    White screen after xx time
    6 Posts 3 Posters 2.9k Views 2 Watching
      Sillec123
      I am using a PI2 and i have the following problem. After xxx minutes the screen will be white and blank. If i am using a remote browser i can reach the right site without any problems. That means the service is available.
        Sillec123
        No one with a solution???
        • bheplerB Offline
          bhepler Module Developer
          I had this problem a while ago when I was playing with Motion and a Raspicam. My solution was to have PM2 monitor the Motion process and restart it whenever it would hang. The process would occasionally hang when writing to the memory card, but I’m not sure if that’s the problem in your case.
          Anyhow, between PM2 monitoring the Motion process and restarting it when necessary and a scheduled reboot every morning at 2AM, it haven’t had the white screen problem in months.
            Sillec123
            How do you monitoring this process? Do you have an example script for it?
            • MichMichM Offline
              MichMich
              Not exactly sure if it helps, but you might try this module: https://github.com/MichMich/MMM-WatchDog
              • bheplerB Offline
                bhepler Module Developer @Sillec123
                @Sillec123 I followed the steps in the Autostarting Magic Mirror tutorial. It was trivial to add the motion startup script to the list of processes for PM2.
