    Config option with array of multiple values?
    25 Posts 3 Posters 9.7k Views 3 Watching
    • UncleRogerU
      UncleRoger @sdetweil
      @sdetweil said in Config option with array of multiple values?:
      generally when you expand the number of items in an array to objects ({}) you start to get thinking about what happens if you decide to add another entry in the object…
      so in javascript you can NAME the elements
      validSenders: [
                      { url:"mom@example.com", name:"Mom", color:"#ff0000" },
                      { url"dad@example.com", name:"Dad", color:"#00ff00" },
                      { url:"son@example.com", name:"Son", color:"#0000ff" },
      that way the code is not sensitive to the order of the elements
           validSenders.forEach(sender =>{
                   if (sender.name =="Dad") {
                        do_something(sender.url)
      So in this scenario, you have validSenders the array and, for example, validSenders.url as one attribute(?) of the array? In your example, where does “sender” come from? It’s not one of the named elements. Is it a sort of temporary variable that gets handed the array … object(?) … so in the first iteration of the forEach (which I assume loops through each entry in the validSenders array), sender would contain(?) url:"mom@example.com", name:“Mom”, and color:“#ff0000”? And sender.url would be “mom@example.com”?
      That makes sense. I apologize for not knowing the terminology; I’m very new to the whole OOP sort of thing.
      you can also use the array.filter() function
      let selected_sender = validSenders.filter(sender=>{
            if(sender.url==mailObj.sender[0].address)
                 return true
           else
                 return false
      if(selected_sender.length>0){
          // we found a matching sender
      the filter function passes each element array in turn to the function
      if you want the element in the output array return true,
      if not return false
      Could this return false if it doesn’t match but an index if it matches so that one could refer to validSenders.color[selected_sender] to get the right attribute?
      I really kinda wish I had a spare RPi laying around so I could do this testing on something other than my production mirror. (I mean, everyone’s aware that it’s a work-in-progress but I don’t want to muck it up.)
      • that.config.validSenders.includes(mailObj.sender[0].address)
      • daysAgo >= 0
      • daysAgo <= that.config.daysToDisplay
      the last two CANNOT be true at the same time
      I’m not sure I understand… if daysToDisplay is, say, 50 and daysAgo = 25, then the last two would both be true?
      What I’m trying to do is make sure that the sender of an e-mail is in the list of valid senders and that the date the e-mail was sent is not more than daysToDisplay days ago.
      maybe what you wanted was
      if (
           that.config.validSenders.includes(mailObj.sender[0].address) &&
          (daysAgo >= 0 && daysAgo <= that.config.daysToDisplay)
      this is two outer compares (with one inner)
      I thought I tried that but even so, I don’t understand how that’s different from what I had. I thought that “If A && B && C” would be the same as “If A && (B && C)” – in either case, all three have to be true for the whole thing to be true.
      • UncleRogerU
        if (
        I just tried this and it works. Not sure why the extra set of parentheses are needed but I’m not going to argue. 8^)
        Thanks!
          sdetweil @UncleRoger
          @UncleRoger array.filter() returns an array with the items that the matching function returned true
          so there is only one. no need for the index. it returned the entire object, item in the list
          sender is the name of the parameter passed to the matching function, the element of the array
          S UncleRogerU 2 Replies Last reply
            @UncleRoger >I really kinda wish I had a spare RPi laying
            MagicMirror will run on windows. you don’t need a pi
            • UncleRogerU
              I got it working with the .filter function:
              let selSender = that.config.validSenders.filter(mySender => {
              	if (mySender.addr.toLowerCase() == mailObj.sender[0].address.toLowerCase())
              		return true
              	 else
              		return false
              but now I’m having a problem trying to use the returned array. In this code the adding the color element to the subject works fine (that’s there for testing), as does the setting the style.color, but if I uncomment the if statement, it crashes:
              subject = subject + selSender[0].color;
              //		if (selSender[0].color != undefined) {
              			subjectWrapper.style.color = selSender[0].color;
              //		} else {
              Is there a reason it doesn’t like that in the IF statement? Note: I also tried it as just “if (selSender[0].color) {” and assigning the value of selSender[0].color to another variable and using that other variable in the IF statement. In at least one test case there is a value in color.
              UncleRogerU 1 Reply Last reply
              • UncleRogerU
                UncleRoger @UncleRoger
                @UncleRoger said in Config option with array of multiple values?:
                // } else {
                Okay, so it looks like Javascript wants “!==”, not “!=”. Ugh.
                Anyway, I got it working using a “switch (true)” block.
                Thanks for all the help!
                  @UncleRoger yes the compares
                  are different
                  one compare s the data type too
                  2 is a number
                  “2” is a string
                  • MZ-BERM
                    MZ-BER
                    Hello @UncleRoger - are you planning to publish your module? And can I may ask you what this module will do?
                    • UncleRogerU
                      UncleRoger @MZ-BER
                      @MZ-BER said in Config option with array of multiple values?:
                      Yes, I am planning to publish it, once I’ve tested it reasonably well. Mostly, it seems to work thus far. I’m doing more testing and working on documentation.
