    Config option with array of multiple values?
    25 Posts 3 Posters 9.7k Views 3 Watching
    • UncleRogerU
      UncleRoger @sdetweil
      @sdetweil said in Config option with array of multiple values?:
      maybe what you wanted was
      if (
           that.config.validSenders.includes(mailObj.sender[0].address) &&
          (daysAgo >= 0 && daysAgo <= that.config.daysToDisplay)
      this is two outer compares (with one inner)
      I just tried this and it works. Not sure why the extra set of parentheses are needed but I’m not going to argue. 8^)
      Thanks!
        sdetweil @UncleRoger
        @UncleRoger array.filter() returns an array with the items that the matching function returned true
        so there is only one. no need for the index. it returned the entire object, item in the list
        sender is the name of the parameter passed to the matching function, the element of the array
        S UncleRogerU 2 Replies Last reply
          @UncleRoger >I really kinda wish I had a spare RPi laying
          MagicMirror will run on windows. you don’t need a pi
          • UncleRogerU
            I got it working with the .filter function:
            let selSender = that.config.validSenders.filter(mySender => {
            	if (mySender.addr.toLowerCase() == mailObj.sender[0].address.toLowerCase())
            		return true
            	 else
            		return false
            but now I’m having a problem trying to use the returned array. In this code the adding the color element to the subject works fine (that’s there for testing), as does the setting the style.color, but if I uncomment the if statement, it crashes:
            subject = subject + selSender[0].color;
            //		if (selSender[0].color != undefined) {
            			subjectWrapper.style.color = selSender[0].color;
            //		} else {
            Is there a reason it doesn’t like that in the IF statement? Note: I also tried it as just “if (selSender[0].color) {” and assigning the value of selSender[0].color to another variable and using that other variable in the IF statement. In at least one test case there is a value in color.
            UncleRogerU 1 Reply Last reply
            • UncleRogerU
              UncleRoger @UncleRoger
              @UncleRoger said in Config option with array of multiple values?:
              // } else {
              Okay, so it looks like Javascript wants “!==”, not “!=”. Ugh.
              Anyway, I got it working using a “switch (true)” block.
              Thanks for all the help!
                @UncleRoger yes the compares
                are different
                one compare s the data type too
                2 is a number
                “2” is a string
                • MZ-BERM
                  MZ-BER
                  Hello @UncleRoger - are you planning to publish your module? And can I may ask you what this module will do?
                  • UncleRogerU
                    UncleRoger @MZ-BER
                    @MZ-BER said in Config option with array of multiple values?:
                    Yes, I am planning to publish it, once I’ve tested it reasonably well. Mostly, it seems to work thus far. I’m doing more testing and working on documentation.
                    The module checks an e-mail address and then shows the subject of any e-mails on the MM. Basically, I wanted a way for my wife and I to post messages for the whole family to see. This is an idea I’ve had for a long time (going back to the days of pagers) and is kinda obsolete – we use text messages and instagram messages a lot these days – but I still wanted to make this happen.
                    Probably next week I’ll be posting a message “how do I put a module in github for everyone to use?” as I’m totally new to all of this. 8^)
                    • UncleRogerU
                      yes the compares
                      are different
                      Heh. Back in my day, we got one equality operator and one inequality operator and we were dang thankful for that. Now git off my lawn! 8^)
                      Seriously, though, thanks for all your help!
                        @UncleRoger I agree. I came in before these fancy new languages. before web.
                          @UncleRoger logon to GitHub, click repositories , new, make the name match your module name, create.
                          it will give you a set of commands to execute in your module folder to upload it to that repo…
                          easy peasy
                          note that you need to create an access key thru the GitHub profile menu to be able to upload.(aka push)
                          this replaces the requested password now
                          UncleRogerU S 2 Replies Last reply
                          • UncleRogerU
                            it will give you a set of commands to execute in your module folder to.upload it to that repo…
                            easy peasy
                            I’ve got a repository set up with a README.md file but I don’t see anything about how to upload the module.
                            Also, is there anywhere with a list of what files I need to upload? These are the files in my directory:
                             ll
                            total 32
                            -rw-r--r--  1 roger roger   59 Oct 25 07:43 email.css.orig
                            -rw-r--r--  1 roger roger 6420 Oct 27 11:26 MMM-MailMessage.js
                            -rw-r--r--  1 roger roger 3566 Oct 25 12:44 MMM-MailMessage.js.save
                            -rw-r--r--  1 roger roger 3117 Oct 25 07:58 node_helper.js
                            drwxr-xr-x 12 roger roger 4096 Oct 25 12:44 node_modules
                            -rw-r--r--  1 roger roger  355 Oct 27 12:37 package.json
                            -rw-r--r--  1 roger roger 3755 Oct 25 12:44 package-lock.json
                            I’m pretty sure the node_modules directory comes from the emailjs-imap-client that it needs (which came from an npm install) so I don’t think that should be in the repository for this module. I’m not sure about package-lock.json. I think package.json is needed – it basically just has the name & description and says it needs the emailjs thing.
                            Other than that, it’s MMM-MailMessage.js and node_helper.js so I think the files needed are:
                            • MMM-MailMessage.js
                            • node_helper.js
                            • package.json
                            Is that right?
                              @UncleRoger then to update your repo
                              on the pi in your module folder
                              git status
                              will tell you the files that changed
                              git add .
                              will add them all
                              git add filename filename2
                              will add only those to the pending commit
                              git commit -m "some message why you made these changes"
                              then
                              git push
                              to upload
                                @UncleRoger when you created the repo on GitHub you should have seen this output
                                I named my repo fribble2 for this test
                                in the section on create new from commandline
                                I would not do the git add for the readme as I have that already on the GitHub side
                                • UncleRogerU
                                  I think I’ve managed to thoroughly muck things up. Apparently my changes are in a branch called “master” and the repository has a “main” and never the twain shall meet.
                                  If I go to the “pull requests” tab in github, it shows me the differences between the file there and my changed file but there’s no way to merge them. This is what I’m seeing:
                                  I have the module working for me on my system but I don’t seem to be able to get it to a state where I can publish it.
                                  I’ve never used git/github before (other than to download modules) and, frankly, there’s a lot of base knowledge I don’t have that seems to be required to understand it and get it working.
                                    @UncleRoger ok
                                    ok, the easiest way to handle this
                                    rename your module folder to some other name
                                    then git clone your github repo
                                    then copy the files from your renamed folder to the clone
                                    then in the clone folder do
                                     git add .
                                    git commit -m "adding 1st commit"
                                    git push
                                    then the local branch will be the same as the remote(github) branch
                                    and all will be well from then on, and u can delete the renamed folder
                                      @UncleRoger well, maybe its even easier
                                      on the github page
                                      the link next to the branches
                                      you can rename main to xyz
                                      then rename master to main
                                      then delete xyz branch
                                      then on your pc
                                      rename the existing folder out of the way
                                      git clone your repo again
                                      then you will be in sync
                                      • UncleRogerU
                                        I went with your first suggestion and it seems to be all better now.
                                        I’m going to play with it some more but once I’m satisfied it won’t break anyone’s set up too badly, do I just change the visibility from private to public?
                                        There was a notice about the repository not being protected but it seems to have gone away; is that something I should worry about?
                                        Lastly, I see this on the repository page:
                                        Do I need to do anything about those?
                                        Thanks again for all your help and your patience!
                                          @UncleRoger just change it to public. the others are for bigger projects
                                          • UncleRogerU
                                            @sdetweil Thanks!
