    Config option with array of multiple values?
    25 Posts 3 Posters 9.7k Views 3 Watching
    • UncleRogerU
      UncleRoger @sdetweil
      I got it working with the .filter function:
      let selSender = that.config.validSenders.filter(mySender => {
      	if (mySender.addr.toLowerCase() == mailObj.sender[0].address.toLowerCase())
      		return true
      	 else
      		return false
      but now I’m having a problem trying to use the returned array. In this code the adding the color element to the subject works fine (that’s there for testing), as does the setting the style.color, but if I uncomment the if statement, it crashes:
      subject = subject + selSender[0].color;
      //		if (selSender[0].color != undefined) {
      			subjectWrapper.style.color = selSender[0].color;
      //		} else {
      Is there a reason it doesn’t like that in the IF statement? Note: I also tried it as just “if (selSender[0].color) {” and assigning the value of selSender[0].color to another variable and using that other variable in the IF statement. In at least one test case there is a value in color.
      UncleRogerU 1 Reply Last reply
      • UncleRogerU
        UncleRoger @UncleRoger
        @UncleRoger said in Config option with array of multiple values?:
        // } else {
        Okay, so it looks like Javascript wants “!==”, not “!=”. Ugh.
        Anyway, I got it working using a “switch (true)” block.
        Thanks for all the help!
          sdetweil @UncleRoger
          @UncleRoger yes the compares
          are different
          one compare s the data type too
          2 is a number
          “2” is a string
          • MZ-BERM
            MZ-BER
            Hello @UncleRoger - are you planning to publish your module? And can I may ask you what this module will do?
            UncleRogerU 2 Replies Last reply
            • UncleRogerU
              UncleRoger @MZ-BER
              @MZ-BER said in Config option with array of multiple values?:
              Yes, I am planning to publish it, once I’ve tested it reasonably well. Mostly, it seems to work thus far. I’m doing more testing and working on documentation.
              The module checks an e-mail address and then shows the subject of any e-mails on the MM. Basically, I wanted a way for my wife and I to post messages for the whole family to see. This is an idea I’ve had for a long time (going back to the days of pagers) and is kinda obsolete – we use text messages and instagram messages a lot these days – but I still wanted to make this happen.
              Probably next week I’ll be posting a message “how do I put a module in github for everyone to use?” as I’m totally new to all of this. 8^)
              • UncleRogerU
                @sdetweil said in Config option with array of multiple values?:
                yes the compares
                are different
                Heh. Back in my day, we got one equality operator and one inequality operator and we were dang thankful for that. Now git off my lawn! 8^)
                Seriously, though, thanks for all your help!
                  @UncleRoger I agree. I came in before these fancy new languages. before web.
                    @UncleRoger logon to GitHub, click repositories , new, make the name match your module name, create.
                    it will give you a set of commands to execute in your module folder to upload it to that repo…
                    easy peasy
                    note that you need to create an access key thru the GitHub profile menu to be able to upload.(aka push)
                    this replaces the requested password now
                    UncleRogerU S 2 Replies Last reply
                    • UncleRogerU
                      it will give you a set of commands to execute in your module folder to.upload it to that repo…
                      easy peasy
                      I’ve got a repository set up with a README.md file but I don’t see anything about how to upload the module.
                      Also, is there anywhere with a list of what files I need to upload? These are the files in my directory:
                       ll
                      total 32
                      -rw-r--r--  1 roger roger   59 Oct 25 07:43 email.css.orig
                      -rw-r--r--  1 roger roger 6420 Oct 27 11:26 MMM-MailMessage.js
                      -rw-r--r--  1 roger roger 3566 Oct 25 12:44 MMM-MailMessage.js.save
                      -rw-r--r--  1 roger roger 3117 Oct 25 07:58 node_helper.js
                      drwxr-xr-x 12 roger roger 4096 Oct 25 12:44 node_modules
                      -rw-r--r--  1 roger roger  355 Oct 27 12:37 package.json
                      -rw-r--r--  1 roger roger 3755 Oct 25 12:44 package-lock.json
                      I’m pretty sure the node_modules directory comes from the emailjs-imap-client that it needs (which came from an npm install) so I don’t think that should be in the repository for this module. I’m not sure about package-lock.json. I think package.json is needed – it basically just has the name & description and says it needs the emailjs thing.
                      Other than that, it’s MMM-MailMessage.js and node_helper.js so I think the files needed are:
                      • MMM-MailMessage.js
                      • node_helper.js
                      • package.json
                      Is that right?
                        @UncleRoger then to update your repo
                        on the pi in your module folder
                        git status
                        will tell you the files that changed
                        git add .
                        will add them all
                        git add filename filename2
                        will add only those to the pending commit
                        git commit -m "some message why you made these changes"
                        then
                        git push
                        to upload
                          @UncleRoger when you created the repo on GitHub you should have seen this output
                          I named my repo fribble2 for this test
                          in the section on create new from commandline
                          I would not do the git add for the readme as I have that already on the GitHub side
                          • UncleRogerU
                            I think I’ve managed to thoroughly muck things up. Apparently my changes are in a branch called “master” and the repository has a “main” and never the twain shall meet.
                            If I go to the “pull requests” tab in github, it shows me the differences between the file there and my changed file but there’s no way to merge them. This is what I’m seeing:
                            I have the module working for me on my system but I don’t seem to be able to get it to a state where I can publish it.
                            I’ve never used git/github before (other than to download modules) and, frankly, there’s a lot of base knowledge I don’t have that seems to be required to understand it and get it working.
                              @UncleRoger ok
                              ok, the easiest way to handle this
                              rename your module folder to some other name
                              then git clone your github repo
                              then copy the files from your renamed folder to the clone
                              then in the clone folder do
                               git add .
                              git commit -m "adding 1st commit"
                              git push
                              then the local branch will be the same as the remote(github) branch
                              and all will be well from then on, and u can delete the renamed folder
                                @UncleRoger well, maybe its even easier
                                on the github page
                                the link next to the branches
                                you can rename main to xyz
                                then rename master to main
                                then delete xyz branch
                                then on your pc
                                rename the existing folder out of the way
                                git clone your repo again
                                then you will be in sync
                                • UncleRogerU
                                  I went with your first suggestion and it seems to be all better now.
                                  I’m going to play with it some more but once I’m satisfied it won’t break anyone’s set up too badly, do I just change the visibility from private to public?
                                  There was a notice about the repository not being protected but it seems to have gone away; is that something I should worry about?
                                  Lastly, I see this on the repository page:
                                  Do I need to do anything about those?
                                  Thanks again for all your help and your patience!
                                    @UncleRoger just change it to public. the others are for bigger projects
                                    • UncleRogerU
                                      @sdetweil Thanks!
                                      • UncleRogerU
                                        UncleRoger @MZ-BER
                                        @MZ-BER
                                        FYI, I’ve published and posted in the modules/showcase forum.
                                        https://forum.magicmirror.builders/topic/18139/mmm-mailmessage-send-messages-to-your-magicmirror-via-e-mail?_=1698853756973
