    MMM-Calendar not seem to load .ics
    21 Posts 2 Posters 6.8k Views 2 Watching
      sdetweil @Dennis-010
      @Dennis-010
      ok, lets try this
      cd ~/MagicMirror/modules/default/calendar
      cp calendarfetcher.js  savefetcher.js
      nano calendarfetcher.js
      then insert this line
      const Log = require("logger");
      const fetchit = require('node-fetch');   //<----- add this line
      const NodeHelper = require("node_helper");
      then add this line
      		const nodeVersion = Number(process.version.match(/^v(\d+\.\d+)/)[1]);
      		let fetcher = null //<------ add this line
      		let httpsAgent = null;
      then later change this
      		fetch(url, { headers: headers, agent: httpsAgent })
      to this
      		if (fetcher === null) {
      			fetcher = fetchit(url, { headers: headers, agent: httpsAgent });
      		fetcher
      then save, (ctrl-o)
      and exit nano (ctrl-x)
      then
      npm install node-fetch@2
      then npm start
      calendar should come up
      mine works…
        Dennis-010 @sdetweil
        This seem to work like a charm, thank you for fixing this.
        Now…when I want to add 2 more url’s I get a new error:
        For each of the new url. Both from the same domain.
        is it possible to have a hacky line for that as well?
        [ERROR] Calendar Error. Could not fetch calendar:  https://www.xxxxxxxx/ical/**url**/Calendar.ics RangeError: Invalid time value
        [23.10.2023 22:56.15.687] [LOG]   Create new calendarfetcher for url: https://**url**/ical/**url**/Calendar.ics - Interval: 3600000
        [23.10.2023 22:56.15.728] [LOG]   Create new calendarfetcher for url: https://**url**/ical/**url**/Calendar.ics - Interval: 3600000
        [23.10.2023 22:56.15.733] [LOG]   Create new calendarfetcher for url: https://**url**/ical/**url**/Calendar.ics - Interval: 3600000
          @Dennis-010 this sounds like an ics data format problem
          change this line in config.js
          logLevel: ["INFO", "LOG", "WARN", "ERROR"],
          to
          logLevel: ["INFO", "LOG", "WARN", "ERROR","DEBUG"],
          then start MM like this
          pm2 stop all
          npm start > somefile.txt 2>&1
          wait 15 seconds
          then in the same window as where you did npm start do
          ctrl-c
          and then examine the somefile.txt to see where that error is…
          i’d like to see the ics file entry for that event
          npm start
            Is this what you are looking for?
            [23.10.2023 23:18.36.721] [ERROR] Calendar Error. Could not fetch calendar:  https://**url**/ical/**url**/Calendar.ics RangeError: Invalid time value
                at Date.toISOString (<anonymous>)
                at /home/dennis/MagicMirror/modules/default/calendar/calendarfetcherutils.js:312:28
                at Array.forEach (<anonymous>)
                at Object.filterEvents (/home/dennis/MagicMirror/modules/default/calendar/calendarfetcherutils.js:140:24)
                at /home/dennis/MagicMirror/modules/default/calendar/calendarfetcher.js:72:36
                at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
            [23.10.2023 23:18.38.049] [DEBUG] parsed data={"ecaf4d70-3f05-470f-a8f3-2566b4f2f1b5":{"type":"VTIMEZONE","params":[],"tzid":"Europe/Amsterdam","487c4058-cf12-4ad3-9d19-abf7c43101a2":{>
            [23.10.2023 23:18.38.053] [DEBUG] There are 327 calendar entries.
            [23.10.2023 23:18.38.055] [DEBUG] Processing entry...
            [23.10.2023 23:18.38.058] [DEBUG] Processing entry...
            [23.10.2023 23:18.38.060] [DEBUG] Event:
            [23.10.2023 23:18.38.153] [ERROR] Calendar Error. Could not fetch calendar:  https://**url**/ical/**url**/Calendar.ics RangeError: Invalid time value
            [23.10.2023 23:18.39.055] [DEBUG] parsed data={"634747":{"type":"VEVENT","params":[],"dtstamp":"2018-03-19T19:38:00.000Z","uid":"634747","description":"Datum: 04/24/2018\nTijd: 19:30\n>
            [23.10.2023 23:18.39.060] [DEBUG] There are 434 calendar entries.
            [23.10.2023 23:18.39.061] [DEBUG] Processing entry...
            [23.10.2023 23:18.39.061] [DEBUG] Event:
            {"type":"VEVENT","params":[],"dtstamp":"2018-03-19T19:38:00.000Z","uid":"634747","description":"Datum: 04/24/2018\nTijd: 19:30\n\nTot dan!\n\nP.S.: Gebruik je GMAIL? Controleer of de t>
            [23.10.2023 23:18.39.062] [DEBUG] start: Tue Apr 24 2018 19:30:00 GMT+0200 (Midden-Europese zomertijd)
              @Dennis-010 thx… I meant download the ics file and find that entry
              like this from my calendar
              BEGIN:VEVENT
              DTSTART:20160729T233000Z
              DTEND:20160730T010000Z
              DTSTAMP:20231023T212812Z
              UID:2prgqt2idcgs5jjf0bvd557v6k@google.com
              CREATED:20160912T121808Z
              LAST-MODIFIED:20160912T121808Z
              SEQUENCE:0
              STATUS:CONFIRMED
              SUMMARY:Dinner at Monument Cafe
              TRANSP:OPAQUE
              END:VEVENT
                I don’t think I understand what you’re asking.