                      The module checks an e-mail address and then shows the subject of any e-mails on the MM. Basically, I wanted a way for my wife and I to post messages for the whole family to see. This is an idea I’ve had for a long time (going back to the days of pagers) and is kinda obsolete – we use text messages and instagram messages a lot these days – but I still wanted to make this happen.
                      Probably next week I’ll be posting a message “how do I put a module in github for everyone to use?” as I’m totally new to all of this. 8^)
                      • UncleRogerU
                        yes the compares
                        are different
                        Heh. Back in my day, we got one equality operator and one inequality operator and we were dang thankful for that. Now git off my lawn! 8^)
                        Seriously, though, thanks for all your help!
                          @UncleRoger I agree. I came in before these fancy new languages. before web.
                            @UncleRoger logon to GitHub, click repositories , new, make the name match your module name, create.
                            it will give you a set of commands to execute in your module folder to upload it to that repo…
                            easy peasy
                            note that you need to create an access key thru the GitHub profile menu to be able to upload.(aka push)
                            this replaces the requested password now
                            UncleRogerU S 2 Replies Last reply
                            • UncleRogerU
                              it will give you a set of commands to execute in your module folder to.upload it to that repo…
                              easy peasy
                              I’ve got a repository set up with a README.md file but I don’t see anything about how to upload the module.
                              Also, is there anywhere with a list of what files I need to upload? These are the files in my directory:
                               ll
                              total 32
                              -rw-r--r--  1 roger roger   59 Oct 25 07:43 email.css.orig
                              -rw-r--r--  1 roger roger 6420 Oct 27 11:26 MMM-MailMessage.js
                              -rw-r--r--  1 roger roger 3566 Oct 25 12:44 MMM-MailMessage.js.save
                              -rw-r--r--  1 roger roger 3117 Oct 25 07:58 node_helper.js
                              drwxr-xr-x 12 roger roger 4096 Oct 25 12:44 node_modules
                              -rw-r--r--  1 roger roger  355 Oct 27 12:37 package.json
                              -rw-r--r--  1 roger roger 3755 Oct 25 12:44 package-lock.json
                              I’m pretty sure the node_modules directory comes from the emailjs-imap-client that it needs (which came from an npm install) so I don’t think that should be in the repository for this module. I’m not sure about package-lock.json. I think package.json is needed – it basically just has the name & description and says it needs the emailjs thing.
                              Other than that, it’s MMM-MailMessage.js and node_helper.js so I think the files needed are:
                              • MMM-MailMessage.js
                              • node_helper.js
                              • package.json
                              Is that right?
                                @UncleRoger then to update your repo
                                on the pi in your module folder
                                git status
                                will tell you the files that changed
                                git add .
                                will add them all
                                git add filename filename2
                                will add only those to the pending commit
                                git commit -m "some message why you made these changes"
                                then
                                git push
                                to upload
                                  @UncleRoger when you created the repo on GitHub you should have seen this output
                                  I named my repo fribble2 for this test
                                  in the section on create new from commandline
                                  I would not do the git add for the readme as I have that already on the GitHub side
                                  • UncleRogerU
                                    I think I’ve managed to thoroughly muck things up. Apparently my changes are in a branch called “master” and the repository has a “main” and never the twain shall meet.
                                    If I go to the “pull requests” tab in github, it shows me the differences between the file there and my changed file but there’s no way to merge them. This is what I’m seeing:
                                    I have the module working for me on my system but I don’t seem to be able to get it to a state where I can publish it.
                                    I’ve never used git/github before (other than to download modules) and, frankly, there’s a lot of base knowledge I don’t have that seems to be required to understand it and get it working.
                                      @UncleRoger ok
                                      ok, the easiest way to handle this
                                      rename your module folder to some other name
                                      then git clone your github repo
                                      then copy the files from your renamed folder to the clone
                                      then in the clone folder do
                                       git add .
                                      git commit -m "adding 1st commit"
                                      git push
                                      then the local branch will be the same as the remote(github) branch
                                      and all will be well from then on, and u can delete the renamed folder
                                        @UncleRoger well, maybe its even easier
                                        on the github page
                                        the link next to the branches
                                        you can rename main to xyz
                                        then rename master to main
                                        then delete xyz branch
                                        then on your pc
                                        rename the existing folder out of the way
                                        git clone your repo again
                                        then you will be in sync
                                        • UncleRogerU
                                          I went with your first suggestion and it seems to be all better now.
                                          I’m going to play with it some more but once I’m satisfied it won’t break anyone’s set up too badly, do I just change the visibility from private to public?
                                          There was a notice about the repository not being protected but it seems to have gone away; is that something I should worry about?
                                          Lastly, I see this on the repository page:
                                          Do I need to do anything about those?
                                          Thanks again for all your help and your patience!
                                            @UncleRoger just change it to public. the others are for bigger projects
