    Image in module not showing on mirror browser
    12 Posts 4 Posters 5.3k Views 4 Watching
    • lavolp3L Offline
      lavolp3 Module Developer
      HI,
      I have an issue where an image is not loading on the browser of the mirror itself, while on Firefox on my laptop, it shows.
      The image is loaded in MMM-Sonos:
                          if (item.track.albumArtURI !== null && item.track.albumArtURI !== undefined && item.track.albumArtURI.trim() !== "") {
                              albumCover.innerHTML = `<img src="${item.track.albumArtURI}" width="80" height="80">`;
                          } else {
                              albumCover.innerHTML = `<img src="SonosRadio.png" width="80" height="80">`;
                          container.append(albumCover);
      It seems to be some browser problem, because as said, on a laptop browser the image is shown.
      Any ideas?
      Thanks,
      Dirk
      How to troubleshoot modules
      MMM-soccer v2, MMM-AVStock
      M bugsounetB S 3 Replies Last reply Reply Quote 0
        MMRIZE @lavolp3
        @lavolp3
        Maybe CORS rule exception?
        • bugsounetB Offline
          bugsounet Banned @lavolp3
          @lavolp3
          Hi, what happen really? only show default image? Or the same? Nothing?
          Maybe typeOf is better for check uri value
          Maybe, InnerHtml is not the better way
          • create an img element
          • use img.src=“uri”
          • use an css class for width/height
          • maybe add an seed for use not image cache
          • create a function for update it
          Can we see current full code for inspect?
            sdetweil @lavolp3
            @lavolp3 open the developers window and select the console tab to see the error
            • lavolp3L Offline
              @sdetweil that’s what I usually do, but here the error is not reproducible on any other browser. But I can try to use electron’s developers tab.
              However, I strongly suspect the reason is @MMRIZE 's CORS issue.
              But have no real idea how to solve that.
              Anybody want to give me a hint?
              • lavolp3L Offline
                lavolp3 Module Developer @bugsounet
                @bugsounet Hi thanks for the help.
                Will consider reworking the code, but as said, it does work on an external browser, so the code itself should not be the issue, would it?
                Rather the interpretation by the browser or any frontend behaviour when downloading the file.
                  sdetweil @lavolp3
                  @lavolp3 use the cors service in MM… someone has to change the code to change the link
                  • lavolp3L Offline
                    @sdetweil What’s the CORS service in MM?
                    I see I have been away for a while…
                      sdetweil @lavolp3
                      @lavolp3 the systems are getting more sensitive to attackers everywhere
                      MM is on a system using 0.0.0.0 probably and that gets sent in the browser making the request and the remote system says, I don’t know where that it, its ‘NOT’ in my allowed systems…
                        sdetweil @lavolp3
                        @lavolp3
                        use this as the url
                        Example input request url:
                        http://address:port/cors?sendheaders=header1:value1,header2:value2&expectedheaders=header1,header2&url=http://www.test.com/path?param1=value1
                        so when you break that down
                        http://address:port MM address (can be localhost, or ip address) and port
                        url= the original url
                        sendheaders= whatever headers you need to set when sending
                        expectedheaders= whatever headers are expected on response
                          sdetweil @lavolp3
                          @lavolp3 said in Image in module not showing on mirror browser:
                          yes, have to do it where the error is
                            sdetweil @lavolp3
                            @lavolp3 see also
                            https://forum.magicmirror.builders/topic/18131/possible-cross-origin-issue
