210416T190000
                                      EXDATE;TZID="Amsterdam, Belgrade, Berlin, Brussels, Budapest, Madrid, Paris, Prague, Stockholm":20210415T190000
                                      BEGIN:VALARM
                                      ACTION:DISPLAY
                                      TRIGGER;RELATED=START:-PT15M
                                      END:VALARM
                                      END:VEVENT
                                      {"type":"VEVENT","params":[],"uid":"E689AEB8C02C4E2CADD8C7D3D303CEAD0","start":"2021-04-15T17:00:00.000Z","datetype":"date-time","end":"2021-04-15T19:00:00.000Z","a94d8d2a-3>
                                      [24.10.2023 00:16.22.001] [DEBUG] start: Thu Apr 15 2021 19:00:00 GMT+0200 (Midden-Europese zomertijd)
                                      [24.10.2023 00:16.22.001] [DEBUG] end:: Thu Apr 15 2021 21:00:00 GMT+0200 (Midden-Europese zomertijd)
                                      [24.10.2023 00:16.22.002] [DEBUG] duration: 7200000
                                      [24.10.2023 00:16.22.002] [DEBUG] title: xxx xxxx
                                      [24.10.2023 00:16.22.002] [DEBUG] Search for recurring events between: Tue Oct 24 2023 00:16:22 GMT+0200 (Midden-Europese zomertijd) and Tue Oct 22 2024 23:59:59 GMT+0200 (M>
                                      [24.10.2023 00:16.22.051] [DEBUG] Title: xxx xxxx, with dates: [null,null,null,null]
                                      [24.10.2023 00:16.22.051] [DEBUG] event.recurrences: [object Object]
                                      [24.10.2023 00:16.22.055] [ERROR] Calendar Error. Could not fetch calendar:  https://url/ical/url/Calendar.ics RangeError: Invalid time value
                                        @Dennis-010 awesome, will need you to run it again with one debugging change
                                        in calendarfetchutils.js
                                        change this
                                        					Log.debug(`event.recurrences: ${event.recurrences}`);
                                        to this
                                        			Log.debug("event.recurrences:" +JSON.stringify(event.recurrences));
                                        but I really think its THIS
                                        the until is outside the event window start/end (04/15, this is 04/18)
                                        AND the event is in the past 2021
                                        but the code tried to find recurrences THIS year
                                        [24.10.2023 00:16.22.051] [DEBUG] Title: xxx xxxx, with dates: [null,null,null,null]  <----- and returned junk.. those are bad dates.
                                          @Dennis-010 try this
                                          cp calendarfetcherutils.js  utils.js
                                          nano calendarfetcherutils.js
                                          insert this line
                                          						futureLocal = futureMoment.toDate(); // future
                                          					if(moment(endDate)>=moment(pastLocal)){ //<--- this line (approx line 283)
                                          						Log.debug(`Search for recurring events between: ${pastLocal} and ${futureLocal}`);
                                          						const dates = rule.between(pastLocal, futureLocal, true, limitFunction);
                                          and this line
                                          							i
                                          									description: description
                                          						} // < ----- this line (approx line 454)
                                          this adds a check if the event end is after the calculated start (for include past events thats a year back) , then process the event, else skip it…
                                          let me know
                                            This did the trick, thank you very much.
                                            You are a genius!!