                What event you want me to find?
                  @Dennis-010 the one that throws the error in the somefile.txt, then look it up in the ICS file
                    Think I found it, will check back tomorrow.
                    BEGIN:VEVENT
                    DTSTAMP:20210413T203456Z
                    UID:E689AEB8C02C4E2CADD8C7D3D303CEAD0
                    DTSTART;TZID="Amsterdam, Belgrade, Berlin, Brussels, Budapest, Madrid, Paris, Prague, Stockholm":20210415T190000
                    DTEND;TZID="Amsterdam, Belgrade, Berlin, Brussels, Budapest, Madrid, Paris, Prague, Stockholm":20210415T210000
                    CLASS:PUBLIC
                    SUMMARY:xxx xxxx
                    SEQUENCE:10
                    RRULE:FREQ=DAILY;UNTIL=20210418T170000Z
                    EXDATE;TZID="Amsterdam, Belgrade, Berlin, Brussels, Budapest, Madrid, Paris, Prague, Stockholm":20210417T190000
                    EXDATE;TZID="Amsterdam, Belgrade, Berlin, Brussels, Budapest, Madrid, Paris, Prague, Stockholm":20210416T190000
                    EXDATE;TZID="Amsterdam, Belgrade, Berlin, Brussels, Budapest, Madrid, Paris, Prague, Stockholm":20210415T190000
                    BEGIN:VALARM
                    ACTION:DISPLAY
                    TRIGGER;RELATED=START:-PT15M
                    END:VALARM
                    END:VEVENT
                    {"type":"VEVENT","params":[],"uid":"E689AEB8C02C4E2CADD8C7D3D303CEAD0","start":"2021-04-15T17:00:00.000Z","datetype":"date-time","end":"2021-04-15T19:00:00.000Z","a94d8d2a-3>
                    [24.10.2023 00:16.22.001] [DEBUG] start: Thu Apr 15 2021 19:00:00 GMT+0200 (Midden-Europese zomertijd)
                    [24.10.2023 00:16.22.001] [DEBUG] end:: Thu Apr 15 2021 21:00:00 GMT+0200 (Midden-Europese zomertijd)
                    [24.10.2023 00:16.22.002] [DEBUG] duration: 7200000
                    [24.10.2023 00:16.22.002] [DEBUG] title: xxx xxxx
                    [24.10.2023 00:16.22.002] [DEBUG] Search for recurring events between: Tue Oct 24 2023 00:16:22 GMT+0200 (Midden-Europese zomertijd) and Tue Oct 22 2024 23:59:59 GMT+0200 (M>
                    [24.10.2023 00:16.22.051] [DEBUG] Title: xxx xxxx, with dates: [null,null,null,null]
                    [24.10.2023 00:16.22.051] [DEBUG] event.recurrences: [object Object]
                    [24.10.2023 00:16.22.055] [ERROR] Calendar Error. Could not fetch calendar:  https://url/ical/url/Calendar.ics RangeError: Invalid time value
                      @Dennis-010 awesome, will need you to run it again with one debugging change
                      in calendarfetchutils.js
                      change this
                      					Log.debug(`event.recurrences: ${event.recurrences}`);
                      to this
                      			Log.debug("event.recurrences:" +JSON.stringify(event.recurrences));
                      but I really think its THIS
                      the until is outside the event window start/end (04/15, this is 04/18)
                      AND the event is in the past 2021
                      but the code tried to find recurrences THIS year
                      [24.10.2023 00:16.22.051] [DEBUG] Title: xxx xxxx, with dates: [null,null,null,null]  <----- and returned junk.. those are bad dates.
                        @Dennis-010 try this
                        cp calendarfetcherutils.js  utils.js
                        nano calendarfetcherutils.js
                        insert this line
                        						futureLocal = futureMoment.toDate(); // future
                        					if(moment(endDate)>=moment(pastLocal)){ //<--- this line (approx line 283)
                        						Log.debug(`Search for recurring events between: ${pastLocal} and ${futureLocal}`);
                        						const dates = rule.between(pastLocal, futureLocal, true, limitFunction);
                        and this line
                        							i
                        									description: description
                        						} // < ----- this line (approx line 454)
                        this adds a check if the event end is after the calculated start (for include past events thats a year back) , then process the event, else skip it…
                        let me know
                          This did the trick, thank you very much.
                          You are a genius!!
                            @Dennis-010 said in MMM-Calendar not seem to load .ics:
                            You are a genius!!
                            well, i don’t know about that… I’ve just spent the last few years fixing bugs in there
